firefly3399刷了两三个官方提供的固件都没法正常使用,都是在2~3秒就挂了 HDMI也没输出。
这里只贴后两秒的带你,输出打印log见附件:
DDR Version 1.24 20191016
In
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: DDR3, 800MHz
W FF != R
Cap error!
no stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x10006281, stride = 0x17
OUT
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 339
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 84689
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x4000, size:0x2000
GPT part: 1, name: trust, start:0x6000, size:0x2000
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x3c6000
GPT part: 7, name: userdata, start:0x420000, size:0xa6ffdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd8cd0
RunBL31 0x40000 @ 124587 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-g9dfc46412e-200628 #jincheng (May 25 2021 - 11:34:16 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 992 MiB
Sysmem: init
Relocation Offset: 3dbeb000, fdt: 3bddf4d8
Using default environment
dwmmc@fe320000: 1, sdhci@fe330000: 0
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
Android header version 0
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1100000 uV
In: serial
Out: serial
Err: serial
Model: Firefly-RK3399 Board (Linux Opensource)
Rockchip UBOOT DRM driver version: v1.0.1
xfer: num: 2, addr: 0x50
Monitor has basic audio support
Could not find baseparameter partition
mode:1920x1080
Detailed mode clock 148500 kHz, flags[5]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 100a
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 148000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'): 0
ANDROID: reboot reason: "recovery"
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000...
Fdt Ramdisk skip relocation
Booting Android Image at 0x0027f800 ...
Kernel load addr 0x00280000 size 22407 KiB
RAM disk load addr 0x0a200000 size 8762 KiB
Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 ... OK
'reserved-memory' ramoops@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831c317
No file: logo_kernel.bmp
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x0a200000 - 0x40000000 (size: 0x35e00000)
Total: 2958.217 ms
Starting kernel ...
[ 1.172599] IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[ 1.715149] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.715762] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.716496] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.718029] Module initialized.
[ 1.718790] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.719601] rk-vcodec ff650000.vpu_service: probe device
[ 1.720325] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.721457] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.722073] rk-vcodec ff650000.vpu_service: init success
[ 1.722796] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.723748] rk-vcodec ff660000.rkvdec: probe device
[ 1.724378] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.725319] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.725901] rk-vcodec ff660000.rkvdec: init success
[ 1.727799] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.728487] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.730734] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.731421] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.733266] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.734486] pwm-regulator: supplied by vcc5v0_sys
[ 1.735601] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.736754] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.738060] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.740610] [drm] Initialized drm 1.1.0 20060810
[ 1.745012] [drm] Rockchip DRM driver version: v1.0.1
[ 1.747690] mali ff9a0000.gpu: Failed to get regulator
[ 1.748158] mali ff9a0000.gpu: Power control initialization failed
[ 1.749048] Unable to detect cache hierarchy for CPU 0
[ 1.750356] brd: module loaded
[ 1.756077] loop: module loaded
[ 1.756922] zram: Added device: zram0
[ 1.757537] lkdtm: No crash points registered, enable through debugfs
[ 1.758475] Loading dl1825 driver
[ 1.760414] register spi return v = :0
[ 1.761280] tun: Universal TUN/TAP device driver, 1.6
[ 1.761734] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.763302] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.764009] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.764651] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.765161] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.765677] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.766392] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.767007] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.772565] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.773181] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.773634] Ring mode enabled
[ 1.773915] DMA HW capability register supported
[ 1.774328] Normal descriptors
[ 1.774635] RX Checksum Offload Engine supported (type 2)
[ 1.775127] Wake-Up On Lan supported
[ 1.775486] Enable RX Mitigation via HW Watchdog Timer
[ 1.844778] libphy: stmmac: probed
[ 1.845134] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.845705] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.848420] usbcore: registered new interface driver rtl8192cu
[ 1.849007] usbcore: registered new interface driver rndis_wlan
[ 1.849784] usbcore: registered new interface driver mt7601u
[ 1.850411] Rockchip WiFi SYS interface (V1.00) ...
