电子发烧友论坛|
使用的ESP-IDF4.4,例程是native_ota_example,在进行ota升级时,一直失败,但是并没有找到原因,也多次重新编译上传过了,以下是完整日志
ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0x1 (POWERON),boot:0x18 (SPI_FAST_FLASH_BOOT) SPIWP:0xee Octal Flash Mode Enabled For OPI Flash, Use Default Flash Boot Mode mode:SLOW_RD, clock div:1 load:0x3fcd0108,len:0x1650 load:0x403b6000,len:0xb7c load:0x403ba000,len:0x2f58 entry 0x403b6248 I (32) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (32) boot: compile time 10:13:08 I (32) boot: chip revision: 0 I (34) boot.esp32s3: Boot SPI Speed : 80MHz I (39) boot.esp32s3: SPI Mode : SLOW READ I (44) boot.esp32s3: SPI Flash Size : 16MB I (49) boot: Enabling RNG early entropy source... I (55) boot: Partition Table: I (58) boot: ## Label Usage Type ST Offset Length I (65) boot: 0 nvs WiFi data 01 02 00009000 00004000 I (73) boot: 1 otadata OTA data 01 00 0000d000 00002000 I (80) boot: 2 phy_init RF data 01 01 0000f000 00001000 I (88) boot: 3 factory factory app 00 00 00010000 00300000 I (95) boot: 4 ota_0 OTA app 00 10 00310000 00300000 I (103) boot: 5 ota_1 OTA app 00 11 00610000 00300000 I (110) boot: End of partition table I (115) boot: Defaulting to factory image I (119) esp_image: segment 0: paddr=00010020 vaddr=3c090020 size=1ba70h (113264) map I (154) esp_image: segment 1: paddr=0002ba98 vaddr=3fc943c0 size=040c8h ( 16584) load I (159) esp_image: segment 2: paddr=0002fb68 vaddr=40374000 size=004b0h ( 1200) load I (161) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=8a47ch (566396) map I (302) esp_image: segment 4: paddr=000ba4a4 vaddr=403744b0 size=0ff08h ( 65288) load I (320) esp_image: segment 5: paddr=000ca3b4 vaddr=50000000 size=00010h ( 16) load I (327) boot: Loaded app from partition at offset 0x10000 I (327) boot: Disabling RNG early entropy source... I (340) cpu_start: Pro cpu up. I (340) cpu_start: Starting app cpu, entry point is 0x403751c4 0x403751c4: call_start_cpu1 at E:/.espressif/frameworks/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156 I (0) cpu_start: App cpu up. I (354) cpu_start: Pro cpu start user code I (354) cpu_start: cpu freq: 160000000 I (354) cpu_start: Application information: I (357) cpu_start: Project name: lcd_lvgl I (362) cpu_start: App version: 1.0.0 I (367) cpu_start: Compile time: Mar 29 2022 10:43:55 I (373) cpu_start: ELF file SHA256: 38c75b6c9c54a9b1... I (379) cpu_start: ESP-IDF: v4.4-dirty I (384) heap_init: Initializing. RAM available for dynamic allocation: I (392) heap_init: At 3FC9C448 len 00043BB8 (270 KiB): D/IRAM I (398) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (405) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (411) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM I (418) spi_flash: detected chip: mxic W (422) spi_flash: Detected flash size > 16 MB, but access beyond 16 MB is not supported for this flash model yet. I (433) spi_flash: flash io: dio W (437) spi_flash: Detected size(32768k) larger than the size in the binary image header(16384k). Using the size in the binary image header. I (451) sleep: Configure to isolate all GPIO pins in sleep state I (457) sleep: Enable automatic switching of GPIO sleep configuration I (464) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (487) native_ota_example: SHA-256 for the partition table: : ef3da872c51e46c9ec50ce42e8c3a835d35ae84f42541996655187323b433d5f I (497) native_ota_example: SHA-256 for bootloader: : ef3da872c51e46c9ec50ce42e8c3a835d35ae84f42541996655187323b433d5f I (507) native_ota_example: SHA-256 for current firmware: : ef3da872c51e46c9ec50ce42e8c3a835d35ae84f42541996655187323b433d5f I (527) pp: pp rom version: e7ae62f I (527) net80211: net80211 rom version: e7ae62f I (547) wifi:wifi driver task: 3fce5604, prio:23, stack:6656, core=0 I (547) system_api: Base MAC address is not set I (547) system_api: read default base MAC address from EFUSE I (557) wifi:wifi firmware version: 7679c42 I (557) wifi:wifi certification version: v7.0 I (557) wifi:config NVS flash: