电子发烧友论坛|
创建方法如下: sudo -s touch grade.sh vim grade.sh #/bin/bash #Verson:0.1 #Auther:diql #Pragram:This pragram is calculation your grade #import an argument read -p "Please input your grade:" x declare -i x #jugemet $x value is none or not if [ "$x" == "" ];then echo "You don't input your grade...." exit 5 fi #jugement the gread level if [[ "$x" -ge "90" && "$x" -le "100" ]];then echo "Congratulation,Your grade is A." elif [[ "$x" -ge "80" && "$x" -le "89" ]];then echo "Good,Your grade is B." elif [[ "$x" -ge "70" && "$x" -le "79" ]];then echo "Ok.Your grade is C." elif [[ "$x" -ge "60" && "$x" -le "69" ]];then echo "Yeah,Your grade is D." elif [[ "$x" -lt "60" ]];then echo "Right,Your grade is F." else echo "Unknow argument...." fi 键入: esc :wq chmod 700 grade.sh ./grade.sh ./build.sh all /etc/update.sh ----------------------------------------------------------- 附带pwm071.sh ---------------------------------------------- #! /bin/sh if [ $# != 2 ]; then echo "$0 echo "User:$0 P3_7 1" exit 0 fi VAL=$1 N=${VAL##*_} T=${VAL#*P} M=${T%_*} GPIOID=$((${M} * 8 + ${N} + 120)) echo "==== GPIOID ${GPIOID} ======" if [ ! -d /sys/class/gpio/gpio$GPIOID ]; then echo $GPIOID > /sys/class/gpio/export echo out > /sys/class/gpio/gpio${GPIOID}/direction fi echo "===$1===$2" echo $2 > /sys/class/gpio/gpio${GPIOID}/value for((i=1;i<=10;i+=1)) do sleep 1 echo $i echo 1 > /sys/class/gpio/gpio${GPIOID}/value sleep 1 echo 0 > /sys/class/gpio/gpio${GPIOID}/value done |
只有小组成员才能发言,加入小组>>
【飞凌OK153-S开发板评测】系统实时性及codesys测试
2342 浏览 0 评论
【OK3506-S12Mini试用评测(二)】开发板SDK配置动态设备树
2461 浏览 0 评论
【飞凌OK-MX9596-C开发板试用】4.电力设备模拟之CAN解锁
1688 浏览 0 评论
【OK3506-S12Mini试用评测(一)】开发板连接putty串口解决Xterminal远程连接问题
2506 浏览 0 评论
【飞凌OK-MX9596-C开发板试用】3.电力设备模拟之抄表
2022 浏览 0 评论
【飞凌OK113i-S开发板试用】基于飞凌嵌入式OK113i网页视频监控项目
28174浏览 1评论
基于 i.MX6ULL 高性价比、通用性强的处理器,适合初学者的板卡ELF 1开发板项目实践
28386浏览 1评论
【飞凌嵌入式OK3588J-C开发板体验】OK3588J-C开发板开箱评测
14937浏览 1评论
16371浏览 1评论
10284浏览 1评论
/9
GMT+8, 2025-12-12 08:57 , Processed in 0.725110 second(s), Total 40, Slave 29 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
855
