电子发烧友论坛|
如标题,环境为idf V4.4.1,参考wifi的scan例程。我目的是创建一个任务定时扫描wifi获取四个参考节点(ESP_AP)的rssi值,wifi模式为ap/sta共存模式,wifi扫描通道为7,相关配置参数如下:
wifi_scan_config_t scan_config = { .ssid = NULL, .bssid = NULL, .channel = 7, .show_hidden = false, .scan_type = WIFI_SCAN_TYPE_ACtiVE }; 然后用任务循环以下代码: esp_wifi_scan_start(&scan_config, false); vTaskDelay(200 / portTICK_PERIOD_MS); ESP_ERROR_CHECK(esp_wifi_scan_get_ap_records(&number, ap_info)); ESP_ERROR_CHECK(esp_wifi_scan_get_ap_num(&ap_count)); ESP_LOGI(TAG, "Total APs scanned = %u", ap_count); for (int i = 0; (i < DEFAULT_SCAN_LIST_SIZE) && (i < ap_count); i++) { ESP_LOGI(TAG, "SSID tt%s", ap_info.ssid); ESP_LOGI(TAG, "RSSI tt%d", ap_info.rssi); ESP_LOGI(TAG, "Channel tt%dn", ap_info.primary); } 但在开发板esp32-wroom中运行时,有时正常,有时会多次扫描后的数据中变成了空的wifi列表,最终变成全空。那四个ESP_AP为我设置的非隐藏的wifi ap,却无法正常的获取到wifi信息。希望大佬们帮我看看,哪里出了问题。以下为我截取的三组wifi扫描串口数据: [0;32mI (30607) esp_apsta: Total APs scanned = 4 [0;32mI (30607) esp_apsta: SSID ESP_AP1 [0;32mI (30607) esp_apsta: RSSI -65 [0;32mI (30607) esp_apsta: Channel 7 [0m [0;32mI (30607) esp_apsta: SSID ESP_AP3 [0;32mI (30617) esp_apsta: RSSI -83 [0;32mI (30617) esp_apsta: Channel 7 [0m [0;32mI (30617) esp_apsta: SSID ESP_AP4 [0;32mI (30627) esp_apsta: RSSI -88 [0;32mI (30627) esp_apsta: Channel 7 [0m [0;32mI (30637) esp_apsta: SSID ESP_AP2 [0;32mI (30637) esp_apsta: RSSI -88 [0;32mI (30637) esp_apsta: Channel 7 [0;32mI (35607) esp_apsta: Total APs scanned = 4 [0;32mI (35607) esp_apsta: SSID ESP_AP1 [0;32mI (35607) esp_apsta: RSSI -67 [0;32mI (35607) esp_apsta: Channel 7 [0m [0;32mI (35607) esp_apsta: SSID ESP_AP3 [0;32mI (35617) esp_apsta: RSSI -86 [0;32mI (35617) esp_apsta: Channel 7 [0m [0;32mI (35617) esp_apsta: SSID ESP_AP4 [0;32mI (35627) esp_apsta: RSSI -90 [0;32mI (35627) esp_apsta: Channel 7 [0m [0;32mI (35637) esp_apsta: SSID [0;32mI (35637) esp_apsta: RSSI 0 [0;32mI (35637) esp_apsta: Channel 0 [0;32mI (204597) esp_apsta: Total APs scanned = 6 [0;32mI (204597) esp_apsta: SSID ESP_AP1 [0;32mI (204597) esp_apsta: RSSI -62 [0;32mI (204597) esp_apsta: Channel 7 [0m [0;32mI (204597) esp_apsta: SSID ESP_AP3 [0;32mI (204607) esp_apsta: RSSI -85 [0;32mI (204607) esp_apsta: Channel 7 [0m [0;32mI (204607) esp_apsta: SSID [0;32mI (204617) esp_apsta: RSSI 0 [0;32mI (204617) esp_apsta: Channel 0 [0m [0;32mI (204627) esp_apsta: SSID [0;32mI (204627) esp_apsta: RSSI 0 [0;32mI (204627) esp_apsta: Channel 0 [0m [0;32mI (204637) esp_apsta: SSID [0;32mI (204637) esp_apsta: RSSI 0 [0;32mI (204637) esp_apsta: Channel 0 [0m [0;32mI (204647) esp_apsta: SSID [0;32mI (204647) esp_apsta: RSSI 0 [0;32mI (204657) esp_apsta: Channel 0 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 04:48 , Processed in 0.748220 second(s), Total 67, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
461