[ 1.850932] usbcore: registered new interface driver rtl8150
[ 1.851501] usbcore: registered new interface driver r8152
[ 1.852045] usbcore: registered new interface driver asix
[ 1.852580] usbcore: registered new interface driver ax88179_178a
[ 1.853189] usbcore: registered new interface driver cdc_ether
[ 1.853755] usbcore: registered new interface driver rndis_host
[ 1.854367] usbcore: registered new interface driver cdc_ncm
[ 1.854915] usbcore: registered new interface driver qmi_wwan
[ 1.855483] usbcore: registered new interface driver cdc_mbim
[ 1.857886] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.863371] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 1.865067] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.865676] ehci-pci: EHCI PCI platform driver
[ 1.866137] ehci-platform: EHCI generic platform driver
[ 1.870130] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.870785] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.871592] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.878121] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.878814] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.879433] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.880073] usb usb1: Product: EHCI Host Controller
[ 1.880514] usb usb1: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 1.881014] usb usb1: SerialNumber: fe3c0000.usb
[ 1.881874] hub 1-0:1.0: USB hub found
[ 1.882252] hub 1-0:1.0: 1 port detected
[ 1.883161] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.883720] ohci-platform: OHCI generic platform driver
[ 1.884658] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.885442] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.886229] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.941335] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.941946] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.942600] usb usb2: Product: Generic Platform OHCI controller
[ 1.943138] usb usb2: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 1.943639] usb usb2: SerialNumber: fe3e0000.usb
[ 1.944685] hub 2-0:1.0: USB hub found
[ 1.945066] hub 2-0:1.0: 1 port detected
[ 1.946848] usbcore: registered new interface driver cdc_acm
[ 1.947363] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.948132] usbcore: registered new interface driver cdc_wdm
[ 1.948684] usbcore: registered new interface driver uas
[ 1.949285] usbcore: registered new interface driver usb-storage
[ 1.949914] usbcore: registered new interface driver usbserial
[ 1.950493] usbcore: registered new interface driver usbserial_generic
[ 1.951116] usbserial: USB Serial support registered for generic
[ 1.951697] usbcore: registered new interface driver ch341
[ 1.952231] usbserial: USB Serial support registered for ch341-uart
[ 1.952833] usbcore: registered new interface driver cp210x
[ 1.953380] usbserial: USB Serial support registered for cp210x
[ 1.953972] usbcore: registered new interface driver ftdi_sio
[ 1.954527] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.955335] usbcore: registered new interface driver keyspan
[ 1.955864] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.956601] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.957290] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.957965] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.958683] usbcore: registered new interface driver option
[ 1.959226] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.960031] usbcore: registered new interface driver oti6858
[ 1.960573] usbserial: USB Serial support registered for oti6858
[ 1.961169] usbcore: registered new interface driver pl2303
[ 1.961697] usbserial: USB Serial support registered for pl2303
[ 1.962289] usbcore: registered new interface driver qcserial
[ 1.962833] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.963523] usbcore: registered new interface driver sierra
[ 1.964051] usbserial: USB Serial support registered for Sierra USB modem
[ 1.966055] usbcore: registered new interface driver usbtouchscreen
[ 1.967039] .. rk pwm remotectl v1.1 init
[ 1.967724] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.968922] sensor_register_slave:mma8452,id=17
[ 1.969358] sensor_register_slave:lis3dh,id=7
[ 1.969762] sensor_register_slave:mma7660,id=18
[ 1.970188] sensor_register_slave:lsm303d,id=22
[ 1.970602] sensor_register_slave:gs_mc3230,id=23
[ 1.971020] [Gsensor] gsensor_init
[ 1.971365] sensor_register_slave:mpu6880_acc,id=24
[ 1.971802] sensor_register_slave:mpu6500_acc,id=25
[ 1.972250] sensor_register_slave:lsm330_acc,id=26
[ 1.972687] sensor_register_slave:akm8975,id=30
[ 1.973111] sensor_register_slave:akm8963,id=31
[ 1.973525] sensor_register_slave:l3g4200d,id=45
[ 1.973939] sensor_register_slave:l3g20d,id=46
[ 1.974352] sensor_register_slave:ewtsa,id=47
[ 1.974755] sensor_register_slave:lsm330_gyro,id=51
[ 1.975203] sensor_register_slave:cm3217,id=53
[ 1.975605] sensor_register_slave:cm3218,id=54
[ 1.976594] i2c /dev entries driver
[ 1.978295] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.979023] fan53555-reg: supplied by vcc5v0_sys
[ 1.982131] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.982828] fan53555-reg: supplied by vcc5v0_sys
[ 1.986040] rk808 0-001b: Pmic Chip id: 0x0
[ 1.989850] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.990496] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.991183] DCDC_REG1: supplied by vcc3v3_sys
[ 1.992507] DCDC_REG2: supplied by vcc3v3_sys
[ 1.993606] DCDC_REG3: supplied by vcc3v3_sys
[ 1.994410] DCDC_REG4: supplied by vcc3v3_sys
[ 1.995393] LDO_REG1: supplied by vcc3v3_sys
[ 1.997038] LDO_REG2: supplied by vcc3v3_sys
[ 1.998533] LDO_REG3: supplied by vcc3v3_sys
[ 2.000035] LDO_REG4: supplied by vcc3v3_sys
[ 2.001560] LDO_REG5: supplied by vcc3v3_sys
[ 2.003066] LDO_REG6: supplied by vcc3v3_sys
[ 2.004606] LDO_REG7: supplied by vcc3v3_sys
[ 2.006135] LDO_REG8: supplied by vcc3v3_sys
[ 2.007632] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.008465] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.012655] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.013858] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009af2000
[ 2.015654] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009af4000
[ 2.018004] fusb302 4-0022: Can't get property of role, set role to default DRP
[ 2.027846] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 2.028845] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input1
[ 2.029862] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009af6000
[ 2.032304] IR NEC protocol handler initialized
[ 2.033822] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 2.034426] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 2.037307] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[ 2.037895] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 2.040641] usbcore: registered new interface driver npu_acm
[ 2.041252] usbcore: registered new interface driver uvcvideo
[ 2.041762] USB Video Class driver (1.1.1)
[ 2.044838] Boot mode: normal
[ 2.047355] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.048365] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 2.050520] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.051480] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.a2fd257.20190430-133301
