1.环境如下
win10环境安装Espressif-IDE(版本:2.6.0,Build id:20220811-0838) 2. 问题复现方法 2.1. 芯片选择esp32 2.2. 菜单栏依次选择 FILE->New->Espressif IDF Project->next->lvgl 创建工程 2.3. 点击编译,直接报错 3. 报错日志 Code: Select all 构建位置: D:Espressifframeworksesp-idf-v4.4.2workspacelvglbuild 正在配置中: D:Espressifframeworksesp-idf-v4.4.2workspacelvglbuild cmake -G Ninja -DCMAKE_TOOLCHAIN_FILE=D:Espressifframeworksesp-idf-v4.4.2toolscmaketoolchain-esp32.cmake -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCCACHE_ENABLE=1 -DIDF_TARGET=esp32 D:Espressifframeworksesp-idf-v4.4.2workspacelvgl -- Found Git: D:/Program Files/Git/cmd/git.exe (found version "2.31.1.windows.1") CMake Error at D:/Espressif/frameworks/esp-idf-v4.4.2/tools/cmake/component.cmake:368 (__component_get_property): __component_get_property Function invoked with incorrect arguments for function named: __component_get_property Call Stack (most recent call first): CMakeLists.txt:8 (idf_component_get_property) CMake Error at CMakeLists.txt:9 (target_compile_options): Cannot specify compile options for target "PRIVATE" which is not built by this project. -- ccache will be used for faster recompilation -- The C compiler identification is GNU 8.4.0 -- The CXX compiler identification is GNU 8.4.0 -- The ASM compiler identification is GNU -- Found assembler: D:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: D:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: D:/Espressif/tools/xtensa-esp32-elf/esp-2021r2-patch3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Building ESP-IDF components for target esp32 -- Checking Python dependencies... Python requirements from D:/Espressif/frameworks/esp-idf-v4.4.2/requirements.txt are satisfied. Processing 2 dependencies: [1/2] idf (4.4.2) [2/2] lvgl/lvgl (8.0.2) -- Project sdkconfig file D:/Espressif/frameworks/esp-idf-v4.4.2/workspace/lvgl/sdkconfig Loading defaults file D:/Espressif/frameworks/esp-idf-v4.4.2/workspace/lvgl/sdkconfig.defaults... -- Found Python3: D:/Espressif/python_env/idf4.4_py3.8_env/Scripts/python.exe (found version "3.8.7") found components: Interpreter -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success -- App "lvgl" version: v4.4.2-dirty -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/workspace/lvgl/build/esp-idf/esp_system/ld/memory.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_system/ld/esp32/sections.ld.in -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom/esp32/ld/esp32.rom.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom/esp32/ld/esp32.rom.api.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom/esp32/ld/esp32.rom.newlib-time.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v4.4.2/components/soc/esp32/ld/esp32.peripherals.ld -- Components: app_trace app_update asio bootloader bootloader_support bt cbor cmock coap console cxx driver efuse esp-tls esp32 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_ipc esp_lcd esp_local_ctrl esp_netif esp_phy esp_pm esp_ringbuf esp_rom esp_serial_slave_link esp_system esp_timer esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos hal heap idf_test ieee802154 jsmn json libsodium log lvgl__lvgl lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter tinyusb ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa -- Component paths: D:/Espressif/frameworks/esp-idf-v4.4.2/components/app_trace D:/Espressif/frameworks/esp-idf-v4.4.2/components/app_update D:/Espressif/frameworks/esp-idf-v4.4.2/components/asio D:/Espressif/frameworks/esp-idf-v4.4.2/components/bootloader D:/Espressif/frameworks/esp-idf-v4.4.2/components/bootloader_support D:/Espressif/frameworks/esp-idf-v4.4.2/components/bt D:/Espressif/frameworks/esp-idf-v4.4.2/components/cbor D:/Espressif/frameworks/esp-idf-v4.4.2/components/cmock D:/Espressif/frameworks/esp-idf-v4.4.2/components/coap D:/Espressif/frameworks/esp-idf-v4.4.2/components/console D:/Espressif/frameworks/esp-idf-v4.4.2/components/cxx D:/Espressif/frameworks/esp-idf-v4.4.2/components/driver D:/Espressif/frameworks/esp-idf-v4.4.2/components/efuse D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp-tls D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp32 D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_adc_cal D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_common D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_eth D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_event D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_gdbstub D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_hid D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_http_client D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_http_server