电子发烧友论坛|
模块:ESP32-S3 N8R2
环境:ESP-IDF4.4.2 我通过spi外接WK2124 SPI转串口芯片(SPI总线上只皆有此一个芯片),在内置串口与SPI外扩串口通讯时,每个串口分别在一个独立的任务中进行收发数据,每个串口也都启动了一个中断任务,程序启动第一次收发都正常运行,在第二轮收发时报错,错误信息如下: Code: Select all assert failed: tlsf_free heap_tlsf.c:872 (!block_is_free(block) && "block already marked as free") Backtrace:0x40375d6a:0x3fc9d6500x4037c139:0x3fc9d670 0x40383155:0x3fc9d690 0x4038246f:0x3fc9d7b0 0x40382d86:0x3fc9d7d0 0x40375fca:0x3fc9d7f0 0x40383185:0x3fc9d810 0x40377882:0x3fc9d830 0x40377d08:0x3fc9d850 0x40377d55:0x3fc9d880 0x420095cf:0x3fc9d8a0 0x4200977e:0x3fc9d8d0 0x42009ccf:0x3fc9d920 0x42009588:0x3fc9d950 0x42007d8e:0x3fc9d970 0x42008db4:0x3fc9d990 0x42007dc8:0x3fc9d9d0 0x420083cd:0x3fc9d9f0 0x420078c8:0x3fc9da10 0x4037f265:0x3fc9db40 0x40375d6a: panic_abort at /home/zhuxy/esp/esp-idf/components/esp_system/panic.c:402 0x4037c139: esp_system_abort at /home/zhuxy/esp/esp-idf/components/esp_system/esp_system.c:128 0x40383155: __assert_func at /home/zhuxy/esp/esp-idf/components/newlib/assert.c:85 0x4038246f: tlsf_free at /home/zhuxy/esp/esp-idf/components/heap/heap_tlsf.c:872 (discriminator 1) 0x40382d86: multi_heap_free_impl at /home/zhuxy/esp/esp-idf/components/heap/multi_heap.c:222 0x40375fca: heap_caps_free at /home/zhuxy/esp/esp-idf/components/heap/heap_caps.c:340 0x40383185: free at /home/zhuxy/esp/esp-idf/components/newlib/heap.c:39 0x40377882: uninstall_priv_desc at /home/zhuxy/esp/esp-idf/components/driver/spi_master.c:736 0x40377d08: spi_device_polling_end at /home/zhuxy/esp/esp-idf/components/driver/spi_master.c:983 (discriminator 15) 0x40377d55: spi_device_polling_transmit at /home/zhuxy/esp/esp-idf/components/driver/spi_master.c:1003 0x420095cf: wk_device_transmit at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/spi_wk2xxx.c:62 0x4200977e: wk_read_SFifo at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/spi_wk2xxx.c:195 0x42009ccf: wk_read_bytes at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/spi_wk2xxx.c:593 0x42009588: uart_port_read_bytes at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/uart_port.c:296 0x42007d8e: _modbus_rtu_recv at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus-rtu.c:204 0x42008db4: _modbus_receive_msg at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus.c:412 0x42007dc8: _modbus_rtu_receive at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus-rtu.c:191 0x420083cd: modbus_receive at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus.c:504 0x420078c8: modbus_rtu_task at /home/zhuxy/esp-projects/IoT-Station/main/src/modbus_slave.c:122 0x4037f265: vPortTaskWrapper at /home/zhuxy/esp/esp-idf/components/freertos/port/xtensa/port.c:131 ELF file SHA256: 4be6f973b94b35ce CPU halted. 