电子发烧友论坛|
module:ESP-WROOM-32
IDF Version:ESP-IDF 4.3 各位,ESP32的技术手册中有关于SPI DMA的描述,但是在ESP-IDF编程指南https://docs.espressif.com/projects/esp ... aster.html当中并没有相关的API,请问是否有关于SPI DMA的例程参考 |
1个回答
ESP32 使用 SPI DMA 的方法如下:
1. 首先,确保你已经安装了 ESP-IDF 4.3 版本。如果你还没有安装,请访问 https://docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/index.html#installation-step-by-step 按照步骤安装。 2. 创建一个新的 ESP-IDF 项目。你可以使用以下命令创建一个名为 "spi_dma_example" 的项目: ``` mkdir spi_dma_example cd spi_dma_example mkdir components cp -r /path/to/esp-idf/examples/peripherals/spi/spi_master/components/spi_master . cp -r /path/to/esp-idf/examples/peripherals/spi/spi_master/main . cp -r /path/to/esp-idf/examples/peripherals/spi/spi_master/CMakeLists.txt . cp -r /path/to/esp-idf/examples/peripherals/spi/spi_master/idf_component.yml . ``` 3. 打开 "spi_master" 组件目录,找到 "spi_master.c" 文件。在这个文件中,你需要添加 DMA 相关的代码。以下是一个示例代码片段: ```c #include "driver/spi_master.h" #include "driver/dma.h" // ... void spi_dma_example() { // 初始化 SPI 和 DMA spi_bus_config_t bus_cfg = { .mosi_io_num = SPI_MASTER_MOSI_GPIO, .miso_io_num = SPI_MASTER_MISO_GPIO, .sclk_io_num = SPI_MASTER_SCLK_GPIO, .quadwp_io_num = -1, .quadhd_io_num = -1, }; spi_device_interface_config_t dev_cfg = { .clock_speed_hz = 10 * 1000 * 1000, // 10 MHz .mode = 0, .spics_io_num = SPI_CS_GPIO, .queue_size = 7, .pre_cb = NULL, }; spi_bus_initialize(HSPI_HOST, &bus_cfg, 1); spi_device_handle_t spi; spi_device_create(HSPI_HOST, &dev_cfg, &spi); // 初始化 DMA lldesc_t dma_desc[2]; memset(&dma_desc[0], 0, sizeof(dma_desc)); dma_desc[0].length = 4096; dma_desc[0].size = 4096; dma_desc[0].buf = (uint8_t *)malloc(4096); dma_desc[0].eof = 1; dma_desc[1].length = 0; dma_desc[1].size = 0; dma_desc[1].buf = NULL; dma_desc[1].eof = 1; dma_descriptor_enable(1, 0, 0, 0, 0, 0); dma_set_owner(1, 0, 0); dma_reset_channel(1, 0); // 配置 SPI DMA spi_transaction_t t; memset(&t, 0, sizeof(t)); t.length = 4096 * 8; t.tx_buffer = dma_desc[0].buf; spi_device_queue_trans(spi, &t, portMAX_DELAY); // 启动 DMA dma_setup_link(1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 |
只有小组成员才能发言,加入小组>>
933 浏览 0 评论
1653 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1284 浏览 1 评论
1218 浏览 1 评论
4959 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1249浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2329浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2524浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 19:01 , Processed in 0.737739 second(s), Total 75, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
887
