ESP-ROM:esp32s3-20210327
Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x2b (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0108,len:0x1854 load:0x403b6000,len:0xb74 load:0x403ba000,len:0x3014 entry 0x403b61ec I (25) boot: ESP-IDF v4.4-beta1-2-gdf0929009a 2nd stage bootloader I (25) boot: compile time 11:30:57 I (25) boot: chip revision: 0 I (28) qio_mode: Enabling default flash chip QIO I (33) boot.esp32s3: Boot SPI Speed : 80MHz I (38) boot.esp32s3: SPI Mode : QIO I (43) boot.esp32s3: SPI Flash Size : 16MB I (48) boot: Enabling RNG early entropy source... W (53) bootloader_random: RNG for ESP32-S3 not currently supported I (60) boot: Partition Table: I (63) boot: ## Label Usage Type ST Offset Length I (71) boot: 0 factory factory app 00 00 00010000 00200000 I (78) boot: 1 model Unknown data 01 82 00210000 0050c000 I (86) boot: End of partition table I (90) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=92010h (598032) map I (189) esp_image: segment 1: paddr=000a2038 vaddr=3fca2bd0 size=0520ch ( 21004) load I (193) esp_image: segment 2: paddr=000a724c vaddr=40378000 size=08dcch ( 36300) load I (202) esp_image: segment 3: paddr=000b0020 vaddr=42000020 size=7f0b8h (520376) map I (282) esp_image: segment 4: paddr=0012f0e0 vaddr=40380dcc size=11dfch ( 73212) load I (296) esp_image: segment 5: paddr=00140ee4 vaddr=50000000 size=00010h ( 16) load I (307) boot: Loaded app from partition at offset 0x10000 I (307) boot: Disabling RNG early entropy source... W (308) bootloader_random: RNG for ESP32-S3 not currently supported I (326) opi psram: vendor id : 0x0d (AP) I (326) opi psram: dev id : 0x02 (generation 3) I (326) opi psram: density : 0x03 (64 Mbit) I (330) opi psram: good-die : 0x01 (Pass) I (334) opi psram: Latency : 0x01 (Fixed) I (339) opi psram: VCC : 0x01 (3V) I (344) opi psram: SRF : 0x01 (Fast Refresh) I (349) opi psram: BurstType : 0x01 (Hybrid Wrap) I (355) opi psram: BurstLen : 0x01 (32 Byte) I (360) opi psram: Readlatency : 0x02 (10 cycles@Fixed) I (366) opi psram: DriveStrength: 0x00 (1/1) W (371) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version. I (381) spiram: Found 64MBit SPI RAM device I (386) spiram: SPI RAM mode: sram 80m I (390) spiram: PSRAM initialized, cache is in normal (1-core) mode. I (397) cpu_start: Pro cpu up. I (401) cpu_start: Starting app cpu, entry point is 0x4037955c 0x4037955c: call_start_cpu1 at D:/STM32F030F4/esp/esp-idf/esp-skainet/esp-skainet/esp-idf/components/esp_system/port/cpu_start.c:156 I (0) cpu_start: App cpu up. I (696) spiram: SPI SRAM memory test OK W (696) rtcinit: calibration efuse version does not match, set default version: 0 I (708) cpu_start: Pro cpu start user code I (708) cpu_start: cpu freq: 240000000 I (708) cpu_start: Application information: I (711) cpu_start: Project name: speech_commands_recognition I (718) cpu_start: App version: v0.3.0-137-gaa36390-dirty I (724) cpu_start: Compile time: Nov 18 2022 11:30:41 I (730) cpu_start: ELF file SHA256: 345501c6b66d9801... I (736) cpu_start: ESP-IDF: v4.4-beta1-2-gdf0929009a I (743) heap_init: Initializing. RAM available for dynamic allocation: I (750) heap_init: At 3FCA9F18 len 000360E8 (216 KiB): D/IRAM I (756) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (763) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM I (769) spiram: Adding pool of 8192K of external SPI memory to heap allocator I (777) spi_flash: detected chip: gd I (781) spi_flash: flash io: qio I (786) sleep: Configure to isolate all GPIO pins in sleep state I (792) sleep: Enable automatic switching of GPIO sleep configuration I (799) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (830) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations I (830) MODEL_LOADER: Initializing models from SPIFFS, partition label: model I (1160) MODEL_LOADER: Partition size: total: 4857101, used: 2085308 I (1420) I2S: DMA Malloc info, datalen=blocksize=1280, dma_buf_count=6 I (1420) I2S: I2S1, MCLK output by GPIO20 I (1420) I2S: DMA Malloc info, datalen=blocksize=320, dma_buf_count=6 I (1430) I2S: I2S0, MCLK output by GPIO42 I (1440) board: Detected codec at 0x40. Name : ES7210 I (1440) board: Detected codec at 0x18. Name : ES8311 I (1460) ES7210: ES7210 in Slave mode I (1460) ES7210: Enable ES7210_INPUT_MIC1 I (1460) ES7210: Enable ES7210_INPUT_MIC2 I (1460) ES7210: Enable ES7210_INPUT_MIC3 I (1470) ES7210: Enable ES7210_INPUT_MIC4 I (1480) ES7210: The ES7210_CLOCK_OFF_REG01 