电子发烧友论坛|
我正在尝试使用 NUCLEO-H743ZI2 板读取单个 ADC 通道,但结果是错误的。我使用 CubeMX 创建了一个非常简单的项目。保留默认时钟设置。在单端模式轮询中启用 ADC3 CH0 (PC3_C Pint)。启用 UART3 以使用板载 VCP 打印消息。但是 adc 返回值不正确。当我将 PC3 引脚连接到 GND 时,值约为 4650-4750。我尝试了许多其他组合,但无法弄清楚我做错了什么。谁能帮我解决 ADC 读取错误。初始化代码如下。
ADC 值读取: uint16_t ADC_Raw; 而 (1) { //HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin); HAL_ADC_Start (&hadc3); HAL_ADC_PollForConversion (&hadc3, 100); ADC_Raw = HAL_ADC_GetValue (&hadc3); My_Printf("rn CH%d[%d] ",0,ADC_Raw); HAL_ADC_Stop(&hadc3); HAL_延迟(1000); /* 用户代码结束 */ /* 用户代码开始 3 */ } 系统时钟配置: void SystemClock_Config(无效) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0}; /** 提供配置更新使能 */ HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY); /** 配置主内部稳压器输出电压 */ __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3); 同时(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)){} /** 配置PLL时钟源的宏 */ __HAL_RCC_PLL_PLLSOURCE_CONFIG(RCC_PLLSOURCE_HSI); /** 根据指定的参数初始化 RCC 振荡器 * 在 RCC_OscInitTypeDef 结构中。 */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI; RCC_OscInitStruct.HSIState = RCC_HSI_DIV1; RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI; 如果 (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { 错误处理程序(); } /** 初始化 CPU、AHB 和 APB 总线时钟 */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2 |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI; RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1; RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV1; RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV1; RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV1; 如果 (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK) { 错误处理程序(); } PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_USART3|RCC_PERIPHCLK_ADC; PeriphClkInitStruct.PLL2.PLL2M = 32; PeriphClkInitStruct.PLL2.PLL2N = 129; PeriphClkInitStruct.PLL2.PLL2P = 2; PeriphClkInitStruct.PLL2.PLL2Q = 2; PeriphClkInitStruct.PLL2.PLL2R = 2; PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_1; PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE; PeriphClkInitStruct.PLL2.PLL2FRACN = 0; PeriphClkInitStruct.Usart234578ClockSelection = RCC_USART234578CLKSOURCE_D2PCLK1; PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLL2; 如果(HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct)!= HAL_OK) { 错误处理程序(); } } 模数转换器配置: 静态无效 MX_ADC3_Init(无效) { /* 用户代码开始 ADC3_Init 0 */ /* 用户代码结束 ADC3_Init 0 */ ADC_ChannelConfTypeDef sConfig = {0}; /* 用户代码开始 ADC3_Init 1 */ /* 用户代码结束 ADC3_Init 1 */ /** 通用配置 */ hadc3.Instance = ADC3; hadc3.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV256; hadc3.Init.Resolution = ADC_RESOLUTION_16B; hadc3.Init.ScanConvMode = ADC_SCAN_DISABLE; hadc3.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc3.Init.LowPowerAutoWait = 禁用; hadc3.Init.ContinuousConvMode = 禁用; hadc3.Init.NbrOfConversion = 1; hadc3.Init.DiscontinuousConvMode = 禁用; hadc3.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc3.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR; hadc3.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc3.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE; hadc3.Init.OversamplingMode = 禁用; 如果(HAL_ADC_Init(&hadc3)!= HAL_OK) { 错误处理程序(); } /** 配置常规频道 */ sConfig.Channel = ADC_CHANNEL_0; sConfig.Rank = ADC_REGULAR_RANK_1; sConfig.SamplingTime = ADC_SAMPLETIME_64CYCLES_5; sConfig.SingleDiff = ADC_SINGLE_ENDED; sConfig.OffsetNumber = ADC_OFFSET_NONE; sConfig.Offset = 0; sConfig.OffsetSignedSaturation = 禁用; 如果 (HAL_ADC_ConfigChannel(&hadc3, &sConfig) != HAL_OK) { 错误处理程序(); } /* 用户代码开始 ADC3_Init 2 */ /* 用户代码结束 ADC3_Init 2 */ } |
1个回答
是地线的电阻引起了问题。由于我们是第一次使用 STM32H7 单片机,所以花了很长时间才解决这个问题。
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1470 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1522 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3670 浏览 1 评论
3861 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2479 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
749浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
681浏览 5评论
728浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
972浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
776浏览 5评论
/9
GMT+8, 2025-12-13 03:57 , Processed in 0.974975 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
522
