这个是新塘官网的列子:脉宽的计算,这个结果和示波器捕获天壤之别,完全不对呀,有懂的大神说一下
/**************************************************************************//** * main.c * V1.00 * $Revision: 4 $ * $Date: 15/05/22 2:06p $ * Capture the PWMB Channel 1 waveform by PWMB Channel 2. * * @note * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved. * ******************************************************************************/ #include #include "M051Series.h" /*---------------------------------------------------------------------------------------------------------*/ /* Macro, type and constant definitions */ /*---------------------------------------------------------------------------------------------------------*/ #define PLLCON_SETTING CLK_PLLCON_50MHz_HXT #define PLL_CLOCK 50000000 /** * @brief PWMA IRQ Handler * * @param None * * @return None * * @details ISR to handle PWMA interrupt event */ void PWMA_IRQHandler(void) { /*In this sample code, user will not use PWMA channel 0~3 PIIR interrupt and CAPIF capture interrupt. Defined following code as 0 for reducing interrupt execution time and code size. */ #if 0 uint32_t u32PwmIntFlag, u32CapIntFlag0, u32CapIntFlag1; /* Handle PWMA Capture function */ u32CapIntFlag0 = PWMA->CCR0; u32CapIntFlag1 = PWMA->CCR2; if(u32CapIntFlag0 & PWM_CCR0_CAPIF0_Msk) { PWMA->CCR0 &= (PWM_CCR_MASK | PWM_CCR0_CAPIF0_Msk); } else if(u32CapIntFlag0 & PWM_CCR0_CAPIF1_Msk) { PWMA->CCR0 &= (PWM_CCR_MASK | PWM_CCR0_CAPIF1_Msk); } else if(u32CapIntFlag1 & PWM_CCR2_CAPIF2_Msk) { PWMA->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF2_Msk); } else if(u32CapIntFlag1 & PWM_CCR2_CAPIF3_Msk) { PWMA->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF3_Msk); } /* Handle PWMA Timer function */ u32PwmIntFlag = PWMA->PIIR; if(u32PwmIntFlag & PWM_PIIR_PWMIF0_Msk) { PWMA->PIIR = PWM_PIIR_PWMIF0_Msk; } else if(u32PwmIntFlag & PWM_PIIR_PWMIF1_Msk) { PWMA->PIIR = PWM_PIIR_PWMIF1_Msk; } else if(u32PwmIntFlag & PWM_PIIR_PWMIF2_Msk) { PWMA->PIIR = PWM_PIIR_PWMIF2_Msk; } else if(u32PwmIntFlag & PWM_PIIR_PWMIF3_Msk) { PWMA->PIIR = PWM_PIIR_PWMIF3_Msk; } #endif } /** * @brief PWMB IRQ Handler * * @param None * * @return None * * @details ISR to handle PWMB interrupt event */ void PWMB_IRQHandler(void) { // uint32_t u32PwmIntFlag; uint32_t u32CapIntFlag1; /* Handle PWMB Capture function */ u32CapIntFlag1 = PWMB->CCR2; /* PWMB channel 2 Capture interrupt */ if(u32CapIntFlag1 & PWM_CCR2_CAPIF2_Msk) { PWMB->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF2_Msk); } } /*--------------------------------------------------------------------------------------*/ /* Capture function to calculate the input waveform information */ /* u32Count[4] : Keep the internal counter value when input signal rising / falling */ /* happens */ /* */ /* time A B C D */ /* ___ ___ ___ ___ ___ ___ ___ ___ */ /* ____| |_| |_| |_| |_| |_| |_| |_| |_____ */ /* index 0 1 2 3 */ /* */ /* The capture internal counter down count from 0x10000, and reload to 0x10000 after */ /* input signal falling happens (Time B/C/D) */ /*--------------------------------------------------------------------------------------*/ void CalPeriodTime(PWM_T *PWM, uint32_t u32Ch) { uint16_t u32Count[4]; uint32_t u32i; uint16_t u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid; /* Clear Capture Falling Indicator (Time A) */ PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH); /* Wait for Capture Falling Indicator */ while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 2); /* Clear Capture Falling Indicator (Time B)*/ PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH); u32i = 0; while(u32i < 4) { /* Wait for Capture Falling Indicator */ while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 2); /* Clear Capture Falling and Rising Indicator */ PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH | PWM_CAPTURE_INT_RISING_LATCH); /* Get Capture Falling Latch Counter Data */ u32Count[u32i++] = PWM_GET_CAPTURE_FALLING_DATA(PWM, u32Ch); /* Wait for Capture Rising Indicator */ while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 2); /* Clear Capture Rising Indicator */ PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_RISING_LATCH); /* Get Capture Rising Latch Counter Data */ u32Count[u32i++] = PWM_GET_CAPTURE_RISING_DATA(PWM, u32Ch); } u16RisingTime = u32Count[1]; u16FallingTime = u32Count[0]; u16HighPeroid = u32Count[1] - u32Count[2]; u16LowPeroid = 0x10000 - u32Count[1]; u16TotalPeroid = 0x10000 - u32Count[2]; printf("\nPWM generate: \nHigh Period=7199 ~ 7201, Low Period=16799 ~ 16801, Total Period=23999 ~ 24001\n"); printf("\nCapture Result: Rising Time = %d, Falling Time = %d \nHigh Period = %d, Low Period = %d, Total Period = %d.