电子发烧友论坛|
用ESP32通过SPI读取设备数据,采用GPIO中断方式触发读取,设备数据准备好后通过GPIO5上升沿触发。GPIO的配置完全按照例程设置,SPI的配置是在eeprom例程的基础上改的。
现象是运行程序可以进入中断读取设备数据,但读取一段时间后,中断不再触发。 中断不触发的原因是设备数据准备好发出上升沿后,如果没有通过SPI读取数据,则设备输出将保持高电平,不会在输出上升沿,直到读取数据后恢复正常。我这样判断的原因是在main_app()函数的循环中加入延时和读取数据的操作后,可以连续产生中断,不会停止。 我的问题是:如何保证每次上升沿中断都被触发并调用中断服务函数?设备正常输出上升沿触发中断的频次是3200次/秒。 IO配置程序如下: #define GPIO_INPUT_IO_1 5 #define GPIO_INPUT_PIN_SEL (1ULL< #define ESP_INTR_FLAG_DEFAULT 0 static xQueueHandle gpio_evt_queue = NULL; eeprom_handle_t eeprom_handle; short Accel_RAW[3] = {0,0,0}; void get_acc(void){ Accel_Device_Read_Accel_Raw(eeprom_handle, Accel_RAW);//读取设备数据 printf("x = %d, y = %d, z= %d.rn", Accel_RAW[0],Accel_RAW[1],Accel_RAW[2]);//输出 } static void IRAM_ATTR gpio_isr_handler(void* arg) { uint32_t gpio_num = (uint32_t) arg; xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL); } static void gpio_task_example(void* arg) { uint32_t io_num; for(;;) { if(xQueueReceive(gpio_evt_queue, &io_num, portMAX_DELAY)) { printf("GPIO[%d] intr, val: %dn", io_num, gpio_get_level(io_num)); get_acc(); } vTaskDelay(10 / portTICK_RATE_MS); } } void app_main(void) { ESP_ERROR_CHECK(init_services()); // Set UART log level esp_log_level_set(TAG, ESP_LOG_INFO); ESP_LOGI(TAG, "Initializing device..."); //zero-initialize the config structure. gpio_config_t io_conf = {}; //interrupt of rising edge io_conf.intr_type = GPIO_INTR_POSEDGE; //bit mask of the pins, use GPIO4/5 here io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL; //set as input mode io_conf.mode = GPIO_MODE_INPUT; //enable pull-up mode io_conf.pull_down_en = 1; gpio_config(&io_conf); //create a queue to handle gpio event from isr gpio_evt_queue = xQueueCreate(10, sizeof(uint32_t)); //start gpio task xTaskCreate(gpio_task_example, "gpio_task_example", 2048, NULL, 10, NULL); //install gpio isr service gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT); //hook isr handler for specific gpio pin gpio_isr_handler_add(GPIO_INPUT_IO_1, gpio_isr_handler, (void*) GPIO_INPUT_IO_1); Accel_Device_Read_Accel_Raw(eeprom_handle, Accel_RAW);// 读取设备数据 ESP_LOGI(TAG, "Initialization finished."); while (1) { ESP_LOGI(TAG, "In mainrn"); vTaskDelay(1000 / portTICK_RATE_MS); // Accel_Device_Read_Accel_Raw(eeprom_handle, Accel_RAW);//加入这句后中断可以连续触发,不会停止 } |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 00:27 , Processed in 0.409028 second(s), Total 38, Slave 31 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
447
