lv_7095647024556576031_20220529235058华为云IoT平台产品创建 1、登录华为云
file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg 2、华为云接入协议 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg
WIN + R键打开PC命令行CMD,执行如下命令获取接入域名的IP地址。 ping a161b173a6.iot-mqtts.cn-north-4.myhuaweicloud.com 通过ping命令可以查询到接入域名的IP地址为121.36.42.100 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg
IP地址对应例程代码中的OC_SERVER_IP,端口号1883对于例程代码中的OC_SERVER_PORT。
file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image012.png file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image014.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image015.png file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image017.jpg
file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image019.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image021.jpg 连接华为云前需要获取CLIENT_ID、USERNAME、PASSWORD,访问 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image023.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image025.jpg
如果实验板刚重启时未激活,并在华为云平台可以看到鉴权失败,则重置该密码,保证与编译时密码一样。 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image027.png
WIFI连接网络 修改例程代码 d e v i c e r o c k c h i p r k 2 2 0 6 s d k _ l i t e o s b o a r d s r c c o n f i g _ n e t w o r k . c中的W I F I _ S S I D 和 WIFI_PASSWORD为使用WIFI的SSID和密匙,用于连接网络,设备通过WIFI访问华为云。 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image029.png
1、修改编译脚本
file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image031.png file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image033.png 2、编译固件 用cd 命令切换到路径lockzhiner-rk2206-openharmony3.0lts
file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image035.jpg Hb clean 如果之前有编译过一定要先清除之前编译文档,否则会出错 Hb set-root . Hb set Hb build-f 编译时一定要全编译
file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image037.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image039.jpg 3、烧写固件 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image041.jpg
弹出的对话框中,依次选择homelzdz /out/rk2206/lockzhiner-rk2206/images,选中 rk2206_db_loader.bin文件 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image043.jpg 指定fireware文件
弹出打开对话框,选择主目录下 ut/rk2206/lockzhiner-rk2206/images,选中 Firmware.img文件 file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image045.jpg
Type c数据线连接电脑与小凌派开发板(插入开发板的USB-OTG(即烧录口)) file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image047.jpgfile:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image049.jpg
长按maskrom,然后点按reset。直到烧写工具出现:“发现一个MASKROM设备” file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image051.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image053.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image055.jpg
将C头拔下,插入开发板的UART(即调试串口) file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image057.jpgfile:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image059.jpg
打开MobaXterm软件,点击Session,再点击Serial file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image061.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image063.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image065.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image067.png file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image069.jpg file:///C:/Users/Anping/AppData/Local/Temp/msohtmlclip1/01/clip_image071.jpg
感谢分享!!!
请问一下遇到这种情况是什么出了问题
板子连接不上WiFi
只有小组成员才能发言,加入小组>>
【小凌派RK2206开发板试用体验】1.通过API接口获取天气信息
7330 浏览 1 评论
6775 浏览 0 评论
【小凌派RK2206开发板试用体验】1.Ubuntu22.04搭建编译环境遇到的问题及解决方法
6294 浏览 0 评论
【小凌派RK2206开发板试用体验】第5章 使用WiFi联网
5990 浏览 0 评论
8089 浏览 0 评论
/9
GMT+8, 2025-12-11 14:12 , Processed in 0.738242 second(s), Total 47, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
