开启psram后无法正常启动,取消psram可以正确运行。
配置见【附件1】 日志如下: �*�,�"� ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x10 (RTCWDT_RTC_RST),boot:0xb (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0108,len:0x1794 load:0x403b6000,len:0xe28 load:0x403ba000,len:0x30b8 entry 0x403b6274 I (25) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (25) boot: compile time 20:12:49 I (25) boot: chip revision: 0 I (27) qio_mode: Enabling default flash chip QIO I (33) boot.esp32s3: Boot SPI Speed : 80MHz I (37) boot.esp32s3: SPI Mode : QOUT I (42) boot.esp32s3: SPI Flash Size : 16MB I (47) boot: Enabling RNG early entropy source... I (52) boot: Partition Table: I (56) boot: ## Label Usage Type ST Offset Length I (63) boot: 0 nvs WiFi data 01 02 00011000 00006000 I (71) boot: 1 phy_init RF data 01 01 00017000 00001000 I (78) boot: 2 factory factory app 00 00 00020000 00100000 I (86) boot: End of partition table I (90) esp_image: segment 0: paddr=00020020 vaddr=3c020020 size=07a10h ( 31248) map I (104) esp_image: segment 1: paddr=00027a38 vaddr=3fc90d40 size=02940h ( 10560) load I (109) esp_image: segment 2: paddr=0002a380 vaddr=40374000 size=05c98h ( 23704) load I (120) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=16eb8h ( 93880) map I (139) esp_image: segment 4: paddr=00046ee0 vaddr=40379c98 size=070a8h ( 28840) load I (146) esp_image: segment 5: paddr=0004df90 vaddr=50000000 size=00010h ( 16) load I (151) boot: Loaded app from partition at offset 0x20000 I (151) boot: Disabling RNG early entropy source... I (168) opi psram: vendor id : 0x00 (UNKNOWN) I (168) opi psram: dev id : 0x03 (generation 4) I (168) opi psram: density : 0x07 (256 Mbit) I (172) opi psram: good-die : 0x01 (Pass) I (177) opi psram: Latency : 0x01 (Fixed) I (182) opi psram: VCC : 0x01 (3V) I (187) opi psram: SRF : 0x00 (Slow Refresh) I (192) opi psram: BurstType : 0x01 ( Wrap) I (197) opi psram: BurstLen : 0x03 (1024 Byte) I (202) opi psram: Readlatency : 0x07 (20 cycles@Fixed) I (208) opi psram: DriveStrength: 0x03 (1/8) I (213) spiram: Found 256MBit SPI RAM device I (218) spiram: SPI RAM mode: sram 40m I (223) spiram: PSRAM initialized, cache is in normal (1-core) mode. |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2334浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 01:29 , Processed in 0.655356 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
707
