大家好,
我需要你的帮助:
我想在 ST25R911B 阅读器和 ST25DV04K 标签之间建立 通信。
我能够将数据从阅读器写入转发器,并且还得到一个中断 (XYZ)。现在我想回答读者。我通过 I2C 将数据写入邮箱。当读者阅读邮箱时,我收到超时或无效请求错误。
标签代码:
初始化:
- void MX_NFC_Init(void)
- const ST25DV_PASSWD st25dv_i2c_password = {.MsbPasswd = 0, .LsbPasswd=0};
- char txtbuf[] = "Initialize NFC-TagrnReset Mailbox and allow write to EEPROMrn Select NFC Type 5rn";
- HAL_UART_Transmit(&huart2, (uint8_t*) txtbuf, sizeof(txtbuf), 100);
- /* Init ST25DV driver */
- while( NFC04A1_NFCTAG_Init(NFC04A1_NFCTAG_INSTANCE) != NFCTAG_OK );
- /* Init GPO */
- MX_NFC04A1_GPO_Init();
- ST25DV_EN_STATUS MB_mode;
- /* If not activated, activate Mailbox, as long as MB is ON EEPROM is not available */
- NFC04A1_NFCTAG_ReadMBMode(NFC04A1_NFCTAG_INSTANCE, &MB_mode);
- if( MB_mode == ST25DV_DISABLE )
- ST25DV_I2CSSO_STATUS i2csso;
- ST25DV_PASSWD passwd;
- /* You need to present password before changing static configuration */
- NFC04A1_NFCTAG_ReadI2CSecuritySession_Dyn(NFC04A1_NFCTAG_INSTANCE, &i2csso );
- if( i2csso == ST25DV_SESSION_CLOSED )
- /* if I2C session is closed, present password to open session */
- passwd.MsbPasswd = 0; /* Default value for password */
- passwd.LsbPasswd = 0; /* change it if password has been modified */
- NFC04A1_NFCTAG_PresentI2CPassword(NFC04A1_NFCTAG_INSTANCE, passwd );
- NFC04A1_NFCTAG_WriteMBMode(NFC04A1_NFCTAG_INSTANCE,ST25DV_ENABLE);
- /*enable interrupts (I2C Protection) */
- NFC04A1_NFCTAG_ConfigIT(NFC04A1_NFCTAG_INSTANCE,
- ( ST25DV_GPO_FIELDCHANGE_MASK |
- ST25DV_GPO_RFPUTMSG_MASK |
- ST25DV_GPO_RFGETMSG_MASK |
- ST25DV_GPO_ENABLE_MASK ) );
- /* Close session as dynamic register doesn't need open session for modification */
- passwd.MsbPasswd = 123;
- passwd.LsbPasswd = 123;
- /* Enable Mailbox in dynamique register */
- NFC04A1_NFCTAG_SetMBEN_Dyn(NFC04A1_NFCTAG_INSTANCE);
- /* Check if Mailbox is available */
- NFC04A1_NFCTAG_ReadMBCtrl_Dyn( NFC04A1_NFCTAG_INSTANCE,&mbctrldynstatus );
- NfcTag_SelectProtocol(NFCTAG_TYPE5);
- /* Check if no NDEF detected, init mem in Tag Type 5 */
- if( NfcType5_NDEFDetection( ) != NDEF_OK )
- CCFileStruct.MagicNumber = NFCT5_MAGICNUMBER_E1_CCFILE;
- CCFileStruct.Version = NFCT5_VERSION_V1_0;
- CCFileStruct.MemorySize = ( ST25DV_MAX_SIZE / 8 ) & 0xFF;
- CCFileStruct.TT5Tag = 0x05;
- char txtbuf1[] = {"Initialization NFC Type5 Protocolrn"};
- /* Init of the Type Tag 5 component (M24LR) */
- while( NfcType5_TT5Init( ) != NFCTAG_OK );
处理传入的 GPO(GPOActivated 在 GPO 回调中设置)
- void MX_NFC4_NDEF_Process(void)
- ST25DV_FIELD_STATUS FieldStatus;
- uint8_t ITStatus;
- /* recognized interrupt */
- if( GPOActivated == 1 )
- /* check if RF-Field changed */ //check return if always on or only at beginning
- NFC04A1_NFCTAG_GetRFField_Dyn(NFC04A1_NFCTAG_INSTANCE, &FieldStatus );
- /* get all other interrput sources */
- NFC04A1_NFCTAG_ReadITSTStatus_Dyn(NFC04A1_NFCTAG_INSTANCE, &ITStatus);
- if( ITStatus == ST25DV_ITSTS_DYN_RFGETMSG_MASK)
- /* read mailbox */
- HAL_UART_Transmit(&huart2, "message getrn", 13, 50 );
- HAL_Delay(10);
- if( ITStatus == ST25DV_ITSTS_DYN_RFPUTMSG_MASK)
- HAL_UART_Transmit(&huart2, "message putrn", 13, 50 );
- uint8_t data[50] = {0};
