电子发烧友论坛|
刚入手的S3开发板,想装一个Micropython,从官网下载的源码编译的时候出现问题
Code: Select all In file included from /home/mars/esp/esp-idf_4_4/components/esp_hw_support/include/soc/spinlock.h:11, from /home/mars/esp/esp-idf_4_4/components/freertos/port/xtensa/include/freertos/portmacro.h:42, from /home/mars/esp/esp-idf_4_4/components/freertos/include/freertos/portable.h:51, from /home/mars/esp/esp-idf_4_4/components/freertos/include/freertos/FreeRTOS.h:63, from /home/mars/esp/micropython-1.18/ports/esp32/mpconfigport.h:10, from /home/mars/esp/micropython-1.18/py/mpconfig.h:62, from /home/mars/esp/micropython-1.18/py/mpstate.h:31, from /home/mars/esp/micropython-1.18/py/runtime.h:29, from /home/mars/esp/micropython-1.18/extmod/nimble/modbluetooth_nimble.c:28: /home/mars/esp/esp-idf_4_4/components/soc/esp32s3/include/soc/cpu.h:27: warning: "WSR" redefined #define WSR(reg, newval) asm volatile ("wsr %0, " #reg : : "r" (newval)); In file included from /home/mars/esp/esp-idf_4_4/components/freertos/port/xtensa/include/freertos/portmacro.h:41, from /home/mars/esp/esp-idf_4_4/components/freertos/include/freertos/portable.h:51, from /home/mars/esp/esp-idf_4_4/components/freertos/include/freertos/FreeRTOS.h:63, from /home/mars/esp/micropython-1.18/ports/esp32/mpconfigport.h:10, from /home/mars/esp/micropython-1.18/py/mpconfig.h:62, from /home/mars/esp/micropython-1.18/py/mpstate.h:31, from /home/mars/esp/micropython-1.18/py/runtime.h:29, from /home/mars/esp/micropython-1.18/extmod/nimble/modbluetooth_nimble.c:28: /home/mars/esp/esp-idf_4_4/components/xtensa/include/xt_instr_macros.h:18: note: this is the location of the previous definition #define WSR(reg, at) asm volatile ("wsr %0, %1" : : "r" (at), "i" (reg)) 报了一堆这样的错误,我看了两个文件,里面定义的内容确实有冲突,这个应该如何解决?? components/soc/esp32s3/include/soc/cpu.h Code: Select all /* C macros for xtensa special register read/write/exchange */ #define RSR(reg, curval) asm volatile ("rsr %0, " #reg : "=r" (curval)); #define WSR(reg, newval) asm volatile ("wsr %0, " #reg : : "r" (newval)); #define XSR(reg, swapval) asm volatile ("xsr %0, " #reg : "+r" (swapval)); components/xtensa/include/xt_instr_macros.h: Code: Select all #define RSR(reg, at) asm volatile ("rsr %0, %1" : "=r" (at) : "i" (reg)) #define WSR(reg, at) asm volatile ("wsr %0, %1" : : "r" (at), "i" (reg)) #define XSR(reg, at) asm volatile ("xsr %0, %1" : "+r" (at) : "i" (reg)) #define RER(reg, at) asm volatile ("rer %0, %1" : "=r" (at) : "r" (reg)) #define WITLB(at, as) asm volatile ("witlb %0, %1; n isync n " : : "r" (at), "r" (as)) #define WDTLB(at, as) asm volatile ("wdtlb %0, %1; n dsync n " : : "r" (at), "r" (as)) 关键是两个里面的内容还不一样,该用哪个? |
只有小组成员才能发言,加入小组>>
176 浏览 0 评论
946 浏览 0 评论
1674 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1334 浏览 1 评论
1234 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
928浏览 3评论
2341浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2529浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-3 11:39 , Processed in 0.953592 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
490
