前言
RT-Thread的驱动框架里有RTC,Alarm关联与RTC,基于STM32的BSP有现成的RTC驱动,STM32本身就有ST官方的RTC HAL支持,在STM32的BSP上开启RTC,简单配置即可。
开启RTC可以基于RTC开启后开启Alarm功能等
开发环境
stm32l476-st-nucleo开发板,基于STM32L476RG
RT-线程 4.1.0
凯尔MDK5
步骤操作
3-st-nu stml76 的最小 RT-Thread 系统
开启报警组件,这里使用RT-Thread ENV工具:menuconfig
开启RT-Thread 4.1.0(当前最新)的报警组件,就一个配置项,报警附属于RTC功能,也是报警工作必须开启RTC
调试
配置使能报警组件,编译成功下载后,发现没有任何效果
这里需要【Alarm】,驱动的文件位置是RTC的libraries/HAL_Drivers/drv_rtc.c
RTC驱动目前没有合入Alarm的驱动,所以需要添加Alarm的驱动部分,才能让Alarm组件成为驱动
这里为了偷懒,把修改后的:drv_rtc.c贴出来,可以根据:RT_USING_ALARM了解直接添加的报警驱动代码
* Copyright (c) 2006-2021, RT-Thread Development Team
* SPDX-License-Identifier: Apache-2.0
* Change Logs:
* Date Author Notes
* 2018-12-04 balanceTWK first version
* 2020-10-14 Dozingfiretruck Porting for stm32wbxx
* 2021-02-05 Meco Man fix the problem of mixing local time and UTC time
* 2021-07-05 iysheng implement RTC framework V2.0
#include "board.h"
#include
#ifdef BSP_USING_ONCHIP_RTC
struct rtc_device_object
rt_rtc_dev_t parent;
#ifdef RT_USING_ALARM
struct rt_rtc_wkalarm wkalarm;
#endif
static struct rtc_device_object rtc_device;
static rt_err_t rtc_alarm_time_set(struct rtc_device_object* p_dev);
static int rt_rtc_alarm_init(void);
static RTC_AlarmTypeDef salarmstructure;
#endif
#ifndef RTC_BKP_DR1
#define RTC_BKP_DR1 RT_NULL
#endif
//#define DRV_DEBUG
#define LOG_TAG "drv.rtc"
#include
#define BKUP_REG_DATA 0xA5A5
static RTC_HandleTypeDef RTC_Handler;
RT_WEAK uint32_t HAL_RTCEx_BKUPRead(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister)
return (~BKUP_REG_DATA);
RT_WEAK void HAL_RTCEx_BKUPWrite(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data)
return;
static rt_err_t stm32_rtc_get_timeval(struct timeval *tv)
RTC_TimeTypeDef RTC_TimeStruct = {0};
RTC_DateTypeDef RTC_DateStruct = {0};
struct tm tm_new = {0};
HAL_RTC_GetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN);
HAL_RTC_GetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN);
tm_new.tm_sec = RTC_TimeStruct.Seconds;
tm_new.tm_min = RTC_TimeStruct.Minutes;
tm_new.tm_hour = RTC_TimeStruct.Hours;
tm_new.tm_mday = RTC_DateStruct.Date;
tm_new.tm_mon = RTC_DateStruct.Month - 1;
tm_new.tm_year = RTC_DateStruct.Year + 100;
tv->tv_sec = timegm(&tm_new);
#if defined(SOC_SERIES_STM32H7)
tv->tv_usec = (255.0 - RTC_TimeStruct.SubSeconds * 1.0) / 256.0 * 1000.0 * 1000.0;
#endif
return RT_EOK;
static rt_err_t set_rtc_time_stamp(time_t time_stamp)
struct tm tm = {0};
gmtime_r(&time_stamp, &tm);
if (tm.tm_year < 100)
return -RT_ERROR;
RTC_TimeStruct.Seconds = tm.tm_sec ;
RTC_TimeStruct.Minutes = tm.tm_min ;
RTC_TimeStruct.Hours = tm.tm_hour;
RTC_DateStruct.Date = tm.tm_mday;
RTC_DateStruct.Month = tm.tm_mon + 1 ;
RTC_DateStruct.Year = tm.tm_year - 100;
RTC_DateStruct.WeekDay = tm.tm_wday + 1;
if (HAL_RTC_SetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN) != HAL_OK)
