电子发烧友论坛|
用下面网页的教程安装流程,安装成功,
===================================================================================================== 使用ESP-IDF launch GUI configation tool失败,停留在 ESP-IDF :Menuconfig: loading initial values.. 提示窗口。 输出显示: ---------------------------ERROR-------------------------- CMake Error at CMakeLists.txt:9 (string): -----------------------END OF ERROR----------------------- ---------------------------ERROR-------------------------- string no output variable specified CMake Error at CMakeLists.txt:13 (string): string begin index: 9 is out of range 0 - 0 CMake Error at CMakeLists.txt:14 (string): string sub-command STRIP requires two arguments. CMake Error at CMakeLists.txt:15 (string): string no output variable specified silence:0 sdkconfig:C:/ESP/esp-at/module_config/module__default/sdkconfig.defaults -----------------------END OF ERROR----------------------- ---------------------------ERROR-------------------------- CMake Error at CMakeLists.txt:49 (include): -----------------------END OF ERROR----------------------- ---------------------------ERROR-------------------------- include could not find load file: -----------------------END OF ERROR----------------------- ---------------------------ERROR-------------------------- C:/ESP/esp-at/esp-idf/tools/cmake/project.cmake -----------------------END OF ERROR----------------------- -- The C compiler identification is unknown ===================================================================================================== 使用ESP-IDE Build project,也失败,终端窗口提示 > Executing task: cmake -G Ninja .. < CMake Error at CMakeLists.txt:9 (string): string no output variable specified CMake Error at CMakeLists.txt:13 (string): string begin index: 9 is out of range 0 - 0 CMake Error at CMakeLists.txt:14 (string): string sub-command STRIP requires two arguments. CMake Error at CMakeLists.txt:15 (string): string no output variable specified silence:0 sdkconfig:C:/ESP/esp-at/module_config/module__default/sdkconfig.defaults CMake Error at CMakeLists.txt:49 (include): include could not find load file: C:/ESP/esp-at/esp-idf/tools/cmake/project.cmake -- The C compiler identification is unknown -- The CXX compiler identification is unknown CMake Error at CMakeLists.txt:51 (project): No CMAKE_C_COMPILER could be found. Tell CMake where to find the compiler by setting either the environment variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to the compiler, or to the compiler name if it is in the PATH. CMake Error at CMakeLists.txt:51 (project): No CMAKE_CXX_COMPILER could be found. Tell CMake where to find the compiler by setting either the environment variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path to the compiler, or to the compiler name if it is in the PATH. -- Configuring incomplete, errors occurred! See also "C:/ESP/esp-at/build/CMakeFiles/CMakeOutput.log". See also "C:/ESP/esp-at/build/CMakeFiles/CMakeError.log". 终端进程“C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake -G Ninja ..”已终止,退出代码: 1。 终端将被任务重用,按任意键关闭。 ========================================================================= command 编译,使用 ./build.py menuconfig 命令也无法成功。 请问是不是当前版本的安装流程不同? 哪里有对应当前版本 esp-at 使用 vscode 的esp-idf扩展编译的教程? |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 05:49 , Processed in 0.564444 second(s), Total 68, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
479