[ 2.052181] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 2.052634] rtk_btcoex: create workqueue
[ 2.052983] rtk_btcoex: Coex over UDP
[ 2.053607] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 2.054232] usbcore: registered new interface driver rtk_btusb
[ 2.054762] Bluetooth: Virtual HCI driver ver 1.5
[ 2.055333] Bluetooth: HCI UART driver ver 2.3
[ 2.055733] Bluetooth: HCI UART protocol H4 registered
[ 2.056207] Bluetooth: HCI UART protocol LL registered
[ 2.056661] Bluetooth: HCI UART protocol ATH3K registered
[ 2.057219] usbcore: registered new interface driver bfusb
[ 2.057772] usbcore: registered new interface driver btusb
[ 2.058921] cpu cpu0: bin=1
[ 2.059267] cpu cpu0: leakage=16
[ 2.072320] cpu cpu0: temp=25000, pvtm=143824 (145664 + -1840)
[ 2.073212] cpu cpu0: pvtm-volt-sel=1
[ 2.073613] cpu cpu0: bin-scale=34
[ 2.074388] cpu cpu4: bin=1
[ 2.074715] cpu cpu4: leakage=27
[ 2.087178] cpu cpu4: temp=26250, pvtm=152019 (153084 + -1065)
[ 2.087823] cpu cpu4: pvtm-volt-sel=1
[ 2.088234] cpu cpu4: bin-scale=17
[ 2.090180] cpu cpu0: avs=0
[ 2.090577] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.092058] cpu cpu0: failed to find power_model node
[ 2.093934] cpu cpu4: avs=0
[ 2.094349] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.096723] cpu cpu4: failed to find power_model node
[ 2.098390] sdhci: Secure Digital Host Controller Interface driver
[ 2.098935] sdhci: Copyright(c) Pierre Ossman
[ 2.099353] Synopsys Designware Multimedia Card Interface Driver
[ 2.101152] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.101814] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.102441] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.102999] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.103887] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.104728] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.105288] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.107192] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.107852] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.108483] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.109041] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.109927] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.111297] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.112158] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.125464] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.139027] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.140051] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.142485] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.143017] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.173603] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.175774] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.176818] usbcore: registered new interface driver usbhid
[ 2.177362] usbhid: USB HID core driver
[ 2.177838] inv_mpu_iio: inv_mpu_init:746
[ 2.181810] usbcore: registered new interface driver snd-usb-audio
[ 2.183774] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 2.184199] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 2.185031] rt5640 1-001c: Can not read property hp_det_gpio
[ 2.185542] rt5640 1-001c: Can not read property: linein-mute.
[ 2.204853] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 2.205569] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 2.206532] nf_conntrack version 0.5.0 (7588 buckets, 30352 max)
[ 2.207524] IPVS: Registered protocols (TCP, UDP)
[ 2.207986] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.208783] IPVS: Creating netns size=2104 id=0
[ 2.209249] IPVS: ipvs loaded.
[ 2.209540] IPVS: [rr] scheduler registered.
[ 2.210335] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.210918] Initializing XFRM netlink socket
[ 2.212158] NET: Registered protocol family 10
[ 2.213587] NET: Registered protocol family 17
[ 2.214011] NET: Registered protocol family 15
[ 2.214469] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.215619] Bridge firewalling registered
[ 2.216605] Bluetooth: RFCOMM socket layer initialized
[ 2.217151] Bluetooth: RFCOMM ver 1.11
[ 2.217515] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.218043] Bluetooth: HIDP socket layer initialized
[ 2.218582] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.219488] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.219985] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.220614] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.221262] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.222023] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.222837] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.223496] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.223964] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.224467] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.225441] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.226230] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.226959] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.227711] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.229336] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.229852] [BT_RFKILL]: ** disable irq
[ 2.230348] [BT_RFKILL]: bt_default device registered.
[ 2.230882] Key type dns_resolver registered
[ 2.231511] sensor_register_slave:mpu6880_gyro,id=50
[ 2.232335] ov13850 1-0036: driver version: 00.01.03
[ 2.235774] ov13850 1-0036: write SCCB_ID failed
[ 2.236397] ov13850: probe of 1-0036 failed with error -5
[ 2.237192] ov13850 1-0046: driver version: 00.01.03
[ 2.239975] ov13850 1-0046: write SCCB_ID failed
[ 2.240584] ov13850: probe of 1-0046 failed with error -5
[ 2.242141] mmc1: new HS400 MMC card at address 0001
[ 2.242586] Registered cp15_barrier emulation handler
[ 2.243124] Registered setend emulation handler
[ 2.243292] mmcblk1: mmc1:0001 008GE0 7.28 GiB
[ 2.243783] mmcblk1boot0: mmc1:0001 008GE0 partition 1 4.00 MiB
[ 2.244377] mmcblk1boot1: mmc1:0001 008GE0 partition 2 4.00 MiB
[ 2.244901] mmcblk1rpmb: mmc1:0001 008GE0 partition 3 4.00 MiB
[ 2.246675] Loading compiled-in X.509 certificates
[ 2.249476] Btrfs loaded
[ 2.250548] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.251035] rga2: Driver loaded successfully ver:3.02
[ 2.251893] rga2: Module initialized.
[ 2.253839] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator
[ 2.257841] rockchip-drm display-subsystem: dmc is disabled
[ 2.258916] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 2.259992] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008ef40f0)
[ 2.260814] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 2.261753] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008ef40f0)
[ 2.263307] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.263959] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.264872] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.268907] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008ee8948)
[ 2.270664] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 2.272318] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.273155] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008ee9978)
[ 2.273890] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.274505] [drm] No driver support for vblank timestamp query.