return -RT_ERROR;
if (HAL_RTC_SetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN) != HAL_OK)
return -RT_ERROR;
LOG_D("set rtc time.");
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR1, BKUP_REG_DATA);
#ifdef SOC_SERIES_STM32F1
/* F1 series does't save year/month/date datas. so keep those datas to bkp reg */
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR2, RTC_DateStruct.Year);
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR3, RTC_DateStruct.Month);
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR4, RTC_DateStruct.Date);
HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR5, RTC_DateStruct.WeekDay);
#endif
return RT_EOK;
/* update RTC_BKP_DRx*/
static void rt_rtc_f1_bkp_update(void)
HAL_PWR_EnableBkUpAccess();
__HAL_RCC_BKP_CLK_ENABLE();
RTC_DateStruct.Year = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR2);
RTC_DateStruct.Month = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR3);
RTC_DateStruct.Date = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR4);
RTC_DateStruct.WeekDay = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR5);
Error_Handler();
if (HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR4) != RTC_DateStruct.Date)
#endif
static rt_err_t rt_rtc_config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
#ifdef BSP_RTC_USING_LSI
PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
#else
PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
#endif
HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
#if defined(SOC_SERIES_STM32WL)
__HAL_RCC_RTCAPB_CLK_ENABLE();
#endif
/* Enable RTC Clock */
__HAL_RCC_RTC_ENABLE();
RTC_Handler.Instance = RTC;
if (HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR1) != BKUP_REG_DATA)
LOG_I("RTC hasn't been configured, please use command to config.");
#if defined(SOC_SERIES_STM32F1)
RTC_Handler.Init.OutPut = RTC_OUTPUTSOURCE_NONE;
RTC_Handler.Init.AsynchPrediv = RTC_AUTO_1_SECOND;
#elif defined(SOC_SERIES_STM32F0)
/* set the frequency division */
RTC_Handler.Init.AsynchPrediv = 0XA0;
RTC_Handler.Init.SynchPrediv = 0xFA;
#else
RTC_Handler.Init.AsynchPrediv = 0X7F;
RTC_Handler.Init.SynchPrediv = 0x0130;
#endif /* BSP_RTC_USING_LSI */
RTC_Handler.Init.HourFormat = RTC_HOURFORMAT_24;
RTC_Handler.Init.OutPut = RTC_OUTPUT_DISABLE;
RTC_Handler.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
RTC_Handler.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
#elif defined(SOC_SERIES_STM32F2) || defined(SOC_SERIES_STM32F4) || defined(SOC_SERIES_STM32F7) || defined(SOC_SERIES_STM32L0) || defined(SOC_SERIES_STM32L4) || defined(SOC_SERIES_STM32WL) || defined(SOC_SERIES_STM32H7) || defined (SOC_SERIES_STM32WB)
RTC_Handler.Init.AsynchPrediv = 0X7D;
#else
RTC_Handler.Init.SynchPrediv = 0XFF;
#else
#warning "This series doesn't support yet!"