enabled I (557) wifi:config nano formating: disabled I (567) wifi:Init data frame dynamic rx buffer num: 32 I (567) wifi:Init management frame dynamic rx buffer num: 32 I (577) wifi:Init management short buffer num: 32 I (577) wifi:Init dynamic tx buffer num: 32 I (587) wifi:Init static tx FG buffer num: 2 I (587) wifi:Init static rx buffer size: 1600 I (587) wifi:Init static rx buffer num: 10 I (597) wifi:Init dynamic rx buffer num: 32 I (597) wifi_init: rx ba win: 6 I (607) wifi_init: tcpip mbox: 32 I (607) wifi_init: udp mbox: 6 I (607) wifi_init: tcp mbox: 6 I (617) wifi_init: tcp tx win: 5744 I (617) wifi_init: tcp rx win: 5744 I (627) wifi_init: tcp mss: 1440 I (627) wifi_init: WiFi IRAM OP enabled I (627) wifi_init: WiFi RX IRAM OP enabled I (637) example_connect: Connecting to Mi 11... I (647) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12 W (647) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration I (707) wifi:mode : sta (7c:df:a1:e1:26:0c) I (707) wifi:enable tsf I (707) example_connect: Waiting for IP(s) I (2757) wifi I (3617) wifi:state: init -> auth (b0) I (3637) wifi:state: auth -> assoc (0) I (3697) wifi:state: assoc -> run (10) I (3787) wifi:connected with Mi 11, aid = 2, channel 1, BW20, bssid = aa:91:d9:3f:a7:3d I (3787) wifi:security: WPA2-PSK, phy: bgn, rssi: -16 I (3787) wifi:pm start, type: 1 I (3797) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 0, mt_pti: 25000, mt_time: 10000 W (3847) wifi:idx:0 (ifx:0, aa:91:d9:3f:a7:3d), tid:0, ssn:0, winSize:64 I (3947) wifi:BcnInt:102400, DTIM:2 I (4527) esp_netif_handlers: example_connect: sta ip: 192.168.177.15, mask: 255.255.255.0, gw: 192.168.177.13 I (4527) example_connect: Got IPv4 event: Interface "example_connect: sta" address: 192.168.177.15 I (5527) example_connect: Got IPv6 event: Interface "example_connect: sta" address: fe80:0000:0000:0000:7edf:a1ff:fee1:260c, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (5527) example_connect: Connected to example_connect: sta I (5537) example_connect: - IPv4 address: 192.168.177.15 I (5537) example_connect: - IPv6 address: fe80:0000:0000:0000:7edf:a1ff:fee1:260c, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (5547) wifi:Set ps type: 0 I (5557) native_ota_example: Starting OTA example I (5557) native_ota_example: Running partition type 0 subtype 0 (offset 0x00010000) I (5837) native_ota_example: Writing to partition subtype 16 at offset 0x310000 I (5837) native_ota_example: New firmware version: 1.0.1 I (5837) native_ota_example: esp_ota_begin succeeded W (6207) wifi:idx:1 (ifx:0, aa:91:d9:3f:a7:3d), tid:6, ssn:2, winSize:64 I (21747) native_ota_example: Connection closed I (21747) native_ota_example: Total Write binary data length: 762864 E (21747) esp_image: image at 0x310000 has invalid magic byte (nothing flashed here?) E (21757) native_ota_example: Image validation failed, image is corrupted E (21767) native_ota_example: Exiting task due to fatal error... |
1个回答
OTA(Over-The-Air)升级是一种无线更新设备固件的方法。在使用ESP32-S3进行OTA升级时,可能会遇到一些问题导致升级失败。根据您提供的日志,以下是一些可能导致OTA升级失败的原因及相应的解决方案:
1. **网络问题**:OTA升级依赖于稳定的网络连接。请确保您的设备连接到可靠的Wi-Fi网络。 2. **固件文件问题**:检查您上传的固件文件是否完整且未损坏。尝试重新生成固件并上传。 3. **ESP-IDF版本问题**:您使用的是ESP-IDF 4.4,但可能存在一些已知的bug。尝试更新到最新的稳定版本或查看是否有相关的bug修复。 4. **分区问题**:OTA升级需要正确的分区配置。请检查您的分区表是否正确设置,特别是OTA分区的大小和类型。 5. **固件签名问题**:如果启用了安全启动或固件签名检查,确保您上传的固件已经正确签名。 6. **内存问题**:ESP32-S3在运行时可能遇到内存不足的问题。检查您的代码是否有内存泄漏或不必要的大对象。 7. **日志不完整**:您提供的日志似乎被截断了,没有显示完整的错误信息。尝试捕获完整的日志以便更好地分析问题。 8. **硬件问题**:虽然较少见,但硬件问题(如损坏的Flash芯片)也可能导致OTA升级失败。 9. **电源问题**:不稳定的电源供应可能会影响OTA升级过程。确保设备电源稳定。 10. **软件配置问题**:检查您的代码中是否有错误的配置,例如错误的WiFi连接参数或OTA服务器设置。 解决步骤: - 确保网络连接稳定。 - 重新生成并上传固件。 - 更新ESP-IDF到最新版本。 - 检查分区表配置。 - 如果启用了签名,确保固件已正确签名。 - 检查代码是否有内存泄漏。 - 捕获完整的日志输出。 - 检查电源供应。 - 检查代码配置,特别是与OTA相关的部分。 如果问题仍然存在,您可能需要更详细地检查ESP32-S3的日志输出,或者在ESP-IDF的issue跟踪器中寻求帮助,提供完整的日志和您的配置信息。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 08:25 , Processed in 0.813150 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
710
