电子发烧友论坛|
直接运行官方 examples/wifi/iperf 里面的示例, 测得的速度最快也只有 0.1Mbits/s 左右, 应该有大几十兆才对, 有人遇到过类似情况吗? 我用的开发板是 esp32-doit-kit-v1
Code: Select all iperf> sta or4 xxxxpassword I (10917) cmd_wifi: sta connecting to 'or4' I (11503) cmd_wifi: sta disconnect, reconnect... I (13912) cmd_wifi: sta disconnect, reconnect... I (15456) esp_netif_handlers: sta ip: 192.168.5.237, mask: 255.255.255.0, gw: 192.168.5.144 iperf> iperf -c 192.168.5.136 -i 3 -t 60 I (26063) cmd_wifi: mode=tcp-client sip=192.168.5.237:5001, dip=192.168.5.136:5001, interval=3, time=60 iperf> I (26376) iperf: Successfully connected Interval Bandwidth 0- 3 sec 0.17 Mbits/sec 3- 6 sec 0.00 Mbits/sec 6- 9 sec 0.09 Mbits/sec 9- 12 sec 0.04 Mbits/sec 12- 15 sec 0.04 Mbits/sec 15- 18 sec 0.04 Mbits/sec 18- 21 sec 0.04 Mbits/sec 21- 24 sec 0.04 Mbits/sec 24- 27 sec 0.04 Mbits/sec 27- 30 sec 0.31 Mbits/sec 30- 33 sec 0.39 Mbits/sec 33- 36 sec 0.35 Mbits/sec 36- 39 sec 0.04 Mbits/sec 39- 42 sec 0.13 Mbits/sec 42- 45 sec 0.09 Mbits/sec 45- 48 sec 0.70 Mbits/sec 48- 51 sec 0.31 Mbits/sec 51- 54 sec 0.13 Mbits/sec 54- 57 sec 0.00 Mbits/sec 57- 60 sec 0.48 Mbits/sec 0- 60 sec 0.17 Mbits/sec I (87412) iperf: TCP Socket client is closed. I (87413) iperf: iperf exit 测试 UDP 的速度有 10Mbits/s 左右, 也是比官方文档差了一大截: Code: Select all iperf> iperf -c 192.168.5.136 -i 3 -t 60 -u I (414255) cmd_wifi: mode=udp-client sip=192.168.5.237:5001, dip=192.168.5.136:5001, interval=3, time=60 I (414257) iperf: Socket created, sending to -2012895040:5001 Interval Bandwidth iperf> 0- 3 sec 8.31 Mbits/sec 3- 6 sec 8.77 Mbits/sec 6- 9 sec 9.63 Mbits/sec 9- 12 sec 7.69 Mbits/sec 12- 15 sec 9.62 Mbits/sec 15- 18 sec 9.64 Mbits/sec 18- 21 sec 9.31 Mbits/sec 21- 24 sec 10.09 Mbits/sec 24- 27 sec 9.22 Mbits/sec 27- 30 sec 10.07 Mbits/sec 30- 33 sec 9.85 Mbits/sec 33- 36 sec 9.51 Mbits/sec 36- 39 sec 10.28 Mbits/sec 39- 42 sec 9.63 Mbits/sec 42- 45 sec 9.72 Mbits/sec 45- 48 sec 9.79 Mbits/sec 48- 51 sec 9.13 Mbits/sec 51- 54 sec 10.09 Mbits/sec 54- 57 sec 9.43 Mbits/sec 57- 60 sec 8.69 Mbits/sec 0- 60 sec 9.42 Mbits/sec I (474269) iperf: UDP Socket client is closed I (474270) iperf: iperf exit iperf server 这边的输出: Code: Select all ➜ esp32-camera git:(master) iperf -s -i 3 ------------------------------------------------------------ Server listening on TCP port 5001 TCP window size: 128 KByte (default) ------------------------------------------------------------ [ 1] local 192.168.5.136 port 5001 connected with 192.168.5.237 port 58085 (icwnd/mss/irtt=11/1440/15000) [ ID] Interval Transfer Bandwidth [ 1] 0.00-3.00 sec 7.03 KBytes 19.2 Kbits/sec [ 1] 3.00-6.00 sec 8.44 KBytes 23.0 Kbits/sec [ 1] 6.00-9.00 sec 21.1 KBytes 57.6 Kbits/sec [ 1] 9.00-12.00 sec 12.7 KBytes 34.6 Kbits/sec [ 1] 12.00-15.00 sec 18.3 KBytes 49.9 Kbits/sec [ 1] 15.00-18.00 sec 14.1 KBytes 38.4 Kbits/sec [ 1] 18.00-21.00 sec 19.7 KBytes 53.8 Kbits/sec [ 1] 21.00-24.00 sec 12.7 KBytes 34.6 Kbits/sec [ 1] 24.00-27.00 sec 16.9 KBytes 46.1 Kbits/sec [ 1] 27.00-30.00 sec 115 KBytes 313 Kbits/sec [ 1] 30.00-33.00 sec 142 KBytes 388 Kbits/sec [ 1] 33.00-36.00 sec 129 KBytes 351 Kbits/sec [ 1] 36.00-39.00 sec 19.7 KBytes 53.8 Kbits/sec [ 1] 39.00-42.00 sec 42.2 KBytes 115 Kbits/sec [ 1] 42.00-45.00 sec 35.2 KBytes 96.0 Kbits/sec [ 1] 45.00-48.00 sec 263 KBytes 718 Kbits/sec [ 1] 48.00-51.00 sec 110 KBytes 301 Kbits/sec [ 1] 51.00-54.00 sec 39.4 KBytes 108 Kbits/sec [ 1] 54.00-57.00 sec 14.1 KBytes 38.4 Kbits/sec [ 1] 57.00-60.00 sec 163 KBytes 446 Kbits/sec [ 1] 60.00-63.00 sec 33.8 KBytes 92.2 Kbits/sec [ 1] 63.00-66.00 sec 35.2 KBytes 96.0 Kbits/sec [ 1] 66.00-67.87 sec 7.94 KBytes 34.7 Kbits/sec [ 1] 0.00-67.87 sec 1.25 MBytes 154 Kbits/sec |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2334浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 01:26 , Processed in 1.257936 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
329