#endif
if (HAL_RTC_Init(&RTC_Handler) != HAL_OK)
return -RT_ERROR;
else
/* F1 series need update by bkp reg datas */
rt_rtc_f1_bkp_update();
#endif
return RT_EOK;
static rt_err_t stm32_rtc_init(void)
#if !defined(SOC_SERIES_STM32H7) && !defined(SOC_SERIES_STM32WL) && !defined(SOC_SERIES_STM32WB)
__HAL_RCC_PWR_CLK_ENABLE();
#endif
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
#ifdef SOC_SERIES_STM32WB
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI1;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
RCC_OscInitStruct.LSEState = RCC_LSE_OFF;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
#else
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI;
#endif
#else
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE;
RCC_OscInitStruct.LSEState = RCC_LSE_ON;
RCC_OscInitStruct.LSIState = RCC_LSI_OFF;
#endif
HAL_RCC_OscConfig(&RCC_OscInitStruct);
if (rt_rtc_config() != RT_EOK)
LOG_E("rtc init failed.");
return -RT_ERROR;
return RT_EOK;
static rt_err_t stm32_rtc_get_secs(time_t *sec)
struct timeval tv;
stm32_rtc_get_timeval(&tv);
*(time_t *) sec = tv.tv_sec;
LOG_D("RTC: get rtc_time %d", *sec);
return RT_EOK;
static rt_err_t stm32_rtc_set_secs(time_t *sec)
rt_err_t result = RT_EOK;
if (set_rtc_time_stamp(*sec))
result = -RT_ERROR;
LOG_D("RTC: set rtc_time %d", *sec);
rt_alarm_update(&rtc_device.parent.parent, 1);
#endif
return result;
static rt_err_t stm32_rtc_get_alarm(struct rt_rtc_wkalarm *alarm)
*alarm = rtc_device.wkalarm;
LOG_D("GET_ALARM %d:%d:%d",rtc_device.wkalarm.tm_hour,
rtc_device.wkalarm.tm_min,rtc_device.wkalarm.tm_sec);
return RT_EOK;
#else
return -RT_ERROR;
#endif
static rt_err_t stm32_rtc_set_alarm(struct rt_rtc_wkalarm *alarm)
LOG_D("RT_DEVICE_CTRL_RTC_SET_ALARM");
if (alarm != RT_NULL)
rtc_device.wkalarm.enable = alarm->enable;
rtc_device.wkalarm.tm_hour = alarm->tm_hour;
rtc_device.wkalarm.tm_min = alarm->tm_min;
rtc_device.wkalarm.tm_sec = alarm->tm_sec;
rtc_alarm_time_set(&rtc_device);
else
LOG_E("RT_DEVICE_CTRL_RTC_SET_ALARM error!!");
return -RT_ERROR;
LOG_D("SET_ALARM %d:%d:%d",alarm->tm_hour,
alarm->tm_min, alarm->tm_sec);
return RT_EOK;
#else
return -RT_ERROR;
#endif
static const struct rt_rtc_ops stm32_rtc_ops =
stm32_rtc_init,
stm32_rtc_get_secs,
stm32_rtc_set_secs,
stm32_rtc_get_alarm,
stm32_rtc_set_alarm,
stm32_rtc_get_timeval,
RT_NULL,
static rt_rtc_dev_t stm32_rtc_dev;
void rt_rtc_alarm_enable(void)
HAL_RTC_SetAlarm_IT(&RTC_Handler,&salarmstructure,RTC_FORMAT_BIN);
HAL_RTC_GetAlarm(&RTC_Handler,&salarmstructure,RTC_ALARM_A,RTC_FORMAT_BIN);
LOG_D("alarm read:%d:%d:%d", salarmstructure.AlarmTime.Hours,
salarmstructure.AlarmTime.Minutes,
salarmstructure.AlarmTime.Seconds);
HAL_NVIC_SetPriority(RTC_Alarm_IRQn, 0x02, 0);
HAL_NVIC_EnableIRQ(RTC_Alarm_IRQn);
void rt_rtc_alarm_disable(void)
HAL_RTC_DeactivateAlarm(&RTC_Handler, RTC_ALARM_A);
HAL_NVIC_DisableIRQ(RTC_Alarm_IRQn);
return RT_EOK;
if (p_dev->wkalarm.enable)
salarmstructure.Alarm = RTC_ALARM_A;
salarmstructure.AlarmDateWeekDay = RTC_WEEKDAY_MONDAY;
salarmstructure.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_WEEKDAY;
salarmstructure.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY;
salarmstructure.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_NONE;
salarmstructure.AlarmTime.TimeFormat = RTC_HOURFORMAT12_AM;
salarmstructure.AlarmTime.Hours = p_dev->wkalarm.tm_hour;
salarmstructure.AlarmTime.Minutes = p_dev->wkalarm.tm_min;
salarmstructure.AlarmTime.Seconds = p_dev->wkalarm.tm_sec;
LOG_D("alarm set:%d:%d:%d", salarmstructure.AlarmTime.Hours,
rt_rtc_alarm_enable();
return RT_EOK;
void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *hrtc)
//LOG_D("rtc alarm isr.
