扫一扫,分享给好友
1个回答
补充下,昨天重新弄了段YUV 1920X1080的,压缩可以正常运行了,但是编码出来的文件有问题,不能播放,信息如下
root@firefly:/opt/mpp/build/linux/aarch64/test# sudo ./mpi_enc_test -i md_sample_sp420_1080p.yuv -t 7 -n 100 -o md_sample_sp420_1080p.h264 -w 1920 -h 1080 -r 25 mpp[4667]: mpi_enc_utils: cmd parse result: mpp[4667]: mpi_enc_utils: input file name: md_sample_sp420_1080p.yuv mpp[4667]: mpi_enc_utils: output file name: md_sample_sp420_1080p.h264 mpp[4667]: mpi_enc_utils: width : 1920 mpp[4667]: mpi_enc_utils: height : 1080 mpp[4667]: mpi_enc_utils: format : 0 mpp[4667]: mpi_enc_utils: type : 7 mpp[4667]: mpi_enc_test: mpi_enc_test start mpp[4667]: mpp_rt: NOT found ion allocator mpp[4667]: mpp_rt: found drm allocator mpp[4667]: mpp_info: mpp version: 3c5dc7fe author: sayon.chen 2020-11-23 [h265d_syntax]: Fix h265 syntax fill sps rps issue mpp[4667]: mpi_enc_test: 0x5581fb8c40 mpi_enc_test encoder test start w 1920 h 1080 type 7 mpp[4667]: mpp_log: can not found match soc name: rockchip,roc-rk3588-pc rockchip,rk3588 mpp[4667]: h264e_api_v2: MPP_ENC_SET_PREP_CFG w:h [1920:1080] stride [1920:1080] mpp[4667]: h264e_api_v2: MPP_ENC_SET_RC_CFG bps 6480000 [405000 : 6885000] fps [25:25] gop 50 mpp[4667]: mpp_enc_v2: send header for set cfg change input/format mpp[4667]: mpp_enc_v2: mode vbr bps [405000:6480000:6885000] fps fix [25/1] -> fix [25/1] gop i [50] v [0] mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 0 size 206 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 1 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 2 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 3 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 4 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 5 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 6 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 7 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 8 size 0 mpp[4667]: mpi_enc_test: 0x5581fb8c40 encoded frame 9 size 0 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1160 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1381 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7174 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2184 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2727 浏览 0 评论
/9
GMT+8, 2025-12-15 04:06 , Processed in 0.896074 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1081
