电子发烧友论坛|
大家好,我对 v4l2-ctl 设置有疑问
眼镜: 处理器:IMX8MM, 内核版本:5.10.72 (hardknott yocto) 相机传感器:r MIPI-CSI OS02G10 总线: V4L2_MBUS_CSI2_DPHY 格式:RAW10 / BG10 ( SBGGR10) /1920x1080 问题: OS02G10 的驱动程序已实现类似于 ov5640 的 V4L2 控制基础结构。它使用子设备概念。 V4L2 无法处理已实现的控件,例如: root@user:~# v4l2-ctl --verbose -L VIDIOC_QUERYCAP: ok root@user:~# v4l2-ctl --set-ctrl brightness=192 unknown control 'brightness' 这是一个众所周知的问题,但希望有人能帮助我更快地找到解决方案。 如何解决? root@user:~# v4l2-ctl --list-devices i.MX6S_CSI (platform:32e20000.csi_bridge): /dev/video0 vsi_v4l2dec (platform:vsi_v4l2dec): /dev/video2 vsi_v4l2enc (platform:vsi_v4l2enc): /dev/video1 此处的所有其他详细信息: root@user:~# v4l2-compliance v4l2-compliance SHA: not available [ 334.897958] unknown pixelformat:'▒▒▒▒' [ 334.902049] mx6s-csi 32e20000.csi_bridge: Fourcc format (0xffffffff) invalid. [ 334.912066] unknown pixelformat:' ' [ 334.918660] mx6s-csi 32e20000.csi_bridge: Fourcc format (0x00000000) invalid. Compliance test for mx6s-csi device /dev/video0: Driver Info: Driver name : mx6s-csi Card type : i.MX6S_CSI Bus info : platform:32e20000.csi_bridge Driver version : 5.10.72 Capabilities : 0x84200001 Video Capture Streaming Extended Pix Format Device Capabilities Device Caps : 0x04200001 Video Capture Streaming Extended Pix Format Required ioctls: test VIDIOC_QUERYCAP: OK Allow for multiple opens: test second /dev/video0 open: OK test VIDIOC_QUERYCAP: OK fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-compliance.cpp(739): prio != match test VIDIOC_G/S_PRIORITY: FAIL test for unlimited opens: OK test invalid ioctls: OK Debug ioctls: test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported) test VIDIOC_LOG_STATUS: OK (Not Supported) Input ioctls: test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported) test VIDIOC_G/S_FREQUENCY: OK (Not Supported) test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported) test VIDIOC_ENUMAUDIO: OK (Not Supported) fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-input-output.cpp(385): std == 0 fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-input-output.cpp(455): invalid attributes for input 0 test VIDIOC_G/S/ENUMINPUT: FAIL test VIDIOC_G/S_AUDIO: OK (Not Supported) Inputs: 0 Audio Inputs: 0 Tuners: 0 Output ioctls: test VIDIOC_G/S_MODULATOR: OK (Not Supported) test VIDIOC_G/S_FREQUENCY: OK (Not Supported) test VIDIOC_ENUMAUDOUT: OK (Not Supported) test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported) test VIDIOC_G/S_AUDOUT: OK (Not Supported) Outputs: 0 Audio Outputs: 0 Modulators: 0 Input/Output configuration ioctls: test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported) test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported) test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported) test VIDIOC_G/S_EDID: OK (Not Supported) Control ioctls: test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK (Not Supported) test VIDIOC_QUERYCTRL: OK (Not Supported) test VIDIOC_G/S_CTRL: OK (Not Supported) test VIDIOC_G/S/TRY_EXT_CTRLS: OK (Not Supported) test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK (Not Supported) test VIDIOC_G/S_JPEGCOMP: OK (Not Supported) Standard Controls: 0 Private Controls: 0 Format ioctls: fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(312): Video Capture cap set, but no Video Capture formats defined test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1308): expected EINVAL, but got 19 when getting parms for buftype 1 test VIDIOC_G/S_PARM: FAIL test VIDIOC_G_FBUF: OK (Not Supported) fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(441): fmt.type != type test VIDIOC_G_FMT: FAIL fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(716): Video Capture is valid, but no TRY_FMT was implemented test VIDIOC_TRY_FMT: FAIL warn: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1099): S_FMT cannot handle an invalid pixelformat. warn: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1100): This may or may not be a problem. For more information see: warn: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1101) fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1115): S_FMT cannot handle an invalid format [ 335.268377] ------------[ cut here ]------------ [ 