我对一切都使用 24 MHz 的 MSIS,如下所示:
- SET_BIT(RCC->CR, RCC_CR_MSISON);
- while (0 == (RCC->CR & RCC_CR_MSISRDY));
- SET_BIT(RCC->ICSCR1, RCC_ICSCR1_MSIRGSEL);
- MODIFY_REG(RCC->ICSCR1, RCC_ICSCR1_MSISRANGE, RCC_ICSCR1_MSISRANGE_0);
- // enable 32kHz clock crystal
- SET_BIT(PWR->DBPR, PWR_DBPR_DBP); // enable write access to backup domain
- MODIFY_REG(RCC->BDCR, RCC_BDCR_LSEDRV, RCC_BDCR_LSEDRV_0); // medium-low drive power
- SET_BIT(RCC->BDCR, RCC_BDCR_LSESYSEN); // enable propagation to other peripherals (like LPTIM4)
- SET_BIT(RCC->BDCR, RCC_BDCR_LSEON); // LL_RCC_LSE_Enable
- while (0 == READ_BIT(RCC->BDCR, RCC_BDCR_LSERDY)); // wait until ready
- // use it to trim the MSIS oscillator
- MODIFY_REG(RCC->CR, RCC_CR_MSIPLLSEL, RCC_CR_MSIPLLSEL);
- SET_BIT(RCC->CR, RCC_CR_MSIPLLEN);
- // set MSIS as system clock
- MODIFY_REG(RCC->CFGR1, RCC_CFGR1_SW, 0);
- while (0 != READ_BIT(RCC->CFGR1, RCC_CFGR1_SWS)); /* Wait until system clock switched to MSIS */
- SystemCoreClock = 24000000UL;
- SET_BIT(PWR->CR3, PWR_CR3_FSTEN); // fast startup of regulator
- MODIFY_REG(RCC->CFGR1, RCC_CFGR1_STOPWUCK, 0); /* use MSIS to wakeup from stop mode */
- CLEAR_BIT(RCC->CR, RCC_CR_MSIPLLFAST);
- CLEAR_BIT(FLASH->ACR, FLASH_ACR_PRFTEN | FLASH_ACR_LATENCY_Msk);
然后我像这样配置 PLL:
- SET_BIT(RCC->AHB2ENR1, RCC_AHB2ENR1_GPIOAEN);
- SET_BIT(RCC->AHB3ENR, RCC_AHB3ENR_PWREN);
- /* make sure PLL1 is off */
- CLEAR_BIT(RCC->CR, RCC_CR_PLL1ON);
- MODIFY_REG(RCC->PLL1CFGR,
- RCC_PLL1CFGR_PLL1SRC | RCC_PLL1CFGR_PLL1RGE |
- RCC_PLL1CFGR_PLL1FRACEN | RCC_PLL1CFGR_PLL1M |
- RCC_PLL1CFGR_PLL1PEN | RCC_PLL1CFGR_PLL1QEN | RCC_PLL1CFGR_PLL1REN,
- RCC_PLL1CFGR_PLL1SRC_0 /* MSI PLL */ |
- RCC_PLL1CFGR_PLL1RGE /* MSI input range between 8 and 16 MHz */ |
- RCC_PLL1CFGR_PLL1M_0 /* divide 24 MHz by 2 (prescaler before VCO, M) */ |
- RCC_PLL1CFGR_PLL1REN /* enable output of PLL1R */
- CLEAR_REG(RCC->PLL1FRACR); /* ensure a defined (but as far unused) fractional divider */
- MODIFY_REG(RCC->PLL1DIVR,
- RCC_PLL1DIVR_PLL1N | RCC_PLL1DIVR_PLL1R, /* clear what we need */
- (11 << RCC_PLL1DIVR_PLL1N_Pos) /* VCO is this many times higher than its input frequency */ |
- (0 << RCC_PLL1DIVR_PLL1R_Pos) /* post divider: value + 1 (?) */
然后我像这样设置 MCO:
- * MCO GPIO Configuration
- * CN13, Pin 2: PWM/D9
- * PA8 ------> MCO
- MODIFY_REG(GPIOA->MODER, GPIO_MODER_MODE8, (2 << GPIO_MODER_MODE8_Pos)); // set mode to alternate function
- CLEAR_BIT(GPIOA->OTYPER, GPIO_OTYPER_OT8); // set output type to push pull
- CLEAR_BIT(GPIOA->PUPDR, GPIO_PUPDR_PUPD8); // no pullup
- MODIFY_REG(GPIOA->OSPEEDR, GPIO_OSPEEDR_OSPEED8, (3 << GPIO_OSPEEDR_OSPEED8_Pos)); // set high speed for pins
- MODIFY_REG(GPIOA->AFR[1], GPIO_AFRH_AFSEL8, (0 << GPIO_AFRH_AFSEL8_Pos)); // select alternate function 0 (MCO) on pin
- * 0x00000000U MCO output disabled, no clock on MCO
- * RCC_CFGR1_MCOSEL_0 SYSCLK selection as MCO1 source
- * RCC_CFGR1_MCOSEL_1 MSIS selection as MCO1 source
- * (RCC_CFGR1_MCOSEL_0 | RCC_CFGR1_MCOSEL_1) HSI selection as MCO1 source
- * RCC_CFGR1_MCOSEL_2 HSE selection as MCO1 source
- * (RCC_CFGR1_MCOSEL_0 | RCC_CFGR1_MCOSEL_2) Main PLL selection as MCO1 source
- * (RCC_CFGR1_MCOSEL_1 | RCC_CFGR1_MCOSEL_2) LSI selection as MCO1 source
- * (RCC_CFGR1_MCOSEL_0 | RCC_CFGR1_MCOSEL_1| RCC_CFGR1_MCOSEL_2) LSE selection as MCO1 source
- * RCC_CFGR1_MCOSEL_3 HSI48 selection as MCO1 source
- * (RCC_CFGR1_MCOSEL_0 | RCC_CFGR1_MCOSEL_3) MSIK selection as MCO1 source
- MODIFY_REG(RCC->CFGR1, (RCC_CFGR1_MCOSEL | RCC_CFGR1_MCOPRE), (RCC_CFGR1_MCOSEL_0 | RCC_CFGR1_MCOSEL_2) | (3 << RCC_CFGR1_MCOPRE_Pos));
只是为了检查一下,这是我的示波器在 MCO (PA/CN13-D9) 上使用 SYSCLK 时给我的结果。它提供近乎完美的 3MHz (24MHz/8)。但是 PLL1R 为 18 MHz,这意味着 VCO 的频率为 144 MHz,而不是我配置的 132 MHz (24MHz/2*11)。我错过了什么?
1个回答
