使用的ESP-IDF4.4,例程是native_ota_example,在进行ota升级时,一直失败,但是并没有找到原因,也多次重新编译上传过了,以下是完整日志
ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x18 (SPI_FAST_FLASH_BOOT) SPIWP:0xee Octal Flash Mode Enabled For OPI Flash, Use Default Flash Boot Mode mode:SLOW_RD, clock div:1 load:0x3fcd0108,len:0x1650 load:0x403b6000,len:0xb7c load:0x403ba000,len:0x2f58 entry 0x403b6248 I (32) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (32) boot: compile time 10:13:08 I (32) boot: chip revision: 0 I (34) boot.esp32s3: Boot SPI Speed : 80MHz I (39) boot.esp32s3: SPI Mode : SLOW READ I (44) boot.esp32s3: SPI Flash Size : 16MB I (49) boot: Enabling RNG early entropy source... I (55) boot: Partition Table: I (58) boot: ## Label Usage Type ST Offset Length I (65) boot: 0 nvs WiFi data 01 02 00009000 00004000 I (73) boot: 1 otadata OTA data 01 00 0000d000 00002000 I (80) boot: 2 phy_init RF data 01 01 0000f000 00001000 I (88) boot: 3 factory factory app 00 00 00010000 00300000 I (95) boot: 4 ota_0 OTA app 00 10 00310000 00300000 I (103) boot: 5 ota_1 OTA app 00 11 00610000 00300000 I (110) boot: End of partition table I (115) boot: Defaulting to factory image I (119) esp_image: segment 0: paddr=00010020 vaddr=3c090020 size=1ba70h (113264) map I (154) esp_image: segment 1: paddr=0002ba98 vaddr=3fc943c0 size=040c8h ( 16584) load I (159) esp_image: segment 2: paddr=0002fb68 vaddr=40374000 size=004b0h ( 1200) load I (161) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=8a47ch (566396) map I (302) esp_image: segment 4: paddr=000ba4a4 vaddr=403744b0 size=0ff08h ( 65288) load I (320) esp_image: segment 5: paddr=000ca3b4 vaddr=50000000 size=00010h ( 16) load I (327) boot: Loaded app from partition at offset 0x10000 I (327) boot: Disabling RNG early entropy source... I (340) cpu_start: Pro cpu up. I (340) cpu_start: Starting app cpu, entry point is 0x403751c4 0x403751c4: call_start_cpu1 at E:/.espressif/frameworks/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156 I (0) cpu_start: App cpu up. I (354) cpu_start: Pro cpu start user code I (354) cpu_start: cpu freq: 160000000 I (354) cpu_start: Application information: I (357) cpu_start: Project name: lcd_lvgl I (362) cpu_start: App version: 1.0.0 I (367) cpu_start: Compile time: Mar 29 2022 10:43:55 I (373) cpu_start: ELF file SHA256: 38c75b6c9c54a9b1... I (379) cpu_start: ESP-IDF: v4.4-dirty I (384) heap_init: Initializing. RAM available for dynamic allocation: I (392) heap_init: At 3FC9C448 len 00043BB8 (270 KiB): D/IRAM I (398) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (405) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (411) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM I (418) spi_flash: detected chip: mxic W (422) spi_flash: Detected flash size > 16 MB, but access beyond 16 MB is not supported for this flash model yet. I (433) spi_flash: flash io: dio W (437) spi_flash: Detected size(32768k) larger than the size in the binary image header(16384k). Using the size in the binary image header. I (451) sleep: Configure to isolate all GPIO pins in sleep state I (457) sleep: Enable automatic switching of GPIO sleep configuration I (464) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (487) native_ota_example: SHA-256 for the partition table: : ef3da872c51e46c9ec50ce42e8c3a835d35ae84f42541996655187323b433d5f I (497) native_ota_example: SHA-256 for bootloader: : ef3da872c51e46c9ec50ce42e8c3a835d35ae84f42541996655187323b433d5f I (507) native_ota_example: SHA-256 for current firmware: : ef3da872c51e46c9ec50ce42e8c3a835d35ae84f42541996655187323b433d5f