- NFC04A1_NFCTAG_ReadMailboxData(NFC04A1_NFCTAG_INSTANCE, &data, 0, 49);
- //uint16_t NDEF_ReadText( sRecordInfo_t *pRecordStruct, NDEF_Text_info_t *pText )
- HAL_Delay(10);
- HAL_UART_Transmit(&huart2, "rnMessage is:rn", 16, 50);
- HAL_Delay(10);
- HAL_UART_Transmit(&huart2, data, 12, 50);
- HAL_Delay(10);
- HAL_UART_Transmit(&huart2, "rnrn", 14, 50);
- HAL_Delay(10);
- ST25DV_MB_CTRL_DYN_STATUS mbctrldynstatus;
- /* Write Data into Mailbox*/
- const uint8_t buf[]={"Hello Readerrn"};
- int32_t ret = 0;
- /* If MB is available, write data */
- if( (mbctrldynstatus.HostPutMsg == 0) && (mbctrldynstatus.RfPutMsg == 0) )
- ret = NFC04A1_NFCTAG_WriteMailboxData( NFC04A1_NFCTAG_INSTANCE, buf, 14 );
- __NOP();
- __NOP();
- else if( FieldStatus == ST25DV_FIELD_ON )
- /* power up device */
- HAL_UART_Transmit(&huart2, "RF field detectedrn", 20, 50 );
- HAL_Delay(10);
- GPOActivated = 0;
来自读者的代码:
- if( rfalNfcIsDevActivated( rfalNfcGetState() ) )
- rfalNfcGetActiveDevice( &nfcDevice );
- ledsOff();
- platformDelay(50);
- ndefDemoPrevFeature = 0xFF; /* Force the display of the prompt */
- uint8_t devUID[RFAL_NFCV_UID_LEN];
- ST_MEMCPY( devUID, nfcDevice->nfcid, nfcDevice->nfcidLen ); /* Copy the UID into local var */
- REVERSE_BYTES( devUID, RFAL_NFCV_UID_LEN ); /* Reverse the UID for display purposes */
- platformLog("ISO15693/NFC-V card found. UID: %srn", hex2Str(devUID, RFAL_NFCV_UID_LEN));
- platformLedOn(PLATFORM_LED_V_PORT, PLATFORM_LED_V_PIN);
- /* Try to read a register */
- uint8_t addr = 0x00;
- uint8_t regcontent[30] = {0x0};
- ReturnCode states[10] = {0};
- /* read enabled irq*/
- states[0] = rfalST25xVPollerReadConfiguration(RFAL_NFCV_REQ_FLAG_DEFAULT,
- nfcDevice->dev.nfcv.InvRes.UID, addr, ®content[0]);
- /* check if tag is powered by vcc */
- states[1] = rfalST25xVPollerReadDynamicConfiguration(RFAL_NFCV_REQ_FLAG_DEFAULT,
- nfcDevice->dev.nfcv.InvRes.UID, 0x02, ®content[1]);
- /* check if MB (fast transfer mode) is enabled */
- states[2] = rfalST25xVPollerReadConfiguration(RFAL_NFCV_REQ_FLAG_DEFAULT,
- nfcDevice->dev.nfcv.InvRes.UID, 0x0D, ®content[2]);
- states[3] = rfalST25xVPollerReadDynamicConfiguration(RFAL_NFCV_REQ_FLAG_DEFAULT,
- nfcDevice->dev.nfcv.InvRes.UID, 0x0D, ®content[3]);
- uint8_t txbuf[30] ={0};
- uint8_t msgdata[] = "Hello Tag";
- uint16_t len=0;
- uint8_t rxbuf[300] ={0};
- platformLog("rnrn written into Mailbox rnrn");
- /* write into Mailbox */
- states[4] = rfalST25xVPollerFastWriteMessage( RFAL_NFCV_REQ_FLAG_DEFAULT,
- nfcDevice->dev.nfcv.InvRes.UID, 11, msgdata, txbuf, 25);
- /* read dynamic configuration */
- /* Read from Mailbox */
- states[5] = rfalST25xVPollerFastReadMessage(RFAL_NFCV_REQ_FLAG_DEFAULT,
- nfcDevice->dev.nfcv.InvRes.UID, 0, 30, rxbuf, sizeof(rxbuf), &len);
- /* Loop until tag is removed from the field */
- platformLog("Operation completedrnTag can be removed from the fieldrn");
- rfalNfcvPollerInitialize();
- while (rfalNfcvPollerInventory( RFAL_NFCV_NUM_SLOTS_1, RFAL_NFCV_UID_LEN * 8U, nfcDevice->dev.nfcv.InvRes.UID, &invRes, &rcvdLen) == ERR_NONE)
- platformDelay(130);
- rfalNfcDeactivate( false );
- platformDelay( 500 );
- state = DEMO_ST_START_DISCOVERY;
1个回答
