电子发烧友论坛|
开发板:ESP32-S2-saola-1_V1.2
开发环境安装方式:esp-idf-tools-setup-offline-2.8.exe 安装后是 v4.2版本 开发环境 :eclipse 使用j-link调试时出现以下问题,未找到原因: Code: Select all Open On-Chip Debugger v0.10.0-esp32-20200709 (2020-07-09-08:54) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html adapter speed: 9600 kHz Started by GNU MCU Eclipse Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : J-Link V9 compiled Dec 13 2019 11:14:50 Info : Hardware version: 9.20 Info : VTarget = 3.301 V Info : clock speed 9600 kHz Info : JTAG tap: esp32s2.cpu tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1) Info : esp32s2: Target halted, PC=0x400314A4, debug_reason=00000001 Info : Detected ESP32-S2 chip Info : Listening on port 3333 for gdb connections Info : accepting 'gdb' connection on tcp/3333 Error: No symbols for FreeRTOS Error: esp32s2: DSR (8000CC13) indicates DIR instruction generated an exception! Warn : esp32s2: Failed reading 5284 bytes at address 0x40030000 Error: no working area available, can't alloc space for stub code! Error: Failed to load stub (-308)! Error: Algorithm run failed (-308)! Error: Failed to run flasher stub (-308)! Warn : Failed to get flash mappings (-308)! Error: esp32s2: DSR (8000CC13) indicates DIR instruction generated an exception! Warn : esp32s2: Failed reading 5284 bytes at address 0x40030000 Error: no working area available, can't alloc space for stub code! Error: Failed to load stub (-308)! Error: Algorithm run failed (-308)! Error: Failed to run flasher stub (-308)! Error: esp32s2: DSR (8000CC13) indicates DIR instruction generated an exception! Warn : esp32s2: Failed reading 5284 bytes at address 0x40030000 Error: no working area available, can't alloc space for stub code! Error: Failed to load stub (-308)! Error: Algorithm run failed (-308)! Error: Failed to run flasher stub (-308)! Error: Failed to probe flash, size 0 KB Error: auto_probe failed Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'. Error: attempted 'gdb' connection rejected |
只有小组成员才能发言,加入小组>>
468 浏览 0 评论
984 浏览 0 评论
1707 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1364 浏览 1 评论
1253 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1286浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2378浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2565浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-12 05:53 , Processed in 0.559290 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
563