void RTC_Alarm_IRQHandler(void)
rt_interrupt_enter();
HAL_RTC_AlarmIRQHandler(&RTC_Handler);
rt_interrupt_leave();
#endif
static int rt_hw_rtc_init(void)
rt_err_t result;
stm32_rtc_dev.ops = &stm32_rtc_ops;
result = rt_hw_rtc_register(&stm32_rtc_dev, "rtc", RT_DEVICE_FLAG_RDWR, RT_NULL);
if (result != RT_EOK)
LOG_E("rtc register err code: %d", result);
return result;
LOG_D("rtc init success");
rt_rtc_alarm_init();
#endif
return RT_EOK;
INIT_DEVICE_EXPORT(rt_hw_rtc_init);
#endif /* BSP_USING_ONCHIP_RTC */
应用应用
添加了Al,还应用了Alarm的逻辑,如创建手臂、准许测试、准许测试的准入标准等:
#include
#include "board.h"
#include
#include
#include
#define RTC_DEBUG
#define DBG_ENABLE
#define DBG_SECTION_NAME "rtc.test"
#define DBG_LEVEL DBG_LOG
#include
#ifdef RTC_DEBUG
static struct rt_alarm * p_alarm_sec = RT_NULL;
static struct rt_alarm * p_alarm_min = RT_NULL;
static struct rt_alarm * p_alarm_hour = RT_NULL;
static struct rt_alarm * p_alarm_time = RT_NULL;
static time_t rtc_gettime(void)
static time_t now;
static struct tm tm;
now = time(NULL);
gmtime_r(&now, &tm);
LOG_D("BJ time:%04d-%02d-%02d %02d:%02d:%02d.%03d
tm.tm_year + 1900, tm.tm_mon + 1,
tm.tm_mday, tm.tm_hour + 8, tm.tm_min,
tm.tm_sec, rt_tick_get() % 1000);
return now;
static void alarm_time_cb(rt_alarm_t alarm, time_t timestamp)
LOG_D("alarm_time_cb ok!
static void alarm_hour_cb(rt_alarm_t alarm, time_t timestamp)
LOG_D("alarm_hour_cb ok!
static void alarm_minute_cb(rt_alarm_t alarm, time_t timestamp)
LOG_D("alarm_minute_cb ok!
static void alarm_second_cb(rt_alarm_t alarm, time_t timestamp)
LOG_D("alarm_second_cb ok!
