电子发烧友论坛|
CAN0的能进去接收正常,CAN1是按葫芦画的,怎么不行呢,请指教
void FCAN1_Init(void) { uint32_t i32=0x00; /* Enable CAN module clock */ CLK_EnableModuleClock(CAN1_MODULE); /* Set PD multi-function pins for CANTX1, CANRX1 */ SYS->GPD_MFP &= ~(SYS_GPD_MFP_PD14_Msk | SYS_GPD_MFP_PD15_Msk); SYS->GPD_MFP |= SYS_GPD_MFP_PD15_CAN1_TXD | SYS_GPD_MFP_PD14_CAN1_RXD; SYS->ALT_MFP &= ~(SYS_ALT_MFP2_PD14_Msk | SYS_ALT_MFP2_PD15_Msk); SYS->ALT_MFP |= SYS_ALT_MFP2_PD15_CAN1_TXD | SYS_ALT_MFP2_PD14_CAN1_RXD; SelectCANSpeed(tCAN1); tCAN1->IF[0].MASK1 = 0x00UL; tCAN1->IF[0].MASK2 = 0x00UL; tCAN1->IF[0].MCON = 0x00; srecemsg_totalnumbers = 0x00; for(i32=0x00;i32IF[1].MASK1,tCAN0->IF[1].MASK2,tCAN0->IF[1].MCON); /* INT Mode */ CAN_EnableInt(tCAN1, CAN_CON_IE_Msk|CAN_CON_SIE_Msk|CAN_CON_EIE_Msk); /* Enable CAN interrupt and corresponding NVIC of CAN */ NVIC_SetPriority(CAN1_IRQn, (1 << __NVIC_PRIO_BITS) - 2); /* Install CAN call back functions */ NVIC_EnableIRQ(CAN1_IRQn); } 我也在用230 现在遇到can1中断既不去,楼主这个问题你解决了么? |
1个回答
/* Reset CAN1 */ SYS_ResetModule(CAN1_RST); /* Set CAN1 baud rate */ CAN_Open(CAN1, CAN_BAUDRATE_500K, CAN_NORMAL_MODE); /* Enable CAN1 receive interrupt */ CAN_EnableInt(CAN1, CAN_CON_IE_Msk | CAN_CON_SIE_Msk); NVIC_EnableIRQ(CAN1_IRQn); /* Set CAN1 message mask */ CAN_SetRxMsg(CAN1, CAN_STD_ID_MASK, CAN_STD_ID_MASK, CAN_MSG_ENHANCED);} One possible solution is to check if the CAN1 interrupt is enabled in the NVIC. If it is not enabled, use the "NVIC_EnableIRQ(CAN1_IRQn);" command to enable it. Another solution is to check the CAN1 configuration and ensure that it is correctly set up for the desired use case, including setting the CAN1 message mask and ensuring that the PD14 and PD15 pins are configured correctly. Finally, it may be helpful to use a debugger or oscilloscope to verify the CAN1 signals and diagnose any potential hardware issues. |
只有小组成员才能发言,加入小组>>
1018 浏览 1 评论
1849 浏览 0 评论
1830 浏览 1 评论
3254 浏览 5 评论
3581 浏览 9 评论
1021浏览 1评论
1850浏览 1评论
如何知道嵌入式电子控制单元 (ECU) 中的RAM使用情况?
1360浏览 1评论
1852浏览 0评论
1178浏览 0评论
/9
GMT+8, 2025-12-1 22:50 , Processed in 0.566143 second(s), Total 44, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3217
