(仍在 DISTRO_VERSION =“3.1.11-snapshot-20221108”)
我试图创建一个自定义机器。
MX
└── STM32mp1-自定义
├── 内核
│ └── stm32mp1-custom.dts
├── optee-os
├── tf-a
│ ├── stm32mp15-ddr-512m-fw-config.dts
│ ├── stm32mp1-custom.dts
│ └── stm32mp1-custom-fw-config.dts
└── u-boot
└── stm32mp1-custom-u-boot.dts
对于第一个“简单”测试,我获取了 stm32mp157f-dk2 板的 dts 文件(而不是来自 CubeMX)。
机器配置如下所示:
- #@TYPE: Machine
- #@NAME: stm32mp15-custom
- #@DESCRIPtiON: Configuration for STM32CubeMX generated project
- #@NEEDED_BSPLAYERS: layers/meta-openembedded/meta-oe layers/meta-openembedded/meta-python
- # Default machine configuration sections
- include conf/machine/include/st-machine-common-stm32mp.inc
- include conf/machine/include/st-machine-providers-stm32mp.inc
- # Define specific common machine name
- MACHINEOVERRIDES .= ":stm32mpcommonmx:stm32mp15commonmx"
- MACHINEOVERRIDES .= ":stm32mp1common:stm32mp15common"
- # Chip architecture
- DEFAULTTUNE = "cortexa7thf-neon-vfpv4"
- include conf/machine/include/tune-cortexa7.inc
- # Machine settings
- STM32MP_DEVICETREE = "${CUBEMX_DTB}"
- # Machine features (default for stm32mp1 like)
- MACHINE_FEATURES += "splashscreen"
- MACHINE_FEATURES += "watchdog"
- MACHINE_FEATURES += "${@'gpu' if d.getVar('ACCEPT_EULA_'+d.getVar('MACHINE')) == '1' else ''}"
- MACHINE_FEATURES += "m4copro"
- # Device Storage
- # Enable the board device storage support with CUBEMX_DTB according to BOOTDEVICE_LABELS
- DEVICE_BOARD_ENABLE_NAND += "${@bb.utils.contains('BOOTDEVICE_LABELS', 'nand-4-256', '${CUBEMX_DTB}', '', d)}"
- DEVICE_BOARD_ENABLE_NOR += "${@bb.utils.contains('BOOTDEVICE_LABELS', 'nor-sdcard' , '${CUBEMX_DTB}', '', d)}"
- DEVICE_BOARD_ENABLE_EMMC += "${@bb.utils.contains('BOOTDEVICE_LABELS', 'emmc', '${CUBEMX_DTB}', '', d)}"
- DEVICE_BOARD_ENABLE_SDCARD += "${@bb.utils.contains('BOOTDEVICE_LABELS', 'sdcard', '${CUBEMX_DTB}', '', d)}"
- # Flashlayout
- # Set the FLASHLAYOUT_TYPE_LABELS to CUBEMX_DTB according to BOOTDEVICE_LABELS
- FLASHLAYOUT_TYPE_LABELS_emmc = "${@bb.utils.contains('BOOTDEVICE_LABELS', 'emmc', '${CUBEMX_DTB}', '', d)}"
- FLASHLAYOUT_TYPE_LABELS_nand-4-256 = "${@bb.utils.contains('BOOTDEVICE_LABELS', 'nand-4-256', '${CUBEMX_DTB}', '', d)}"
- FLASHLAYOUT_TYPE_LABELS_nor-sdcard = "${@bb.utils.contains('BOOTDEVICE_LABELS', 'nor-sdcard' , '${CUBEMX_DTB}', '', d)}"
- FLASHLAYOUT_TYPE_LABELS_sdcard = "${@bb.utils.contains('BOOTDEVICE_LABELS', 'sdcard', '${CUBEMX_DTB}', '', d)}"
- # Specific settings for 'extensible' and 'deleteall' configurations
- FLASHLAYOUT_CONFIG_LABELS_deleteall = "cubemx"
- FLASHLAYOUT_TYPE_LABELS_deleteall_cubemx = "${CUBEMX_DTB}"
- FLASHLAYOUT_TYPE_LABELS_extensible = "${CUBEMX_DTB}"
- # CubeMX extra config
- ENABLE_CUBEMX_DTB ?= "1"
- # User machine customization sections
- # Boot Scheme
