电子发烧友论坛|
I (0) cpu_start: App cpu up.
I (927) heap_init: Initializing. RAM available for dynamic allocation: I (934) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (940) heap_init: At 3FFB2BC0 len 0002D440 (181 KiB): DRAM I (946) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (952) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (959) heap_init: At 4008D8EC len 00012714 (73 KiB): IRAM I (965) cpu_start: Pro cpu start user code I (982) spi_flash: detected chip: gd I (982) spi_flash: flash io: qio I (982) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (996) example_asr_keywords: Initialize SR wn handle Quantized wakeNet5: wakeNet5X3_v2_nihaoxiaoxin_6_0.95_0.85, mode:0 (Oct 14 2020 16:26:17) I (1009) example_asr_keywords: keywords: nihaoxiaoxin (index = 1) Fail: index is out of range, the min index is 1, the max index is 1I (1016) example_asr_keywords: keywords_num = 1, threshold = 0.000000, sample_rate = 16000, chunksize = 480, sizeof_uint16 = 2 WARNING: Sample length must less than 5000ms in the SINGLE_RECOGNITION mode SINGLE_RECOGNITION: 2_0 MN1_4; core: 0; (May 15 2020 14:50:27) SHIFT: 8, 12, 17, 17, 19, 17, 6, 16, 15, 14, I (1059) example_asr_keywords: keywords_num = 166 , sample_rate = 16000, chunksize = 480, sizeof_uint16 = 2 I (1061) example_asr_keywords: [ 1 ] Start codec chip I (1567) example_asr_keywords: [ 2.0 ] Create audio pipeline for recording I (1567) example_asr_keywords: [ 2.1 ] Create i2s stream to read audio data from codec chip I (1588) example_asr_keywords: [ 2.3 ] Create raw to receive data I (1588) example_asr_keywords: [ 3 ] Register all elements to audio pipeline I (1592) example_asr_keywords: [ 4 ] Link elements together [codec_chip]-->i2s_stream-->raw-->[SR] W (1703) I2C_BUS: i2c_bus_create:57: I2C bus has been already created, [port:0] ----------------------------- ESP Audio Platform ----------------------------- | | | ESP_AUDIO-v1.7.0-31-g5b8f999-3072767-09be8fe | | Compile date: Oct 14 2021-11:00:34 | ------------------------------------------------------------------------------ I (1768) example_asr_keywords: esp_audio instance is:0x3ffd0b50 I (1768) example_asr_keywords: [ 5 ] Start audio_pipeline |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 06:53 , Processed in 0.697592 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
606
