Thorlabs, a vertically integrated photonics products manufacturer serving the laser and electro-optics research market, is seeking a talented, experienced FPGA design and verification engineer. This position will be located in the Thorlabs R&D center in Shanghai, China, and lead the development and commercialization of a variety of FPGA-based high-speed electronic designs for Thorlabs products.
Thorlabs是一家垂直整合光子学产品制造商,服务于激光和光电研究市场,现招聘有才华、经验丰富的FPGA设计和验证工程师。该职位工作地点位于索雷博上海的研发中心,负责公司产品中一系列基于FPGA的高速电子设计的开发和量产支持。
Responsibilities:
- Design and support of FPGA-based solutions for electro-optical systems.
完成基于FPGA的光电模块和产品的开发和技术支持工作
- FPGA programming in VHDL and/or Verilog; Participates in cross-functional new product development teams as an FPGA/Digital electronics design expert.
使用 VHDL和/或Verilog进行FPGA开发;在跨专业和部门的产品开发团队中承担FPGA和数字电子设计工作
- Development of FPGA including coding, simulation, synthesis, test and functional verification, timing closure, and documentation. Emphasis on high-speed hardware data path, memory controllers, USB3, SerDes and PCIe interface.
具体的FPGA开发工作包括:编码,仿真,综合,测试,功能验证,时序收敛,编写文档。工作内容包括高速数字电路、存储控制器、USB3控制器、PCIe接口等设计工作
- Support electronic and electrical component, circuit, and board design for high-speed digital systems.
配合完成高速数字系统的电子电气元件选型、验证、电路和电路板设计
- Participate in lab testing of prototype imaging equipment and address FPGA performance improvements.
配合进行成像系统设备的实验室调试测试工作
Knowledge and Skills:
- Demonstrated strong VHDL and/or Verilog skills; logical and physical design, timing closure.
精通VHDL和/或Verilog开发,数字逻辑电路设计,时序收敛技巧
- Implementations of high-speed (GHz) SerDes, DDR3, FFT, digital filtering, and interfacing with AD/DA, camera chips, etc. Using logic design techniques.
能够基于FPGA实现高速(GHz) SerDes, DDR3控制器, FFT算法,数字滤波器,AD/DA接口,图像传感器接口等等
- Solid understanding of data movement and AXI interfaces; Experience with High-speed serial interface IPs (e.g. PCIe interface, contemporary high speed ADC/DAC interfaces, DDR3, etc.).
精通数据传输和接口技术,如AXI接口,高速数据接口(比如PCIe接口,高速AD/DA接口,DDR3接口)
- Familiarity with high-speed (GHz) PCB design techniques
熟悉高速 (GHz) PCB 设计技术
- Demonstrated ability to bring FPGA subsystem from concept through release to manufacturing
能够完成FPGA子系统的概念设计到量产发布全过程相关工作(包括原理样机、工程样机、量产产品定型等)
- Working knowledge of signal processing algorithms, host architectures, and host data storage devices and optimization techniques
熟悉信号处理算法、数字电路产品架构、数据存储产品、各种优化技能
- Experience with laboratory instrumentation such as function generators, oscilloscopes, network analyzers, and logic analyzers
熟练使用各种实验室设备,包括函数发生器、示波器、网络分析仪和逻辑分析仪
- Design for Test and Manufacturability
熟悉面向测试和生产的设计,保证产品具备良好的可测试性、可制造性
- Board-level, production test development and implementation
能够对电路板、模块、整机进行测试、调试、改进
- Excellent communication skills in verbal and written English
英语口语和书面表达流利
- Strong ability to work well in a group atmosphere, and comply with high-quality standards
能够参与团队合作,服从团队需要,高质量地实现团队目标
- Experience with Xilinx (Zynq) and/or Altera SOC products and development tools.
具有Xilinx (Zynq) 和/或 Altera SOC 产品和开发工具的使用经验
- Experience with implementation and optimization of Image processing algorithms in FPGA logic.
具有在FPGA上实现和优化图像处理算法的经验
- Mixed Signal PCB design is a plus.
熟悉混合信号PCB设计者优先
