嗨,我在多路复用模式下使用 OCTOSPI1 和 OCTOSPI2 以在内存映射模式下连接两个 S27KL0641 ram。
这些 Rams 用于 LTDC 帧缓冲区和其他应用程序数据(结构、数据......)。 我从 cubeMX 的 STM32Cube_FW_H7_V1.9.0DriversBSPComponentss70kl1281 和 STM32Cube_FW_H7_V1.9.0DriversBSPSTM32H735G-DK 开始初始化 OSPI,我更改了引脚影响,添加了 HAL_OSPIM_Config 并启用了 IoManager 时钟。 应用程序正常启动,但几分钟后进入 Hardfault。 根据 MPU initilization,问题发生得更快。 这是我的 MPU 配置 //ospi2数据 MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = OCTOSPI2_BASE; MPU_InitStruct.Size = MPU_REGION_SIZE_8MB; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER0; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0; MPU_InitStruct.SubRegionDisable = 0x00; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE; HAL_MPU_ConfigRegion(&MPU_InitStruct); //ospi 1数据 MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = OCTOSPI1_BASE; MPU_InitStruct.Size = MPU_REGION_SIZE_8MB; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER1; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0; MPU_InitStruct.SubRegionDisable = 0x00; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE; HAL_MPU_ConfigRegion(&MPU_InitStruct); //octospi1 帧增益,大小 = 0x200000 MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = OCTOSPI1_BASE; MPU_InitStruct.Size = MPU_REGION_SIZE_8MB; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER2; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1; MPU_InitStruct.SubRegionDisable = ~0x03; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE; HAL_MPU_ConfigRegion(&MPU_InitStruct); 这是Ram参数 hospi->Init.DualQuad = HAL_OSPI_DUALQUAD_DISABLE; hospi->Init.MemoryType = HAL_OSPI_MEMTYPE_HYPERBUS; hospi->Init.DeviceSize = Init->MemorySize; hospi->Init.FreeRunningClock = HAL_OSPI_FREERUNCLK_DISABLE; hospi->Init.ClockMode = HAL_OSPI_CLOCK_MODE_0; hospi->Init.WrapSize = HAL_OSPI_WRAP_128_BYTES; hospi->Init.SampleShifting = Init->SampleShifting; hospi->Init.DelayHoldQuarterCycle = HAL_OSPI_DHQC_ENABLE; hospi->Init.ChipSelectBoundary = 23; /* 内存管芯边界 2^23=8MBs*/ hospi->Init.Refresh = 275; //250; /*4us @100MHz*/ hospi->Init.FifoThreshold = 1; hospi->Init.ChipSelectHighTime = 20; hospi->Init.ClockPrescaler = 4; //从275Mhz开始计时 ospi_ram_init.LatencyType = BSP_OSPI_RAM_FIXED_LATENCY; ospi_ram_init.BurstType = BSP_OSPI_RAM_LINEAR_BURST; ospi_ram_init.BurstLength = BSP_OSPI_RAM_BURST_32_BYTES; 你能告诉我我的代码中是否有错误可能导致此问题吗?提前致谢 |
1个回答
我用你的代码测试过,我有同样的问题。
我设法解决了这个问题,这是由于一些时间问题,我必须启用 DelayBlock 才能使其工作 hospi->Init.DelayBlockBypass = HAL_OSPI_DELAY_BLOCK_USED; DelayBlock_Configure(DLYB_OCTOSPI1,1,50); |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2475 浏览 1 评论
3165 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1730 浏览 1 评论
3553 浏览 6 评论
5917 浏览 21 评论
892浏览 4评论
1266浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
532浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1250浏览 3评论
1304浏览 3评论
GMT+8, 2024-10-6 02:41 , Processed in 0.999761 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