D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_https_ota D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_https_server D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_hw_support D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_ipc D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_lcd D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_local_ctrl D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_netif D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_phy D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_pm D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_ringbuf D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_rom D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_serial_slave_link D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_system D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_timer D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_websocket_client D:/Espressif/frameworks/esp-idf-v4.4.2/components/esp_wifi D:/Espressif/frameworks/esp-idf-v4.4.2/components/espcoredump D:/Espressif/frameworks/esp-idf-v4.4.2/components/esptool_py D:/Espressif/frameworks/esp-idf-v4.4.2/components/expat D:/Espressif/frameworks/esp-idf-v4.4.2/components/fatfs D:/Espressif/frameworks/esp-idf-v4.4.2/components/freemodbus D:/Espressif/frameworks/esp-idf-v4.4.2/components/freertos D:/Espressif/frameworks/esp-idf-v4.4.2/components/hal D:/Espressif/frameworks/esp-idf-v4.4.2/components/heap D:/Espressif/frameworks/esp-idf-v4.4.2/components/idf_test D:/Espressif/frameworks/esp-idf-v4.4.2/components/ieee802154 D:/Espressif/frameworks/esp-idf-v4.4.2/components/jsmn D:/Espressif/frameworks/esp-idf-v4.4.2/components/json D:/Espressif/frameworks/esp-idf-v4.4.2/components/libsodium D:/Espressif/frameworks/esp-idf-v4.4.2/components/log D:/Espressif/frameworks/esp-idf-v4.4.2/workspace/lvgl/managed_components/lvgl__lvgl D:/Espressif/frameworks/esp-idf-v4.4.2/components/lwip D:/Espressif/frameworks/esp-idf-v4.4.2/workspace/lvgl/main D:/Espressif/frameworks/esp-idf-v4.4.2/components/mbedtls D:/Espressif/frameworks/esp-idf-v4.4.2/components/mdns D:/Espressif/frameworks/esp-idf-v4.4.2/components/mqtt D:/Espressif/frameworks/esp-idf-v4.4.2/components/newlib D:/Espressif/frameworks/esp-idf-v4.4.2/components/nghttp D:/Espressif/frameworks/esp-idf-v4.4.2/components/nvs_flash D:/Espressif/frameworks/esp-idf-v4.4.2/components/openssl D:/Espressif/frameworks/esp-idf-v4.4.2/components/openthread D:/Espressif/frameworks/esp-idf-v4.4.2/components/partition_table D:/Espressif/frameworks/esp-idf-v4.4.2/components/perfmon D:/Espressif/frameworks/esp-idf-v4.4.2/components/protobuf-c D:/Espressif/frameworks/esp-idf-v4.4.2/components/protocomm D:/Espressif/frameworks/esp-idf-v4.4.2/components/pthread D:/Espressif/frameworks/esp-idf-v4.4.2/components/sdmmc D:/Espressif/frameworks/esp-idf-v4.4.2/components/soc D:/Espressif/frameworks/esp-idf-v4.4.2/components/spi_flash D:/Espressif/frameworks/esp-idf-v4.4.2/components/spiffs D:/Espressif/frameworks/esp-idf-v4.4.2/components/tcp_transport D:/Espressif/frameworks/esp-idf-v4.4.2/components/tcpip_adapter D:/Espressif/frameworks/esp-idf-v4.4.2/components/tinyusb D:/Espressif/frameworks/esp-idf-v4.4.2/components/ulp D:/Espressif/frameworks/esp-idf-v4.4.2/components/unity D:/Espressif/frameworks/esp-idf-v4.4.2/components/usb D:/Espressif/frameworks/esp-idf-v4.4.2/components/vfs D:/Espressif/frameworks/esp-idf-v4.4.2/components/wear_levelling D:/Espressif/frameworks/esp-idf-v4.4.2/components/wifi_provisioning D:/Espressif/frameworks/esp-idf-v4.4.2/components/wpa_supplicant D:/Espressif/frameworks/esp-idf-v4.4.2/components/xtensa -- Configuring incomplete, errors occurred! See also "D:/Espressif/frameworks/esp-idf-v4.4.2/workspace/lvgl/build/CMakeFiles/CMakeOutput.log". cmake --build . -- -v ninja: error: loading 'build.ninja': 系统找不到指定的文件。 构建完成(0 个错误,0 个警告): D:Espressifframeworksesp-idf-v4.4.2workspacelvglbuild D:Espressifpython_envidf4.4_py3.8_envScriptspython.exe D:Espressifframeworksesp-idf-v4.4.2toolsidf_size.py D:/Espressif/frameworks/esp-idf-v4.4.2/workspace/lvgl/build/lvgl.map D:Espressifpython_envidf4.4_py3.8_envScriptspython.exe D:/Espressif/frameworks/esp-idf-v4.4.2/componentspartition_tablegen_esp32part.py D:Espressifframeworksesp-idf-v4.4.2workspacelvglbuildpartition_tablepartition-table.bin Total time taken to build the project: 10,467 ms |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1250浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2330浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 21:59 , Processed in 0.712997 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
544