\n\n", u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid); if((u16HighPeroid < 7199) || (u16HighPeroid > 7201) || (u16LowPeroid < 16799) || (u16LowPeroid > 16801) || (u16TotalPeroid < 23999) || (u16TotalPeroid > 24001)) printf("Capture Test Fail!!\n"); else printf("Capture Test Pass!!\n"); } void SYS_Init(void) { /*---------------------------------------------------------------------------------------------------------*/ /* Init System Clock */ /*---------------------------------------------------------------------------------------------------------*/ /* Enable Internal RC clock */ CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk; /* Waiting for IRC22M clock ready */ while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk)); /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */ CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLK_S_Msk; CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_HIRC; CLK->CLKDIV &= ~CLK_CLKDIV_HCLK_N_Msk; /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/ CLK->PLLCON |= CLK_PLLCON_PD_Msk; /* Enable external 12MHz XTAL, internal 22.1184MHz */ CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk; /* Enable PLL and Set PLL frequency */ CLK->PLLCON = PLLCON_SETTING; /* Waiting for clock ready */ while(!(CLK->CLKSTATUS & (CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk))); /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */ CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL; /* Enable IP clock */ CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_PWM45_EN_Msk | CLK_APBCLK_PWM67_EN_Msk; /* IP clock source */ CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL; /* IP clock source */ CLK->CLKSEL2 = CLK_CLKSEL2_PWM45_S_HXT | CLK_CLKSEL2_PWM67_S_HXT; /* Reset PWMB channel0~channel3 */ SYS->IPRSTC2 = SYS_IPRSTC2_PWM47_RST_Msk; SYS->IPRSTC2 = 0; /* Update System Core Clock */ /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */ //SystemCoreClockUpdate(); PllClock = PLL_CLOCK; // PLL SystemCoreClock = PLL_CLOCK / 1; // HCLK CyclesPerUs = PLL_CLOCK / 1000000; // For SYS_SysTickDelay() /*---------------------------------------------------------------------------------------------------------*/ /* Init I/O Multi-function */ /*---------------------------------------------------------------------------------------------------------*/ /* Set P3 multi-function pins for UART0 RXD and TXD */ SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0; /* Set P2 multi-function pins for PWMB Channel0~3 */ SYS->P2_MFP = SYS_MFP_P25_PWM5 | SYS_MFP_P26_PWM6; } void UART0_Init(void) { /*---------------------------------------------------------------------------------------------------------*/ /* Init UART */ /*---------------------------------------------------------------------------------------------------------*/ UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(PLL_CLOCK, 115200); UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1; } /*---------------------------------------------------------------------------------------------------------*/ /* Main Function */ /*---------------------------------------------------------------------------------------------------------*/ int32_t main(void) { /* Unlock protected registers */ SYS_UnlockReg(); /* Init System, IP clock and multi-function I/O */ SYS_Init(); /* Lock protected registers */ SYS_LockReg(); /* Init UART0 for printf */ UART0_Init(); printf("+------------------------------------------------------------------------+\n"); printf("| PWM Driver Sample Code |\n"); printf("| |\n"); printf("+------------------------------------------------------------------------+\n"); printf(" This sample code will use PWMB channel 2 to capture\n the signal from PWMB channel 1.\n"); printf(" I/O configuration:\n"); printf(" PWM5(P2.5 PWMB channel 1) <--> PWM6(P2.6 PWMB channel 2)\n\n"); printf("Use PWMB Channel 2(P2.6) to capture the PWMB Channel 1(P2.5) Waveform\n"); while(1) { printf("Press any key to start PWM Capture Test\n"); getchar(); /*--------------------------------------------------------------------------------------*/ /* Set the PWMB Channel 1 as PWM output function. */ /*--------------------------------------------------------------------------------------*/ /* Assume PWM output frequency is 250Hz and duty ratio is 30%, user can calculate PWM settings by follows. duty ratio = (CMR+1)/(CNR+1) cycle time = CNR+1 High level = CMR+1 PWM clock source frequency = __HXT = 12000000 (CNR+1) = PWM clock