- BOOTSCHEME_LABELS += "trusted"
- #BOOTSCHEME_LABELS += "optee"
- # Boot Device Choice
- # Define the boot device supported
- BOOTDEVICE_LABELS += "sdcard"
- BOOTDEVICE_LABELS += "emmc"
- BOOTDEVICE_LABELS += "nand-4-256"
- BOOTDEVICE_LABELS += "nor-sdcard"
- # Support Feature Choice
- # Define the features to enable on board
- #MACHINE_FEATURES += "bluetooth"
- #MACHINE_FEATURES += "wifi"
- # Specific firmwares and kernel modules configuration
- # Set the list of kernel module to be auto-loaded during boot
- #KERNEL_MODULE_AUTOLOAD += ""
- # Set Bluetooth related package list needed when 'bluetooth' feature is enabled
- #BLUETOOTH_LIST += ""
- # Set Wifi related package list needed when 'wifi' feature is enabled
- #WIFI_LIST += ""
- # CubeMX Project Config
- # Assign CubeMX Board devicetree and project path name
- #CUBEMX_DTB = "stm32mp157c-my-demo"
- CUBEMX_DTB = "stm32mp1-custom"
- #CUBEMX_PROJECT = "mx/STM32MP157C-EV1/my-demo/DeviceTree/my-demo"
- #CUBEMX_PROJECT = "mx/stm32mp1-custom/DeviceTree/custom"
- CUBEMX_PROJECT = "mx/stm32mp1-custom"
- # Indicate which STM32MP package are used: 'A', 'C', 'D' or 'F'
- CUBEMX_SOC_PACKAGE = "C"
- # Indicate the size of DDR available on BOARD: 512 or 1024 (size in MB unit)
- CUBEMX_BOARD_DDR_SIZE = "512"
- #CUBEMX_BOARD_DDR_SIZE = "1024"
- # Indicate if you like to disable the DVFS which are activated by default
- CUBEMX_SOC_DVFS_OFF = "0"
当我现在尝试构建“分发”图像时,大多数似乎都有效,但不会生成 tf-a 的 stm32mp1-custom-trusted.dtb 文件。
- bitbake core-image-minimal
- ERROR: tf-a-stm32mp-v2.4-stm32mp-r2-r0 do_deploy: Missing u-boot-stm32mp1-custom-trusted.dtb file in folder: /home/jenkins/Development/SW_APP/_tmp/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxweston-stm32mp1-custom/tmp-glibc/deploy/images/stm32mp1-custom/u-boot
- ERROR: tf-a-stm32mp-v2.4-stm32mp-r2-r0 do_deploy: Execution of '/home/jenkins/Development/SW_APP/_tmp/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxweston-stm32mp1-custom/tmp-glibc/work/stm32mp1_custom-ostl-linux-gnueabi/tf-a-stm32mp/v2.4-stm32mp-r2-r0/temp/run.do_deploy.3121445' failed with exit code 1:
- WARNING: exit code 1 from a shell command.
- ERROR: Logfile of failure stored in: /home/jenkins/Development/SW_APP/_tmp/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxweston-stm32mp1-custom/tmp-glibc/work/stm32mp1_custom-ostl-linux-gnueabi/tf-a-stm32mp/v2.4-stm32mp-r2-r0/temp/log.do_deploy.3121445
- ERROR: Task (/home/jenkins/Development/SW_APP/_tmp/openstlinux-5.10-dunfell-mp1-21-11-17/layers/meta-st/meta-st-stm32mp/recipes-bsp/trusted-firmware-a/tf-a-stm32mp_2.4.bb:do_deploy) failed with exit code '1'
当我之前使用 MACHINE=stm32mp1 时,总是会生成相应的 u-boot-stm32mp157*-trusted.dtb 文件并且构建成功。
我假设我缺少步骤。
我知道有构建 tf-a-bl2 和 bl32 的手动步骤,但我缺少的是在 yocto 构建环境中自定义机器所需的必要步骤的文档。
谢谢!
1个回答