如果把两个任务的串口对调,错误又稍有不同,错误信息如下: Code: Select all Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled. Core 0 register dump: PC : 0x40382734 PS : 0x00060833 A0 : 0x80382d89 A1 : 0x3fc9f8a0 0x40382734: insert_free_block at /home/zhuxy/esp/esp-idf/components/heap/heap_tlsf.c:243 (inlined by) block_insert at /home/zhuxy/esp/esp-idf/components/heap/heap_tlsf.c:269 (inlined by) tlsf_free at /home/zhuxy/esp/esp-idf/components/heap/heap_tlsf.c:876 A2 : 0x3fc9974c A3 : 0xa5a5a5a5 A4 : 0x3fc97a94 A5 : 0x00060823 A6 : 0x00060820 A7 : 0x00000001 A8 : 0x3fc9fad4 A9 : 0x00000017 A10 : 0x0000001f A11 : 0x3fc9fadc A12 : 0x3fc9fad4 A13 : 0x3fc9f9e8 A14 : 0x02ce0988 A15 : 0x00ffffff SAR : 0x00000018 EXCCAUSE: 0x0000001d EXCVADDR: 0xa5a5a5b1 LBEG : 0x40056f5c LEND : 0x40056f72 LCOUNT : 0xffffffff Backtrace:0x40382731:0x3fc9f8a00x40382d86:0x3fc9f8c0 0x40375fca:0x3fc9f8e0 0x40383185:0x3fc9f900 0x40377882:0x3fc9f920 0x40377d08:0x3fc9f940 0x40377d55:0x3fc9f970 0x420095cf:0x3fc9f990 0x4200977e:0x3fc9f9c0 0x42009ccf:0x3fc9fa10 0x42009588:0x3fc9fa40 0x42007d8e:0x3fc9fa60 0x42008db4:0x3fc9fa80 0x42008f49:0x3fc9fac0 0x42008ff1:0x3fc9fc00 0x420071f5:0x3fc9fc30 0x4037f265:0x3fc9fca0 0x40382731: insert_free_block at /home/zhuxy/esp/esp-idf/components/heap/heap_tlsf.c:242 (inlined by) block_insert at /home/zhuxy/esp/esp-idf/components/heap/heap_tlsf.c:269 (inlined by) tlsf_free at /home/zhuxy/esp/esp-idf/components/heap/heap_tlsf.c:876 0x40382d86: multi_heap_free_impl at /home/zhuxy/esp/esp-idf/components/heap/multi_heap.c:222 0x40375fca: heap_caps_free at /home/zhuxy/esp/esp-idf/components/heap/heap_caps.c:340 0x40383185: free at /home/zhuxy/esp/esp-idf/components/newlib/heap.c:39 0x40377882: uninstall_priv_desc at /home/zhuxy/esp/esp-idf/components/driver/spi_master.c:736 0x40377d08: spi_device_polling_end at /home/zhuxy/esp/esp-idf/components/driver/spi_master.c:983 (discriminator 15) 0x40377d55: spi_device_polling_transmit at /home/zhuxy/esp/esp-idf/components/driver/spi_master.c:1003 0x420095cf: wk_device_transmit at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/spi_wk2xxx.c:62 0x4200977e: wk_read_SFifo at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/spi_wk2xxx.c:195 0x42009ccf: wk_read_bytes at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/spi_wk2xxx.c:593 0x42009588: uart_port_read_bytes at /home/zhuxy/esp-projects/IoT-Station/components/drivers/src/uart_port.c:296 0x42007d8e: _modbus_rtu_recv at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus-rtu.c:204 0x42008db4: _modbus_receive_msg at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus.c:412 0x42008f49: read_registers at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus.c:1202 0x42008ff1: modbus_read_registers at /home/zhuxy/esp-projects/IoT-Station/components/libmodbus/src/modbus.c:1243 0x420071f5: modbusTask at /home/zhuxy/esp-projects/IoT-Station/main/main.c:84 0x4037f265: vPortTaskWrapper at /home/zhuxy/esp/esp-idf/components/freertos/port/xtensa/port.c:131 我还发现一个奇怪现象,在调用SPI驱动接口前如加有printf或ESP_LOG来输出日志,则有可能正常运行(未长时间测试,未加日志输出则在第二次串口通讯时报错),这是什么原因呢? |
只有小组成员才能发言,加入小组>>
468 浏览 0 评论
986 浏览 0 评论
1708 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1364 浏览 1 评论
1253 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1287浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2382浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2570浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-13 04:02 , Processed in 0.726371 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
392