value before stop is 0 I (1480) ES7210: Enable ES7210_INPUT_MIC1 I (1480) ES7210: Enable ES7210_INPUT_MIC2 I (1490) ES7210: Enable ES7210_INPUT_MIC3 I (1490) ES7210: Enable ES7210_INPUT_MIC4 I (1500) DRV8311: ES8311 in Slave mode I (1510) gpio: GPIO[38]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 I (1510) AFE_SR: afe interface for speech recognition I (1520) AFE_SR: AFE version: SR_V220727 I (1520) AFE_SR: Initial auido front-end, total channel: 3, mic num: 2, ref num: 1 I (1530) AFE_SR: aec_init: 1, se_init: 1, vad_init: 1 I (1530) AFE_SR: wakenet_init: 1 model_name: wn9_hilexin model_data: /srmodel/wn9_hilexin/wn9_data MC Quantized wakenet9: wakenet9_v1h24_hilexin_3_0.608_0.615, tigger:v3, mode:2, p:0, (Oct 9 2022 17:21:08) I (2440) AFE_SR: wake num: 3, mode: 0, (Oct 12 2022 19:13:45) multinet:mn4_cn I (2440) MN: model_name: mn4_cn model_data: /srmodel/mn4_cn/mn4_cn_data I (4560) MN: SINGLE_RECOGNITION: V4.5 CN; core: 0; (Oct 12 2022 19:13:44) esp_mn_commands_update_from_sdkconfig I (4560) MN_COMMAND: ---------------------SPEECH COMMANDS--------------------- I (4570) MN_COMMAND: Command ID0, phrase ID0: da kai kong tiao I (4570) MN_COMMAND: Command ID1, phrase ID1: guan bi kong tiao I (4580) MN_COMMAND: Command ID2, phrase ID2: zeng da feng su I (4590) MN_COMMAND: Command ID3, phrase ID3: jian xiao feng su I (4590) MN_COMMAND: Command ID4, phrase ID4: sheng gao yi du I (4600) MN_COMMAND: Command ID5, phrase ID5: jiang di yi du I (4610) MN_COMMAND: Command ID6, phrase ID6: zhi re mo shi I (4610) MN_COMMAND: Command ID6, phrase ID7: zhi le mo shi I (4620) MN_COMMAND: Command ID7, phrase ID8: zhi leng mo shi I (4630) MN_COMMAND: Command ID7, phrase ID9: zhi ren mo shi I (4630) MN_COMMAND: Command ID7, phrase ID10: zhi len mo shi I (4640) MN_COMMAND: Command ID8, phrase ID11: jie neng mo shi I (4640) MN_COMMAND: Command ID9, phrase ID12: guan bi jie neng mo shi I (4650) MN_COMMAND: Command ID10, phrase ID13: chu shi mo shi I (4660) MN_COMMAND: Command ID11, phrase ID14: guan bi chu shi mo shi I (4670) MN_COMMAND: Command ID12, phrase ID15: shui mian mo shi I (4670) MN_COMMAND: Command ID13, phrase ID16: guan bi shui mian mo shi I (4680) MN_COMMAND: Command ID14, phrase ID17: ding shi yi xiao shi I (4690) MN_COMMAND: Command ID15, phrase ID18: ding shi liang xiao shi I (4690) MN_COMMAND: Command ID16, phrase ID19: zui da feng su I (4700) MN_COMMAND: Command ID16, phrase ID20: zui gao feng su I (4710) MN_COMMAND: --------------------------------------------------------- ------------detect start------------ WAKEWORD DETECTED AFE_FETCH_CHANNEL_VERIFIED, channel index: 2 assert failed: dl_matrixq_slice dl_lib_matrixq.c:483 (in->flags & DL_MF_FOREIGNDATA) Backtrace:0x40379e86:0x3fce96b00x4038a3ad:0x3fce96d0 0x40390961:0x3fce96f0 0x420212da:0x3fce9810 0x42022e1e:0x3fce9830 0x42021e5e:0x3fce9890 0x420153cb:0x3fce98c0 0x42015a4b:0x3fce98f0 0x4200789e:0x3fce9910 0x4038d51d:0x3fce9940 0x40379e86: panic_abort at D:/STM32F030F4/esp/esp-idf/esp-skainet/esp-skainet/esp-idf/components/esp_system/panic.c:402 0x4038a3ad: esp_system_abort at D:/STM32F030F4/esp/esp-idf/esp-skainet/esp-skainet/esp-idf/components/esp_system/esp_system.c:121 0x40390961: __assert_func at D:/STM32F030F4/esp/esp-idf/esp-skainet/esp-skainet/esp-idf/components/newlib/assert.c:85 0x420212da: dl_matrixq_slice at /home/sunxiangyu/aishare/master/esp_sr_lib/build/../components/dl_lib/dl_lib_matrixq.c:483 0x42022e1e: dl_convq16_lstm_layer_s3 at /home/sunxiangyu/aishare/master/esp_sr_lib/build/../components/dl_lib/dl_lib_convq_queue_s3.c:960 (discriminator 2) 0x42021e5e: dl_convq16_lstm_layer at /home/sunxiangyu/aishare/master/esp_sr_lib/build/../components/dl_lib/dl_lib_convq_queue.c:620 0x420153cb: multinet4_model_run_step2 at /home/sunxiangyu/aishare/master/esp_sr_lib/build/../components/multinet/multinet4_single_quantized_cn.c:1141 0x42015a4b: model_detect at /home/sunxiangyu/aishare/master/esp_sr_lib/build/../components/multinet/multinet4_single_quantized_cn.c:1607 0x4200789e: detect_Task at D:STM32F030F4espesp-idfesp-skainetesp-skainetexamplescn_speech_commands_recognitionbuild/../main/main.c:115 0x4038d51d: vPortTaskWrapper at D:/STM32F030F4/esp/esp-idf/esp-skainet/esp-skainet/esp-idf/components/freertos/port/xtensa/port.c:130 |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 00:12 , Processed in 0.775198 second(s), Total 68, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
723