[ 2.299119] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.299720] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.300368] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.301502] hub 1-1:1.0: USB hub found
[ 2.301969] hub 1-1:1.0: 7 ports detected
[ 2.738002] vendor storage:20190527 ret = 0
[ 2.777451] Freeing drm_logo memory: 616K
[ 2.856157] Console: switching to colour frame buffer device 240x67
[ 2.911041] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.918347] mali ff9a0000.gpu: leakage=23
[ 2.942443] mali ff9a0000.gpu: temp=25625, pvtm=120267 (121003 + -736)
[ 2.943790] mali ff9a0000.gpu: pvtm-volt-sel=0
[ 2.944769] mali ff9a0000.gpu: avs=0
[ 2.946647] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.947784] mali ff9a0000.gpu: Protected mode not available
[ 2.949514] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.950255] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.951465] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.954305] mali ff9a0000.gpu: Probed as mali0
[ 2.961035] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.961905] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 2.962846] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.963728] xhci-hcd xhci-hcd.10.auto: irq 229, io mem 0xfe800000
[ 2.964668] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.965325] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.965977] usb usb3: Product: xHCI Host Controller
[ 2.966448] usb usb3: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 2.966955] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 2.968367] hub 3-0:1.0: USB hub found
[ 2.968768] hub 3-0:1.0: 1 port detected
[ 2.969819] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.970645] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.971529] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.972709] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.973356] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.974006] usb usb4: Product: xHCI Host Controller
[ 2.974471] usb usb4: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 2.974977] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.976330] hub 4-0:1.0: USB hub found
[ 2.976728] hub 4-0:1.0: 1 port detected
[ 2.979467] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.979965] usb usb4: USB disconnect, device number 1
[ 2.997346] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 2.998013] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 2.998761] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 3.000299] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 3.000773] usb usb3: USB disconnect, device number 1
[ 3.001791] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 3.004563] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 3.005910] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 3.006935] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 3.007847] xhci-hcd xhci-hcd.11.auto: irq 230, io mem 0xfe900000
[ 3.008973] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.009628] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.010353] usb usb3: Product: xHCI Host Controller
[ 3.010803] usb usb3: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 3.011338] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 3.013517] hub 3-0:1.0: USB hub found
[ 3.013947] hub 3-0:1.0: 1 port detected
[ 3.015070] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 3.016192] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 3.017051] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.018069] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.018733] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.019416] usb usb4: Product: xHCI Host Controller
[ 3.019867] usb usb4: Manufacturer: Linux 4.4.194+ xhci-hcd
[ 3.020400] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 3.022265] hub 4-0:1.0: USB hub found
[ 3.022682] hub 4-0:1.0: 1 port detected
[ 3.028496] ehci-platform fe380000.usb: EHCI Host Controller
[ 3.029707] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 3.030695] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 3.037369] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 3.038318] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.038932] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.039598] usb usb5: Product: EHCI Host Controller
[ 3.040038] usb usb5: Manufacturer: Linux 4.4.194+ ehci_hcd
[ 3.040561] usb usb5: SerialNumber: fe380000.usb
[ 3.042044] hub 5-0:1.0: USB hub found
[ 3.042457] hub 5-0:1.0: 1 port detected
[ 3.044291] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 3.045205] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 3.046050] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 3.101784] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.102444] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.103127] usb usb6: Product: Generic Platform OHCI controller
[ 3.103670] usb usb6: Manufacturer: Linux 4.4.194+ ohci_hcd
[ 3.104200] usb usb6: SerialNumber: fe3a0000.usb
[ 3.106444] hub 6-0:1.0: USB hub found
[ 3.106885] hub 6-0:1.0: 1 port detected
[ 3.110410] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.111154] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 3.111777] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 3.112372] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 3.113303] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 3.114323] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 3.114887] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 3.116292] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 3.129914] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.142557] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 3.145053] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[ 3.160573] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[ 3.168386] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input2
[ 3.171796] rockchip-cdndp-sound dp-sound: spdif-hifi <-> ff870000.spdif mapping ok
[ 3.172558] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 3.174955] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card2/input3
[ 3.177477]
[ 3.177627] =======================================================
[ 3.177746] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 3.177756] ======== dhd_wlan_init_plat_data ========
[ 3.177762] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.177776] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=70, oob_irq_flags=0x414
[ 3.177781] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 3.177784] dhd_wifi_platform_load: Enter
[ 3.177814] Power-up adapter 'DHD generic adapter'
[ 3.177888] wifi_platform_set_power = 1
[ 3.177893] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.177899] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.177905] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.183327] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.183885] =======================================================
[ 3.184458] Realtek 8723DU USB WiFi driver (Powered by Rockchip) init.
[ 3.185041] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.185480] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.185901] RTW: module init start
[ 3.186224] RTW: rtl8723du v5.6.5.1_34252.20190703_COEX20181130-2e2e
[ 3.186794] RTW: build time: May 25 2021 11:10:05
[ 3.187230] RTW: rtl8723du BT-Coex version = COEX20181130-2e2e
[ 3.187950] usbcore: registered new interface driver rtl8723du
[ 3.188505] RTW: module init ret=0
[ 3.190295] input: gpio-keys as /devices/platform/gpio-keys/input/input4
[ 3.191512] ==gsl_ts_init==
[ 3.191912] ret=0
[ 3.193180] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:06 UTC (1358499006)
[ 3.202676] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.204764] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.206848] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.210229] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.227658] vcc_sd: disabling
[ 3.227969] vcc_mipi: disabling
[ 3.228286] dvdd_1v2: disabling
u▒ 3.229553]
[ 3.266898] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒N<▒▒▒▒▒▒▒▒▒▒▒▒▒▒Ѐ▒ ▒h@▒▒▒▒▒H▒▒▒▒▒▒▒▒Y▒▒▒▒b
X"
▒▒▒▒F}▒#▒~t#▒▒▒▒v▒:▒▒▒4O(▒▒▒▒^▒▒@\▒
D▒'SH▒H
▒z<▒d%▒(
4▒b2▒ ABd▒^V▒4▒▒▒▒ cs▒▒▒p
▒s▒D▒▒@▒▒▒▒▒
<,▒▒▒▒▒▒DDR Version 1.24 20191016
In
W FF != R
Cap error!