335.275401] WARNING: CPU: 0 PID: 739 at drivers/media/common/videobuf2/videobuf2-core.c:806 vb2_core_reqbufs+0x140/0x420 [ 335.286266] Modules linked in: fsl_jr_uio caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine rng_core authenc libdes crct10dif_ce secvio caam error [ 335.286306] virtio_rpmsg_bus rpmsg_ns imx_rproc imx_rpmsg_tty fuse [ 335.307098] CPU: 0 PID: 739 Comm: v4l2-compliance Not tainted 5.10.72-lts-5.10.y+ge4c14755b1cb #1 [ 335.315970] Hardware name: user i.MX8MM Base Board (DT) [ 335.321199] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--) [ 335.327209] pc : vb2_core_reqbufs+0x140/0x420 [ 335.331566] lr : vb2_core_reqbufs+0x108/0x420 [ 335.335921] sp : ffff80001c5e3b30 [ 335.339235] x29: ffff80001c5e3b30 x28: ffff800011339508 [ 335.344549] x27: 00000000c0145608 x26: ffff80001c5e3d68 [ 335.349866] x25: ffff80001c5e3d68 x24: ffff00000448c178 [ 335.355180] x23: 0000000000000001 x22: ffff80001c5e3d68 [ 335.360494] x21: ffff000008b00000 x20: 0000000000000000 [ 335.365808] x19: ffff00000448c110 x18: 0000000000000000 [ 335.371122] x17: 0000000000000000 x16: 0000000000000000 [ 335.376437] x15: 0000000000000000 x14: 0000000000000000 [ 335.381751] x13: 0000000000000000 x12: 0000000000000000 [ 335.387065] x11: 0000000000000000 x10: 0000000000000000 [ 335.392382] x9 : 0000000000000000 x8 : 0000ffff00000001 [ 335.397696] x7 : 0000000000000000 x6 : 0000000000000000 [ 335.403010] x5 : ffff000004187010 x4 : 0000000000000000 [ 335.408323] x3 : 0000000000000001 x2 : ffff80001c5e3b84 [ 335.413637] x1 : ffff80001c5e3b8c x0 : ffff80001c5e3b88 [ 335.418952] Call trace: [ 335.421401] vb2_core_reqbufs+0x140/0x420 [ 335.425417] vb2_reqbufs+0x58/0x70 [ 335.428823] mx6s_vidioc_reqbufs+0x40/0x7c [ 335.432921] v4l_reqbufs+0x4c/0x60 [ 335.436322] __video_do_ioctl+0x180/0x3e4 [ 335.440331] video_usercopy+0x1a0/0x450 [ 335.444167] video_ioctl2+0x18/0x24 [ 335.447659] v4l2_ioctl+0x44/0x64 [ 335.450978] __arm64_sys_ioctl+0xa8/0xf0 [ 335.454903] el0_svc_common.constprop.0+0x78/0x1c4 [ 335.459694] do_el0_svc+0x24/0x8c [ 335.463011] el0_svc+0x14/0x20 [ 335.466067] el0_sync_handler+0x1a4/0x1b0 [ 335.470077] el0_sync+0x180/0x1c0 [ 335.473391] ---[ end trace 70273d2f610c9f9a ]--- test VIDIOC_S_FMT: FAIL test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported) fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1439): doioctl(node, VIDIOC_G_SELECTION, &sel) != EINVAL test Cropping: FAIL fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1439): doioctl(node, VIDIOC_G_SELECTION, &sel) != EINVAL test Composing: FAIL fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1712): doioctl(node, VIDIOC_S_FMT, &fmt) fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-formats.cpp(1861): doioctl(node, VIDIOC_S_FMT, &fmt) test Scaling: FAIL Codec ioctls: test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported) test VIDIOC_G_ENC_INDEX: OK (Not Supported) test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported) Buffer ioctls: fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-buffers.cpp(612): q.reqbufs(node, 1) test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-buffers.cpp(749): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_MMAP support is missing or malfunctioning. fail: ../../../v4l-utils-1.20.0/utils/v4l2-compliance/v4l2-test-buffers.cpp(750): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_MMAP support is missing, probably due to earlier failing format tests. test VIDIOC_EXPBUF: OK (Not Supported) test Requests: OK (Not Supported) Total for mx6s-csi device /dev/video0: 45, Succeeded: 34, Failed: 11, Warnings: 3 |
相关推荐 |
只有小组成员才能发言,加入小组>>
2140个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37411 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6803 浏览 1 评论
7835 浏览 1 评论
7667 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5091 浏览 0 评论
1594浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1230浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
772浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
765浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
709浏览 1评论
/9
GMT+8, 2025-12-17 13:29 , Processed in 0.526465 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
406