I (527) pp: pp rom version: e7ae62f I (527) net80211: net80211 rom version: e7ae62f I (547) wifi:wifi driver task: 3fce5604, prio:23, stack:6656, core=0 I (547) system_api: Base MAC address is not set I (547) system_api: read default base MAC address from EFUSE I (557) wifi:wifi firmware version: 7679c42 I (557) wifi:wifi certification version: v7.0 I (557) wifi:config NVS flash: enabled I (557) wifi:config nano formating: disabled I (567) wifi:Init data frame dynamic rx buffer num: 32 I (567) wifi:Init management frame dynamic rx buffer num: 32 I (577) wifi:Init management short buffer num: 32 I (577) wifi:Init dynamic tx buffer num: 32 I (587) wifi:Init static tx FG buffer num: 2 I (587) wifi:Init static rx buffer size: 1600 I (587) wifi:Init static rx buffer num: 10 I (597) wifi:Init dynamic rx buffer num: 32 I (597) wifi_init: rx ba win: 6 I (607) wifi_init: tcpip mbox: 32 I (607) wifi_init: udp mbox: 6 I (607) wifi_init: tcp mbox: 6 I (617) wifi_init: tcp tx win: 5744 I (617) wifi_init: tcp rx win: 5744 I (627) wifi_init: tcp mss: 1440 I (627) wifi_init: WiFi IRAM OP enabled I (627) wifi_init: WiFi RX IRAM OP enabled I (637) example_connect: Connecting to Mi 11... I (647) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12 W (647) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration I (707) wifi:mode : sta (7c:df:a1:e1:26:0c) I (707) wifi:enable tsf I (707) example_connect: Waiting for IP(s) I (2757) wifi<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1 I (3617) wifi:state: init -> auth (b0) I (3637) wifi:state: auth -> assoc (0) I (3697) wifi:state: assoc -> run (10) I (3787) wifi:connected with Mi 11, aid = 2, channel 1, BW20, bssid = aa:91:d9:3f:a7:3d I (3787) wifi:security: WPA2-PSK, phy: bgn, rssi: -16 I (3787) wifi:pm start, type: 1 I (3797) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 0, mt_pti: 25000, mt_time: 10000 W (3847) wifi: I (3947) wifi:BcnInt:102400, DTIM:2 I (4527) esp_netif_handlers: example_connect: sta ip: 192.168.177.15, mask: 255.255.255.0, gw: 192.168.177.13 I (4527) example_connect: Got IPv4 event: Interface "example_connect: sta" address: 192.168.177.15 I (5527) example_connect: Got IPv6 event: Interface "example_connect: sta" address: fe80:0000:0000:0000:7edf:a1ff:fee1:260c, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (5527) example_connect: Connected to example_connect: sta I (5537) example_connect: - IPv4 address: 192.168.177.15 I (5537) example_connect: - IPv6 address: fe80:0000:0000:0000:7edf:a1ff:fee1:260c, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (5547) wifi:Set ps type: 0 I (5557) native_ota_example: Starting OTA example I (5557) native_ota_example: Running partition type 0 subtype 0 (offset 0x00010000) I (5837) native_ota_example: Writing to partition subtype 16 at offset 0x310000 I (5837) native_ota_example: New firmware version: 1.0.1 I (5837) native_ota_example: esp_ota_begin succeeded W (6207) wifi: I (21747) native_ota_example: Connection closed I (21747) native_ota_example: Total Write binary data length: 762864 E (21747) esp_image: image at 0x310000 has invalid magic byte (nothing flashed here?) E (21757) native_ota_example: Image validation failed, image is corrupted E (21767) native_ota_example: Exiting task due to fatal error... |
只有小组成员才能发言,加入小组>>
1024 浏览 1 评论
562浏览 6评论
469浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
454浏览 5评论
454浏览 4评论
428浏览 4评论
GMT+8, 2024-12-3 09:38 , Processed in 0.852452 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
