电子发烧友论坛|
有人可以告诉我如何解决这个问题吗?
代码:全选ketch uses 391,852 bytes (78%) of program storage space. Maximum is 499,696 bytes. Global variables use 53,672 bytes (65%) of dynamic memory, leaving 28,248 bytes for local variables. Maximum is 81,920 bytes. /Users/adambryant/Library/Arduino15/packages/esp8266/tools/esptool/0.4.6/esptool -vv -cd ck -cb 9600 -cp /dev/cu.SLAB_USBtoUART -ca 0x00000 -cf /var/folders/lk/x85468mj7479l_t_44y9q4600000gn/T/build8983361191619901382.tmp/ESP8266Basic.cpp.bin esptool v0.4.6 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de> setting board to ck setting baudrate from 115200 to 9600 setting port from /dev/tty.usbserial to /dev/cu.SLAB_USBtoUART setting address from 0x00000000 to 0x00000000 espcomm_upload_file stat /var/folders/lk/x85468mj7479l_t_44y9q4600000gn/T/build8983361191619901382.tmp/ESP8266Basic.cpp.bin success opening port /dev/cu.SLAB_USBtoUART at 9600 tcgetattr tcsetattr serial open opening bootloader resetting board trying to connect setting character timeout 0 done setting character timeout 1 done espcomm_send_command: sending command header espcomm_send_command: sending command payload trying to connect setting character timeout 0 done setting character timeout 1 done espcomm_send_command: sending command header espcomm_send_command: sending command payload espcomm_send_command: receiving 2 bytes of data espcomm_send_command: receiving 2 bytes of data espcomm_send_command: receiving 2 bytes of data espcomm_send_command: receiving 2 bytes of data espcomm_send_command: receiving 2 bytes of data espcomm_send_command: receiving 2 bytes of data espcomm_send_command: receiving 2 bytes of data espcomm_send_command: receiving 2 bytes of data espcomm_open Uploading 396000 bytes from /var/folders/lk/x85468mj7479l_t_44y9q4600000gn/T/build8983361191619901382.tmp/ESP8266Basic.cpp.bin to flash at 0x00000000 erasing flash size: 060ae0 address: 000000 first_sector_index: 0 total_sector_count: 97 head_sector_count: 16 adjusted_sector_count: 81 adjusted_size: 051000 espcomm_send_command: sending command header espcomm_send_command: sending command payload setting timeout 10000 setting character timeout 100 done setting timeout 1 setting character timeout 1 done espcomm_send_command: receiving 2 bytes of data writing flash warning: espcomm_send_command: didn't receive command response warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed warning: espcomm_send_command: didn't receive command response closing bootloader ajb2k3.wordpress.com 我患有随机失灵突触的坏情况! |
只有小组成员才能发言,加入小组>>
461 浏览 0 评论
982 浏览 0 评论
1702 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1358 浏览 1 评论
1249 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1274浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
942浏览 3评论
2372浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2560浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1067浏览 2评论
/9
GMT+8, 2025-12-10 13:54 , Processed in 1.288737 second(s), Total 67, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
570