no stride
OUT
CPUId = 0x0
ChipType = 0x10, 338
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 84608
SecureMode = 0
No find bl30.bin
Load OK, addr=0x200000, size=0x8741c
RunBL31 0x40000 @ 118941 us
NOTICE: BL31: v1.3(release):af49f67
NOTICE: BL31: Built : 16:55:08, May 19 2020
INFO: plat_rockchip_pmu_init(1191): pd status 3e
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-256-gebb61ff5 #4 Wed Apr 22 01:34:02 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Dec 14 2021 - 15:40:19)
CPU: rk3399
cpu version = 0
CPU's clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Board: Rockchip platform Board
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(000000003fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01e00000
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
rockusb key: key_rockusb.key.adc.keyValueLow = 0, key_rockusb.key.adc.keyValueHigh = 30
power key: bank-0 pin-5
can't find dts node for fixed
usb bc: can find node by path: /dwc-control-usb/usb_bc
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=975000,pwm_value=58
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Can't find dts node for fuel guage cw201x
can't find dts node for ec-battery
Can't find dts node for charger bq25700
invalide header tag
ca head not found
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
failed to find panel driver
read logo on state from dts [1]
no fuel gauge found
drm_rk_selete_output; fail get baseparameter
rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
dw_hdmi_setup HDMI mode
rockchip_panel_enable: failed to find panel prepare funcs
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
failed to display kernel logo
got recovery cmd from misc.
load fdt from resouce.
hwversion: disabled!
Secure Boot state: 0
kernel @ 0x00280000 (0x013c9008)
ramdisk @ 0x04bf0000 (0x00755ad0)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000004600000, end 0000000004616b1d ... OK
Add bank:0000000000200000, 0000000008200000
Add bank:000000000a200000, 0000000035e00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
[ 1.483952] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.484004] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.484081] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.484108] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.484177] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.484190] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.485247] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.485357] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.485375] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.485424] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.485481] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.486003] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.486183] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.497434] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.511827] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.512108] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.513826] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.513854] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.540817] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.542096] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.545750] usbcore: registered new interface driver usbhid
[ 1.545768] usbhid: USB HID core driver
[ 1.545886] inv_mpu_iio: inv_mpu_init:746
[ 1.546587] ashmem: initialized
[ 1.547924] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.551627] rknandbase v1.1 2016-11-08
[ 1.552122] usbcore: registered new interface driver snd-usb-audio
[ 1.553474] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.553555] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.553568] rt5640 1-001c: Can not read property: linein-mute.
[ 1.561710] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 1.561736] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 1.561862] u32 classifier
[ 1.561875] Actions configured
[ 1.561913] Netfilter messages via NETLINK v0.30.
[ 1.561968] nf_conntrack version 0.5.0 (7603 buckets, 30412 max)
[ 1.562288] ctnetlink v0.93: registering with nfnetlink.
[ 1.562840] xt_time: kernel timezone is -0000
[ 1.563546] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.563778] arp_tables: (C) 2002 David S. Miller
[ 1.564149] Initializing XFRM netlink socket
[ 1.564591] NET: Registered protocol family 10
[ 1.565606] mip6: Mobile IPv6
[ 1.565643] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.566672] sit: IPv6 over IPv4 tunneling driver
[ 1.567138] NET: Registered protocol family 17
[ 1.567168] NET: Registered protocol family 15
[ 1.567203] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.567364] Bridge firewalling registered
[ 1.567402] Ebtables v2.0 registered
[ 1.567611] Bluetooth: RFCOMM TTY layer initialized
[ 1.567633] Bluetooth: RFCOMM socket layer initialized
[ 1.567662] Bluetooth: RFCOMM ver 1.11
[ 1.567681] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.567690] Bluetooth: BNEP filters: protocol multicast
[ 1.567705] Bluetooth: BNEP socket layer initialized
[ 1.567717] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.567728] Bluetooth: HIDP socket layer initialized
[ 1.567779] l2tp_core: L2TP core driver, V2.0
[ 1.567798] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.567816] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.568114] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.568172] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.568182] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.568190] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.568263] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.568271] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.568281] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.568330] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.568665] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.568710] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.568740] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.568770] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.569256] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.569308] [BT_RFKILL]: ** disable irq
[ 1.569434] [BT_RFKILL]: bt_default device registered.
[ 1.569580] sensor_register_slave:mpu6500_gyro,id=49
[ 1.569599] sensor_register_slave:mpu6880_gyro,id=50
[ 1.570757] Registered cp15_barrier emulation handler
[ 1.570855] Registered setend emulation handler
[ 1.571408] registered taskstats version 1
[ 1.572115] rockchip ion idev is NULL
[ 1.572133] rga2 ff680000.rga: rga ion client create success!
[ 1.572279] rga2: Driver loaded successfully ver:3.02
[ 1.572443] rga2: Module initialized.
[ 1.576570] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[ 1.578090] rockchip-drm display-subsystem: defer getting devfreq
[ 1.578365] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.578566] rockchip-vop ff900000.vop: unable to request PWM
[ 1.578586] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.578633] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.578753] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.578764] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.579081] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.579119] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.579196] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.581376] mmc1: MAN_BKOPS_EN bit is not set
[ 1.583564] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.583913] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.584172] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.584183] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.584189] [drm] No driver support for vblank timestamp query.
