I (257) cpu_start: ELF file SHA256: 3ba37c9ca1df85ac...
I (263) cpu_start: ESP-IDF: v4.4.1-472-gc9140caf8c-dirty I (270) heap_init: Initializing. RAM available for dynamic allocation: I (277) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (283) heap_init: At 3FFB2CD0 len 0002D330 (180 KiB): DRAM I (290) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (296) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (302) heap_init: At 4008CDA0 len 00013260 (76 KiB): IRAM I (310) spi_flash: detected chip: gd I (313) spi_flash: flash io: dio W (317) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (331) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (342) I2S: DMA Malloc info, datalen=blocksize=256, dma_buf_count=8 I (352) I2S: DMA Malloc info, datalen=blocksize=256, dma_buf_count=8 I (352) I2S: I2S0, MCLK output by GPIO0 I (382) ES8311: ES8311 in Slave mode and I2S format I (392) i2s_es8311: [echo] Echo start |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 05:41 , Processed in 0.593769 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
678
