电子发烧友论坛|
开发环境:VSCode + Platformio + Arduino
硬件平台:ESP32C3 ESP-IDF版本:V4.1.2 Platformio PACKAGES: - tool-esptoolpy 1.30100.210531 (3.1.0) - toolchain-riscv-esp 1.80400.0 (8.4.0) 由于项目要求,以ESP32C3为平台的自研电路板,现在碰见一个比较棘手的问题无法解决。当加载BLE时,烧录后就不断重启,如果不加载BLE,只进行控制,如PWM,ADc,GPIO之类的都是ok的。网上找寻了很多信息,依然没解决问题,请高手指点。 BLE的初始化函数:(只执行到这里,就出异常) BLEDevice::init(DEVICE_NAME); 不断重启的log信息: ESP-ROM:esp32c3-api1-20210207 Build:Feb 7 2021 rst:0xf (BROWNOUT_RST),boot:0xf (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd6100,len:0x12f4 load:0x403ce000,len:0x93c load:0x403d0000,len:0x292c SHA-256 comparison failed: Calculated: 8d996f0c10c713e532f0d62ceb5bd044db8011bcaef3163574bcc3fc4768f05d Expected: e9d7702986eabdb730063e52592f19701feea7da0d2207d674ef148b8cdb3216 Attempting to boot anyway... entry 0x403ce000 I (49) boot: ESP-IDF v4.4-dev-2313-gc69f0ec32 2nd stage bootloader I (49) boot: compile time 12:10:29 I (49) boot: chip revision: 3 I (49) boot_comm: chip revision: 3, min. bootloader chip revision: 0 I (56) boot.esp32c3: SPI Speed : 80MHz I (59) boot.esp32c3: SPI Mode : DIO I (63) boot.esp32c3: SPI Flash Size : 4MB I (67) boot: Enabling RNG early entropy source... I (71) boot: Partition Table: I (74) boot: ## Label Usage Type ST Offset Length I (80) boot: 0 nvs WiFi data 01 02 00009000 00005000 I (87) boot: 1 otadata OTA data 01 00 0000e000 00002000 I (93) boot: 2 app0 OTA app 00 10 00010000 00300000 I (100) boot: 3 spiffs Unknown data 01 82 00310000 000f0000 I (106) boot: End of partition table I (110) boot_comm: chip revision: 3, min. application chip revision: 0 I (116) esp_image: segment 0: paddr=00010020 vaddr=3c0a0020 size=1c070h (114800) map I (141) esp_image: segment 1: paddr=0002c098 vaddr=3fc8d000 size=02338h ( 9016) load I (143) esp_image: segment 2: paddr=0002e3d8 vaddr=40380000 size=01c40h ( 7232) load I (147) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=96fb4h (618420) map I (249) esp_image: segment 4: paddr=000c6fdc vaddr=40381c40 size=0b24ch ( 45644) load I (258) esp_image: segment 5: paddr=000d2230 vaddr=50000000 size=00010h ( 16) load I (262) boot: Loaded app from partition at offset 0x10000 I (263) boot: Disabling RNG early entropy source... |
1 条评论
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1250浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2330浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 22:09 , Processed in 0.561864 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
520