[ 1.584636] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.599033] mmc1: new HS400 MMC card at address 0001
[ 1.599470] mmcblk1: mmc1:0001 008GE0 7.28 GiB
[ 1.599655] mmcblk1boot0: mmc1:0001 008GE0 partition 1 4.00 MiB
[ 1.599825] mmcblk1boot1: mmc1:0001 008GE0 partition 2 4.00 MiB
[ 1.599995] mmcblk1rpmb: mmc1:0001 008GE0 partition 3 4.00 MiB
[ 1.600353] parameter: 0x000000000 -- 0x000400000 (4 MB)
[ 1.600367] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 1.600375] trust: 0x000800000 -- 0x000c00000 (4 MB)
[ 1.600382] misc: 0x000c00000 -- 0x001000000 (4 MB)
[ 1.600390] resource: 0x001000000 -- 0x002000000 (16 MB)
[ 1.600397] kernel: 0x002000000 -- 0x003800000 (24 MB)
[ 1.600404] boot: 0x003800000 -- 0x005800000 (32 MB)
[ 1.600412] recovery: 0x005800000 -- 0x009800000 (64 MB)
[ 1.600419] backup: 0x009800000 -- 0x010800000 (112 MB)
[ 1.600427] cache: 0x010800000 -- 0x018800000 (128 MB)
[ 1.600440] system: 0x018800000 -- 0x078800000 (1536 MB)
[ 1.600448] oem: 0x078800000 -- 0x098800000 (512 MB)
[ 1.600455] metadata: 0x098800000 -- 0x099800000 (16 MB)
[ 1.600463] verity_mode: 0x099800000 -- 0x099808000 (0 MB)
[ 1.600470] reserved: 0x099808000 -- 0x099c08000 (4 MB)
[ 1.600477] frp: 0x099c08000 -- 0x099c88000 (0 MB)
[ 1.600484] userdata: 0x099c88000 -- 0x1d1c00000 (4991 MB)
[ 1.600543] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.637466] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.762422] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.762500] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.762528] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.763877] hub 1-1:1.0: USB hub found
[ 1.764108] hub 1-1:1.0: 7 ports detected
[ 2.075907] vendor storage:20160801 ret = 0
[ 2.084331] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.103894] mali ff9a0000.gpu: leakage=23
[ 2.129061] mali ff9a0000.gpu: temp=27500, pvtm=120363 (121007 + -644)
[ 2.130117] mali ff9a0000.gpu: pvtm-volt-sel=0
[ 2.132402] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.133237] mali ff9a0000.gpu: Protected mode not available
[ 2.134210] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.134402] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.134673] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.135858] mali ff9a0000.gpu: Probed as mali0
[ 2.140200] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.140528] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.140798] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.140852] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe800000
[ 2.141005] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.141027] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.141035] usb usb3: Product: xHCI Host Controller
[ 2.141041] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.141048] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.141365] hub 3-0:1.0: USB hub found
[ 2.141397] hub 3-0:1.0: 1 port detected
[ 2.141577] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.141685] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.141739] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.141799] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.141807] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.141814] usb usb4: Product: xHCI Host Controller
[ 2.141820] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.141826] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 2.142101] hub 4-0:1.0: USB hub found
[ 2.142135] hub 4-0:1.0: 1 port detected
[ 2.143173] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 2.143224] usb usb4: USB disconnect, device number 1
[ 2.159750] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 2.159784] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 2.159821] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 2.160116] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 2.160150] usb usb3: USB disconnect, device number 1
[ 2.160655] xhci-hcd xhci-hcd.11.auto: USB bus 3 deregistered
[ 2.161512] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 2.161780] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 3
[ 2.162096] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.162141] xhci-hcd xhci-hcd.12.auto: irq 234, io mem 0xfe900000
[ 2.162372] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.162389] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.162398] usb usb3: Product: xHCI Host Controller
[ 2.162407] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.162415] usb usb3: SerialNumber: xhci-hcd.12.auto
[ 2.162904] hub 3-0:1.0: USB hub found
[ 2.162963] hub 3-0:1.0: 1 port detected
[ 2.163401] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 2.163559] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 4
[ 2.163789] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.164065] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.164082] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.164091] usb usb4: Product: xHCI Host Controller
[ 2.164099] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.164107] usb usb4: SerialNumber: xhci-hcd.12.auto
[ 2.164555] hub 4-0:1.0: USB hub found
[ 2.164611] hub 4-0:1.0: 1 port detected
[ 2.168541] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.168765] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 2.169025] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.180742] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.180917] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.180938] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.180947] usb usb5: Product: EHCI Host Controller
[ 2.180956] usb usb5: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.180964] usb usb5: SerialNumber: fe380000.usb
[ 2.181738] hub 5-0:1.0: USB hub found
[ 2.181797] hub 5-0:1.0: 1 port detected
[ 2.182754] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.183143] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 2.183302] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.238196] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.238258] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.238473] usb usb6: Product: Generic Platform OHCI controller
[ 2.238690] usb usb6: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.238907] usb usb6: SerialNumber: fe3a0000.usb
[ 2.239797] hub 6-0:1.0: USB hub found
[ 2.239872] hub 6-0:1.0: 1 port detected
[ 2.241355] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.241656] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.241805] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.242037] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.242250] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.242485] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.242669] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.243218] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.254137] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.267685] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.270273] rockchip-dmc dmc: Failed to get leakage
[ 2.270496] rockchip-dmc dmc: Failed to get pvtm
[ 2.271525] rockchip-dmc dmc: could not find power_model node
[ 2.276727] devfreq dmc: Couldn't update frequency transition information.
