我希望在以 横向 720x1280 运行的 iMX RT1176 上实现尽可能快的图形,即滚动、动画等。我可以参考哪些设置/示例 LVGL 演示?现在我正在使用 MIMXRT1170-EVKB 和 RK055HDMIPI4MA0 5.5" 英寸屏幕。
还使用 FreeRTOS,而不是裸机...... |
1个回答
您可以参考以下设置和示例:
1. LVGL的配置: a. 在lv_conf.h文件中启用VGLite或PXP: /*Software library configuration*/ #define LV_USE_USER_DATA 0 /*Enable/disable the usage of user data*/ #define LV_COLOR_DEPTH 32 /*Color depth: 1/8/16/32*/ #define LV_COLOR_16_SWAP 0 /*Swap the 2 bytes of RGB565 color. Useful if the display works with a pixel pipeline (e.g. HDMI)*/ #define LV_IMG_CACHE_DEF_SIZE 1 /*Default cache size in image decoder (in pixel count)*/ #define LV_IMG_CACHE_LARGE_SIZE 2 /*Large cache size in image decoder (in pixel count)*/ #define LV_DPI 130 /*Set a default DPI for every object*/ /* Use PXP (Pixel Processing Pipeline) as LVGL's display driver */ #define LV_COLOR_TRANSP LV_COLOR_MAKE(0, 0, 0) /*The color of transparent pixels*/ #define LV_COLOR_LSHIFT 16 /*Bit shift of Red part in LV_COLOR_DEPTH*/ #define LV_COLOR_RSHIFT 0 /*Bit shift of Red part in LV_COLOR_DEPTH*/ #define LV_COLOR_GSHIFT 8 /*Bit shift of Green part in LV_COLOR_DEPTH*/ #define LV_COLOR_BSHIFT 0 /*Bit shift of Blue part in LV_COLOR_DEPTH*/ #define LV_PXP_DISPLAY_DEVICE disp_dev /*Set PXP display device*/ #define LV_PXP_DISPLAY_BUFFER_COUNT 2 /*The number of frame buffers*/ #define LV_PXP_DISPLAY_WIDTH 720 /*The width of the display*/ #define LV_PXP_DISPLAY_HEIGHT 1280 /*The height of the display*/ #define LV_PXP_DISPLAY_INPUT_FORMAT PXP_INPUT_FORMAT_RGB_888 /*The input format of PXP*/ /* Use VGLite as LVGL's display driver */ #define LV_HOR_RES_MAX 720 /*Set maximum horizontal resolution*/ #define LV_VER_RES_MAX 1280 /*Set maximum vertical resolution*/ #define LV_VDB_SIZE (LV_HOR_RES_MAX * LV_VER_RES_MAX / 8) /*Set Virtual Display Buffer size*/ #define LV_VDB_DOUBLE_BUFFERED 1 /*Enable double buffering*/ #define LV_VDB_TRUE_COLOR_SUPPORT 0 /*Disable true color support*/ ... #define LV_COLOR_DEPTH 16 /*Color depth: 1/8/16/32*/ #define LV_DISPLAY_DRIVER lv_disp_drv_t pxp_drv; lv_disp_drv_t vglite_drv; ... #if USE_PXP_DISPLAY LV_LAYER_DEF(lvgl_disp_buf_pxp, NULL, LV_PXP_DISPLAY_WIDTH, LV_PXP_DISPLAY_HEIGHT, LV_LAYER_TOP, LV_COLOR_DEPTH); static pxp_device_t disp_dev = { .input_format = LV_PXP_DISPLAY_INPUT_FORMAT, .width = LV_PXP_DISPLAY_WIDTH, .height = LV_PXP_DISPLAY_HEIGHT, .buffer_count = LV_PXP_DISPLAY_BUFFER_COUNT, .pxp_irq = LV_PXP_IRQ, .pixel_addr = PXP_OUTPUT_ADDR }; static void pxp_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p) { pxp_process_frame(area->x1, area->y1, area->x2, area->y2, (uint8_t*)color_p, 0, LV_PXP_DISPLAY_INPUT_FORMAT, PXP_OUTPUT_ADDR); lv_disp_flush_ready(drv); } #endif /* USE_PXP_DISPLAY */ 2. 示例程序: 使用LVGL的示例程序可以帮助您快速理解和使用LVGL。您可以尝试运行以下示例程序: a. lv_demo_benchmark: 这个示例会运行LVGL的主要特性,例如各种基本组件、动画和滚动。您可以通过观察控制台输出,了解工作负载和帧速率。 b. lv_demo_keypad_encoder: 这个示例会展示如何使用LVGL的按键和编码器输入控件。 c. lv_demo_music: 这个示例会展示如何使用LVGL的图像和动画来创建一个音乐播放器UI。 d. lv_demo_printer: 这个示例会展示如何使用LVGL的图像、文本和滚动来创建一个打印机UI。 3. FreeRTOS使用: 您可以参考LVGL Github库中的FreeRTOS示例,这些示例会展示如何在RTOS环境中使用LVGL。对于iMX RT1176,您需要确保正确配置FreeRTOS内存分配器和时钟。 希望这些信息对您有所帮助。 |
只有小组成员才能发言,加入小组>>
2139个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37409 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6802 浏览 1 评论
7831 浏览 1 评论
7665 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5089 浏览 0 评论
1584浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1224浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
769浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
760浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
704浏览 1评论
/9
GMT+8, 2025-12-14 22:31 , Processed in 0.995735 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
965
