case 3:
if (MotorA.FlagBEMF == 0) //未检测到过零事件 MotorA.FlagBEMF 过零事件标志 { if (MotorA.PWMticks >= 4)//消磁 { if ( BEMF()) //判断是否过零点 { MotorA.FlagSwitchStep = MotorA.PWMTicksPre >> 4; //延迟30电角度 PWMTicksPre记录的是上一步的时间 MotorA.FlagBEMF = 1; //检测到过零事件,不再检测 } } } else { if (MotorA.FlagSwitchStep == 0) //延迟时刻到 { BLDC_SwitchStep(); //换向 BEMF_Cnt++; //换向计数加1 } else { MotorA.FlagSwitchStep--; //延时时刻未到,自减 } } if (BEMF_Cnt >= 800000) //800000次换向之后,停止 { MotorA.State++; //状态加1 BEMF_Cnt = 0; //换向计数清零 } break; case 4: BLDC_Stop(); break; |
1个回答
The reason why the commutation happens more than 80000 times in three-step commutation of brushless DC motor for back electromotive force detection may depend on several factors, including:
1. The speed and load of the motor: Higher speeds and heavier loads may require more frequent commutation to maintain smooth operation and avoid torque ripple. 2. The accuracy of the back EMF detection circuit: The reliability and precision of the sensor or algorithm used to detect the zero-crossing of back EMF signals can affect the timing and frequency of commutation. 3. The design of the motor and driver: The number of motor poles and the driving algorithm (e.g. sinusoidal vs trapezoidal) can impact the commutation frequency, as well as the choice of PWM frequency and duty cycle. In the given code snippet, it seems that the commutation occurs when the back EMF zero-crossing is not detected for a certain period of time, and the motor is demagnetized if the PWM ticks exceed a threshold. However, without more context or information about the specific motor and circuit used, it is difficult to determine the exact reason for the high commutation frequency. |
只有小组成员才能发言,加入小组>>
3210 浏览 9 评论
2896 浏览 16 评论
3404 浏览 1 评论
8848 浏览 16 评论
3998 浏览 18 评论
9629浏览 3评论
1010浏览 3评论
522浏览 2评论
const uint16_t Tab[10]={0}; const uint16_t *p; p = Tab;//报错是怎么回事?
524浏览 2评论
用NUC131单片机UART3作为打印口,但printf没有输出东西是什么原因?
2251浏览 2评论
GMT+8, 2024-10-4 05:13 , Processed in 1.061984 second(s), Total 81, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