[ 2.277340] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[ 2.282813] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[ 2.284733] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input2
[ 2.285548] rockchip-cdndp-sound dp-sound: spdif-hifi <-> ff870000.spdif mapping ok
[ 2.285755] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 2.286318] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card2/input3
[ 2.287746] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
[ 2.288364] It doesn't contain Rogue gpu
[ 2.304687] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.306253] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.307798] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.310550] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.312532] vdd3v3_pcie: disabling
[ 2.312591] vcc_sd: disabling
[ 2.313070] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-5008918', rk_ko_ver is '5', built at '18:09:04', on 'Dec 13 2021'.
[ 2.313538] Mali: Mali device driver loaded
[ 2.314612] input: rk29-keypad as /devices/platform/rockchip-key/input/input4
v▒ 2.316662]
[ 2.364646] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.373169] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 317
[ 2.375848] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.375896] mmc2: new ultra high speed SDR104 SDIO card at address 0001
In
W FF != R
Cap error!
no stride
OUT
CPUId = 0x0
ChipType = 0x10, 337
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 84661
SecureMode = 0
No find bl30.bin
RunBL31 0x40000 @ 119199 us
INFO: SPSR = 0x3c9
CPU: rk3399
cpu version = 0
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
pmic:rk808
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
Starting kernel ...
[ 1.512626] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.516314] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.519673] usbcore: registered new interface driver usbhid
[ 1.519708] usbhid: USB HID core driver
[ 1.519868] inv_mpu_iio: inv_mpu_init:746
[ 1.520732] ashmem: initialized
[ 1.522574] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.527511] rknandbase v1.1 2016-11-08
[ 1.528232] usbcore: registered new interface driver snd-usb-audio
[ 1.530254] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.530419] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.530556] rt5640 1-001c: Can not read property: linein-mute.
[ 1.540763] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 1.540870] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 1.541254] u32 classifier
[ 1.541311] Actions configured
[ 1.541569] Netfilter messages via NETLINK v0.30.
[ 1.541812] nf_conntrack version 0.5.0 (7603 buckets, 30412 max)
[ 1.542388] ctnetlink v0.93: registering with nfnetlink.
[ 1.543335] xt_time: kernel timezone is -0000
[ 1.544950] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.545323] arp_tables: (C) 2002 David S. Miller
[ 1.546206] Initializing XFRM netlink socket
[ 1.546847] NET: Registered protocol family 10
[ 1.548132] mip6: Mobile IPv6
[ 1.548211] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.549626] sit: IPv6 over IPv4 tunneling driver
[ 1.550316] NET: Registered protocol family 17
[ 1.550399] NET: Registered protocol family 15
[ 1.550613] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.551465] Bridge firewalling registered
[ 1.551597] Ebtables v2.0 registered
[ 1.552046] Bluetooth: RFCOMM TTY layer initialized
[ 1.552068] Bluetooth: RFCOMM socket layer initialized
[ 1.552133] Bluetooth: RFCOMM ver 1.11
[ 1.552158] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.552168] Bluetooth: BNEP filters: protocol multicast
[ 1.552182] Bluetooth: BNEP socket layer initialized
[ 1.552198] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.552211] Bluetooth: HIDP socket layer initialized
[ 1.552284] l2tp_core: L2TP core driver, V2.0
[ 1.552335] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.552355] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.552860] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.552999] mmc1: MAN_BKOPS_EN bit is not set
[ 1.553036] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.553068] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.553078] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.553174] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.553183] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.553195] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.553272] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.553897] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.554006] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.554068] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.554106] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.554513] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.554571] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 1.554611] [BT_RFKILL]: ** disable irq
[ 1.554768] [BT_RFKILL]: bt_default device registered.
[ 1.555064] sensor_register_slave:mpu6500_gyro,id=49
[ 1.555111] sensor_register_slave:mpu6880_gyro,id=50
[ 1.557089] Registered cp15_barrier emulation handler
[ 1.557261] Registered setend emulation handler
[ 1.558159] registered taskstats version 1
[ 1.559223] rockchip ion idev is NULL
[ 1.559240] rga2 ff680000.rga: rga ion client create success!
[ 1.559488] rga2: Driver loaded successfully ver:3.02
[ 1.559857] rga2: Module initialized.
[ 1.561485] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[ 1.563533] rockchip-drm display-subsystem: defer getting devfreq
[ 1.563936] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.564285] rockchip-vop ff900000.vop: unable to request PWM
[ 1.564342] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.564403] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.564632] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.564680] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.565222] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.565270] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.565423] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.567622] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.568258] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.568932] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.569048] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.569099] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.569108] [drm] No driver support for vblank timestamp query.
