ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0018,len:4 load:0x3fff001c,len:7376 ho 0 tail 12 room 4 load:0x40078000,len:14904 ho 0 tail 12 room 4 load:0x40080400,len:4988 entry 0x40080708 I (70) boot: Chip Revision: 1 I (75) boot_comm: chip revision: 1, min. bootloader chip revision: 0 I (43) boot: ESP-IDF v4.0.2 2nd stage bootloader I (43) boot: compile time 09:59:16 I (43) boot: Enabling RNG early entropy source... I (48) qio_mode: Enabling default flash chip QIO I (53) boot: SPI Speed : 80MHz I (57) boot: SPI Mode : QIO I (61) boot: SPI Flash Size : 4MB I (65) boot: Partition Table: I (69) boot: ## Label Usage Type ST Offset Length I (76) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (83) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (91) boot: 2 factory factory app 00 00 00010000 00300000 I (98) boot: End of partition table I (103) boot_comm: chip revision: 1, min. application chip revision: 0 I (110) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1ff4f8 (2 094328) map I (687) esp_image: segment 1: paddr=0x0020f520 vaddr=0x3ffb0000 size=0x00af0 ( 2800) load I (688) esp_image: segment 2: paddr=0x00210018 vaddr=0x400d0018 size=0x42820 (27 2416) map I (768) esp_image: segment 3: paddr=0x00252840 vaddr=0x3ffb0af0 size=0x016cc ( 5836) load I (770) esp_image: segment 4: paddr=0x00253f14 vaddr=0x40080000 size=0x00400 ( 1024) load I (775) esp_image: segment 5: paddr=0x0025431c vaddr=0x40080400 size=0x0d224 ( 5 3796) load I (809) boot: Loaded app from partition at offset 0x10000 I (810) boot: Disabling RNG early entropy source... I (810) cpu_start: Pro cpu up. I (814) cpu_start: Application information: I (818) cpu_start: Project name: speech_recognition_example I (825) cpu_start: App version: v2.2-107-ge5438f4 I (831) cpu_start: Compile time: Apr 22 2021 11:29:57 I (837) cpu_start: ELF file SHA256: e9b9cab89463b466... I (843) cpu_start: ESP-IDF: v4.0.2 I (848) cpu_start: Starting app cpu, entry point is 0x40081320 I (0) cpu_start: App cpu up. I (858) heap_init: Initializing. RAM available for dynamic allocation: I (865) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (871) heap_init: At 3FFB3350 len 0002CCB0 (179 KiB): DRAM I (877) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (884) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (890) heap_init: At 4008D624 len 000129DC (74 KiB): IRAM I (896) cpu_start: Pro cpu start user code I (913) spi_flash: detected chip: gd I (914) spi_flash: flash io: qio W (914) spi_flash: Detected size(8192k) larger than the size in the binary image header(4096k). Using the size in the binary image header. I (925) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (940) example_asr_keywords: Initialize SR wn handle Quantized wakeNet5: wakeNet5X3_v2_nihaoxiaozhi_6_0.955_0.90, mode:0 (Oct 14 2020 16:26:17) I (953) example_asr_keywords: keywords: nihaoxiaozhi (index = 1) Fail: index is out of range, the min index is 1, the max index is 1I (960) examp le_asr_keywords: keywords_num = 1, threshold = 0.000000, sample_rate = 16000, ch unksize = 480, sizeof_uint16 = 2 CONTINUOUS_RECOGNITION: 2_0 MN1_4; core: 0; (May 15 2020 14:50:28) SHIFT: 8, 12, 17, 17, 19, 17, 6, 16, 15, 14, I (997) example_asr_keywords: keywords_num = 200 , sample_rate = 16000, chunksiz e = 480, sizeof_uint16 = 2 I (998) example_asr_keywords: [ 1 ] Start codec chip I (1505) example_asr_keywords: [ 2.0 ] Create audio pipeline for recording I (1505) example_asr_keywords: [ 2.1 ] Create i2s stream to read audio data from codec chip I (1512) example_asr_keywords: [ 2.3 ] Create raw to receive data I (1517) example_asr_keywords: [ 3 ] Register all elements to audio pipeline I (1525) example_asr_keywords: [ 4 ] Link elements together [codec_chip]-->i2s_s tream-->raw-->[SR] W (1595) I2C_BUS: i2c_bus_create:57: I2C bus has been already created, [port:0] ----------------------------- ESP Audio Platform ----------------------------- | | | ESP_AUDIO-v1.6.6-10-gf944a6b-aca0d7f-2d83f7a | | Compile date: Mar 15 2021-11:14:21 | ------------------------------------------------------------------------------ I (1635) example_asr_keywords: esp_audio instance is:0x3ffd24dc I (1635) example_asr_keywords: [ 5 ] Start audio_pipeline |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 10:26 , Processed in 0.708604 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
582
