windows系统,采用esp32,平台:vscode。Code: Select all
#include #include #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "driver/i2c.h" #include "esp_log.h" #include "string.h" #include "driver/rtc_io.h" #include "esp_sleep.h" #include "time.h" #include "sys/time.h" #include "driver/uart.h" #define pin GPIO_NUM_15 RTC_DATA_ATTR int timesWokenUp = 0; void app_main(void) { /* 一般 GPIO config and wakeup enable */ bool re = esp_sleep_is_valid_wakeup_gpio(pin); printf("pin %d is %sn", pin, re == 1 ? "RTC_GPIO" : "NORMAL_GRIO"); gpio_pad_select_gpio(pin); gpio_pulldown_en(pin); gpio_pullup_dis(pin); gpio_set_direction(pin, GPIO_MODE_INPUT); printf("pin stat = %dn ", gpio_get_level(pin)); gpio_wakeup_enable(pin, GPIO_INTR_HIGH_LEVEL); esp_sleep_enable_gpio_wakeup(); /*使timer唤醒睡眠功能用*/ esp_sleep_enable_timer_wakeup(10000000); while (1) { printf("start to sleepn"); uart_wait_tx_idle_polling(CONFIG_ESP_CONSOLE_UART_NUM); //等待发送缓冲区的数据全部发送完成。 esp_sleep_wakeup_cause_t cause = esp_sleep_get_wakeup_cause(); switch (cause) { case ESP_SLEEP_WAKEUP_TIMER: printf("wakeup from timern"); break; case ESP_SLEEP_WAKEUP_EXT0: printf("wakeup from EXT0n"); break; case ESP_SLEEP_WAKEUP_GPIO: printf("wakeup from GPIOn"); break; case ESP_SLEEP_WAKEUP_EXT1: printf("wakeup from EXT1n"); break; default: printf("NO REASONn"); } // int64_t start = esp_timer_get_time(); printf("going to sleep. woken up %dn", timesWokenUp++); esp_deep_sleep_start(); printf("wakeup ,wakeupn"); } } |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1250浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2330浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 21:29 , Processed in 0.555432 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
848