[ 1.569458] mmc1: new HS400 MMC card at address 0001
[ 1.570417] mmcblk1: mmc1:0001 008GE0 7.28 GiB
[ 1.570859] mmcblk1boot0: mmc1:0001 008GE0 partition 1 4.00 MiB
[ 1.571201] mmcblk1boot1: mmc1:0001 008GE0 partition 2 4.00 MiB
[ 1.571551] mmcblk1rpmb: mmc1:0001 008GE0 partition 3 4.00 MiB
[ 1.572023] parameter: 0x000000000 -- 0x000400000 (4 MB)
[ 1.572058] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 1.572069] trust: 0x000800000 -- 0x000c00000 (4 MB)
[ 1.572079] misc: 0x000c00000 -- 0x001000000 (4 MB)
[ 1.572090] resource: 0x001000000 -- 0x002000000 (16 MB)
[ 1.572100] kernel: 0x002000000 -- 0x003800000 (24 MB)
[ 1.572111] boot: 0x003800000 -- 0x005800000 (32 MB)
[ 1.572121] recovery: 0x005800000 -- 0x009800000 (64 MB)
[ 1.572132] backup: 0x009800000 -- 0x010800000 (112 MB)
[ 1.572143] cache: 0x010800000 -- 0x018800000 (128 MB)
[ 1.572192] system: 0x018800000 -- 0x078800000 (1536 MB)
[ 1.572204] oem: 0x078800000 -- 0x098800000 (512 MB)
[ 1.572216] metadata: 0x098800000 -- 0x099800000 (16 MB)
[ 1.572227] verity_mode: 0x099800000 -- 0x099808000 (0 MB)
[ 1.572238] reserved: 0x099808000 -- 0x099c08000 (4 MB)
[ 1.572248] frp: 0x099c08000 -- 0x099c88000 (0 MB)
[ 1.572259] userdata: 0x099c88000 -- 0x1d1c00000 (4991 MB)
[ 1.572344] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.609356] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.735633] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.735723] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.735746] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.737288] hub 1-1:1.0: USB hub found
[ 1.737960] hub 1-1:1.0: 7 ports detected
[ 2.046994] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.057728] vendor storage:20160801 ret = 0
[ 2.060953] mali ff9a0000.gpu: leakage=23
[ 2.084724] mali ff9a0000.gpu: temp=29375, pvtm=120408 (120960 + -552)
[ 2.085923] mali ff9a0000.gpu: pvtm-volt-sel=0
[ 2.087637] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.088133] mali ff9a0000.gpu: Protected mode not available
[ 2.088963] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.089090] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.089388] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.090187] mali ff9a0000.gpu: Probed as mali0
[ 2.094834] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.095016] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.095269] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.095327] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe800000
[ 2.095681] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.095760] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.095979] usb usb3: Product: xHCI Host Controller
[ 2.096195] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.096412] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.096958] hub 3-0:1.0: USB hub found
[ 2.097101] hub 3-0:1.0: 1 port detected
[ 2.097477] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.097616] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.097775] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.098014] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.098180] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.098398] usb usb4: Product: xHCI Host Controller
[ 2.098616] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.098834] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 2.099390] hub 4-0:1.0: USB hub found
[ 2.099533] hub 4-0:1.0: 1 port detected
[ 2.100894] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 2.100926] usb usb4: USB disconnect, device number 1
[ 2.105106] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 2.105359] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 5
[ 2.105920] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.106141] xhci-hcd xhci-hcd.12.auto: irq 234, io mem 0xfe900000
[ 2.106506] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.106548] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.106763] usb usb5: Product: xHCI Host Controller
[ 2.106979] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.107194] usb usb5: SerialNumber: xhci-hcd.12.auto
[ 2.107842] hub 5-0:1.0: USB hub found
[ 2.107903] hub 5-0:1.0: 1 port detected
[ 2.108364] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 2.108717] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 6
[ 2.108819] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.109066] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.109211] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.109426] usb usb6: Product: xHCI Host Controller
[ 2.109642] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.109860] usb usb6: SerialNumber: xhci-hcd.12.auto
[ 2.110501] hub 6-0:1.0: USB hub found
[ 2.110563] hub 6-0:1.0: 1 port detected
[ 2.113565] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.114025] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 7
[ 2.114405] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.117361] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 2.117384] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 2.117414] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 2.117677] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 2.117716] usb usb3: USB disconnect, device number 1
[ 2.118284] xhci-hcd xhci-hcd.11.auto: USB bus 3 deregistered
[ 2.125848] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.125992] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.126008] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.126017] usb usb7: Product: EHCI Host Controller
[ 2.126026] usb usb7: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.126034] usb usb7: SerialNumber: fe380000.usb
[ 2.126447] hub 7-0:1.0: USB hub found
[ 2.126640] hub 7-0:1.0: 1 port detected
[ 2.127371] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.127648] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.127903] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.183380] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.183448] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.183664] usb usb3: Product: Generic Platform OHCI controller
[ 2.183880] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[ 2.184098] usb usb3: SerialNumber: fe3a0000.usb
[ 2.184706] hub 3-0:1.0: USB hub found
[ 2.184787] hub 3-0:1.0: 1 port detected
[ 2.185823] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.186013] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.186166] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.186392] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.186610] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.186840] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.187032] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.187493] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.199411] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.212835] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.214076] rockchip-dmc dmc: Failed to get leakage
[ 2.214195] rockchip-dmc dmc: Failed to get pvtm
[ 2.217991] rockchip-dmc dmc: could not find power_model node
[ 2.228522] devfreq dmc: Couldn't update frequency transition information.
[ 2.231100] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[ 2.238365] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[ 2.245105] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input2
[ 2.247402] rockchip-cdndp-sound dp-sound: spdif-hifi <-> ff870000.spdif mapping ok
[ 2.247512] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 2.248984] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card2/input3
[ 2.250829] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:04 UTC (1358499004)
[ 2.252660] It doesn't contain Rogue gpu
[ 2.265762] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.267502] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.269133] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.272020] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.285016] vdd3v3_pcie: disabling
[ 2.285072] vcc_sd: disabling
[ 2.285377] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-5008918', rk_ko_ver is '5', built at '18:09:04', on 'Dec 13 2021'.
[ 2.285789] Mali: Mali device driver loaded
[ 2.286473] input: rk29-keypad as /devices/platform/rockchip-key/input/input4
v▒ 2.288512]
[ 2.327416] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.336843] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 317
[ 2.339892] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.339943] mmc2: new ultra high speed SDR104 SDIO card at address 0001