source frequency/prescaler/clock source divider/PWM output frequency = 12000000/2/1/250 = 24000 (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.) CNR = 23999 duty ratio = 30% ==> (CMR+1)/(CNR+1) = 30% CMR = 7199 Prescale value is 1 : prescaler= 2 Clock divider is PWM_CSR_DIV1 : clock divider =1 */ /* set PWMB channel 1 output configuration */ PWM_ConfigOutputChannel(PWMB, PWM_CH1, 250, 30); /* Enable PWM Output path for PWMB channel 1 */ PWM_EnableOutput(PWMB, 0x2); /* Enable Timer for PWMB channel 1 */ PWM_Start(PWMB, 0x2); /*--------------------------------------------------------------------------------------*/ /* Set the PWMB channel 2 for capture function */ /*--------------------------------------------------------------------------------------*/ /* If input minimum frequency is 250Hz, user can calculate capture settings by follows. Capture clock source frequency = __HXT = 12000000 in the sample code. (CNR+1) = Capture clock source frequency/prescaler/clock source divider/minimum input frequency = 12000000/2/1/250 = 24000 (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.) CNR = 0xFFFF (Note: In capture mode, user should set CNR to 0xFFFF to increase capture frequency range.) */ /* set PWMB channel 2 capture configuration */ PWM_ConfigCaptureChannel(PWMB, PWM_CH2, 166, 0); /* Enable capture falling edge interrupt for PWMB channel 2 */ PWM_EnableCaptureInt(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH); /* Enable PWMB NVIC interrupt */ NVIC_EnableIRQ((IRQn_Type)(PWMB_IRQn)); /* Enable Timer for PWMB channel 2 */ PWM_Start(PWMB, 0x4); /* Enable Capture Function for PWMB channel 2 */ PWM_EnableCapture(PWMB, 0x4); /* Wait until PWMB channel 2 Timer start to count */ while(PWMB->PDR2 == 0); /* Capture the Input Waveform Data */ CalPeriodTime(PWMB, PWM_CH2); /*------------------------------------------------------------------------------------------------------*/ /* Stop PWMB channel 1 (Recommended procedure method 1) */ /* Set PWM Timer loaded value(CNR) as 0. When PWM internal counter(PDR) reaches to 0, disable PWM Timer */ /*------------------------------------------------------------------------------------------------------*/ /* Set PWMB channel 1 loaded value as 0 */ PWM_Stop(PWMB, 0x2); /* Wait until PWMB channel 1 Timer Stop */ while(PWMB->PDR1 != 0); /* Disable Timer for PWMB channel 1 */ PWM_ForceStop(PWMB, 0x2); /* Disable PWM Output path for PWMB channel 1 */ PWM_DisableOutput(PWMB, 0x2); /*------------------------------------------------------------------------------------------------------*/ /* Stop PWMB channel 2 (Recommended procedure method 1) */ /* Set PWM Timer loaded value(CNR) as 0. When PWM internal counter(PDR) reaches to 0, disable PWM Timer */ /*------------------------------------------------------------------------------------------------------*/ /* Disable PWMB NVIC */ NVIC_DisableIRQ((IRQn_Type)(PWMB_IRQn)); /* Set loaded value as 0 for PWMB channel 2 */ PWM_Stop(PWMB, 0x4); /* Wait until PWMB channel 2 current counter reach to 0 */ while(PWMB->PDR2 != 0); /* Disable Timer for PWMB channel 2 */ PWM_ForceStop(PWMB, 0x4); /* Disable Capture Function and Capture Input path for PWMB channel 2*/ PWM_DisableCapture(PWMB, 0x4); /* Clear Capture Interrupt flag for PWMB channel 2*/ PWM_ClearCaptureIntFlag(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH); } } printf("\nPWM generate: \nHigh Period=7199 ~ 7201, Low Period=16799 ~ 16801, Total Period=23999 ~ 24001\n"); printf("\nCapture Result: Rising Time = %d, Falling Time = %d \nHigh Period = %d, Low Period = %d, Total Period = %d.\n\n", u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid); if((u16HighPeroid < 7199) || (u16HighPeroid > 7201) || (u16LowPeroid < 16799) || (u16LowPeroid > 16801) || (u16TotalPeroid < 23999) || (u16TotalPeroid > 24001)) printf("Capture Test Fail!!\n"); else printf("Capture Test Pass!!\n"); 尤其这句,这样得出的结果和示波器抓取的完全不一样?有大神解释一下吗 |
1个回答
这个程序是用来进行PWM捕获的,主要涉及了PWM模块的配置以及捕获计算。关于结果不正确的情况,可能有以下几个原因:
1.示波器和程序采样的时候不一致,导致结果有误差。 2.程序中的计算有问题,需要细心检查代码逻辑。 3.PWM模块的配置不正确,导致捕获数据出错。 你可以按照以下步骤来定位问题: 1.使用示波器采集PWM信号,查看实际的脉宽情况。 2.将采集到的数据和程序计算出的数据进行对比,找出差异。 3.检查程序中的计算逻辑和PWM模块配置是否正确,特别是脉宽计算的公式是否正确。 如果以上步骤都没有找到问题,你可以将相关代码和实际采集数据上传到论坛进行求助,让更多的人参与进来。 |
只有小组成员才能发言,加入小组>>
513 浏览 0 评论
1033 浏览 1 评论
2417 浏览 5 评论
2738 浏览 9 评论
移植了freeRTOS到STMf103之后显示没有定义的原因?
2555 浏览 6 评论
使用eim外接fpga可是端口一点反应都没有有没有大哥指点一下啊
589浏览 9评论
589浏览 7评论
请教大神怎样去解决iMX6Q在linux3.0.35内核上做AP失败的问题呢
700浏览 6评论
568浏览 5评论
607浏览 5评论
GMT+8, 2024-10-3 17:32 , Processed in 1.160106 second(s), Total 79, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