static struct rt_alarm * rtc_alarm_test_create(rt_alarm_callback_t callback, rt_uint32_t flag, struct tm *p_tm)
struct rt_alarm_setup alarm_setup_test;
alarm_setup_test.flag = flag;
alarm_setup_test.wktime.tm_year = p_tm->tm_year;
alarm_setup_test.wktime.tm_mon = p_tm->tm_mon;
alarm_setup_test.wktime.tm_mday = p_tm->tm_mday;
alarm_setup_test.wktime.tm_wday = p_tm->tm_wday;
alarm_setup_test.wktime.tm_hour = p_tm->tm_hour;
alarm_setup_test.wktime.tm_min = p_tm->tm_min;
alarm_setup_test.wktime.tm_sec = p_tm->tm_sec;
return rt_alarm_create(callback, &alarm_setup_test);
static void rtc_alarm_time_create(void)
static time_t now;
if (p_alarm_time != RT_NULL)
return;
now = time(NULL) + 65;
p_alarm_time = rtc_alarm_test_create(alarm_time_cb, RT_ALARM_DAILY, &tm);
static void rtc_alarm_time_start(void)
rt_alarm_start(p_alarm_time);
static void rtc_alarm_time_stop(void)
rt_alarm_stop(p_alarm_time);
static void rtc_alarm_time_delete(void)
if (rt_alarm_delete(p_alarm_time) == RT_EOK)
static void rtc_alarm_second_create(void)
static time_t now;
if (p_alarm_sec != RT_NULL)
return;
now = time(NULL) + 1;
p_alarm_sec = rtc_alarm_test_create(alarm_second_cb, RT_ALARM_SECOND, &tm);
static void rtc_alarm_second_start(void)
rt_alarm_start(p_alarm_sec);
static void rtc_alarm_second_stop(void)
rt_alarm_stop(p_alarm_sec);
static void rtc_alarm_second_delete(void)
if (rt_alarm_delete(p_alarm_sec) == RT_EOK)
static void rtc_alarm_minute_create(void)
static time_t now;
if (p_alarm_min != RT_NULL)
return;
now = time(NULL) + 60;
p_alarm_min = rtc_alarm_test_create(alarm_minute_cb, RT_ALARM_MINUTE, &tm);
static void rtc_alarm_minute_start(void)
rt_alarm_start(p_alarm_min);
static void rtc_alarm_minute_stop(void)
rt_alarm_stop(p_alarm_min);
static void rtc_alarm_minute_delete(void)
if (rt_alarm_delete(p_alarm_min) == RT_EOK)
static void rtc_alarm_hour_create(void)
static time_t now;
if (p_alarm_hour != RT_NULL)
return;
now = time(NULL) + 3600;
p_alarm_hour = rtc_alarm_test_create(alarm_hour_cb, RT_ALARM_HOUR, &tm);
static void rtc_alarm_hour_start(void)
rt_alarm_start(p_alarm_hour);
static void rtc_alarm_hour_stop(void)
rt_alarm_stop(p_alarm_hour);
static void rtc_alarm_hour_delete(void)
if (rt_alarm_delete(p_alarm_hour) == RT_EOK)
void rtc_alarm_start(int argc, char **argv)
int index = 0;
if (argc >= 2)
index = atoi(argv[1]);
switch(index)
case 0:
rtc_alarm_hour_start();
break;
case 1:
rtc_alarm_minute_start();
break;
case 2:
rtc_alarm_second_start();
break;
case 3:
rtc_alarm_time_start();
break;
default:
break;
void rtc_alarm_stop(int argc, char **argv)
int index = 0;
if (argc >= 2)
switch(index)
case 0:
rtc_alarm_hour_stop();
break;
case 1:
rtc_alarm_minute_stop();
break;
case 2:
rtc_alarm_second_stop();
break;
case 3:
rtc_alarm_time_stop();
break;
default:
break;
void rtc_alarm_create(int argc, char **argv)
int index = 0;
if (argc >= 2)
switch(index)
case 0:
rtc_alarm_hour_create();
break;
case 1:
rtc_alarm_minute_create();
break;
case 2:
rtc_alarm_second_create();
break;
case 3:
rtc_alarm_time_create();
break;
default:
break;
void rtc_alarm_delete(int argc, char **argv)
int index = 0;
if (argc >= 2)
switch(index)
case 0:
rtc_alarm_hour_delete();
break;
case 1:
rtc_alarm_minute_delete();
break;
case 2:
rtc_alarm_second_delete();
break;
case 3:
rtc_alarm_time_delete();
break;
default:
break;
MSH_CMD_EXPORT(rtc_gettime, rtc get time);
MSH_CMD_EXPORT(rtc_alarm_create, rtc alarm_create);
MSH_CMD_EXPORT(rtc_alarm_delete, rtc alarm_delete);
MSH_CMD_EXPORT(rtc_alarm_start, rtc alarm_start);
MSH_CMD_EXPORT(rtc_alarm_stop, rtc alarm_stop);
#endif
#endif //RT_USING_ALARM
报警调试
报警几种类型:单次、有分好、周、好几秒的又一周期、天、时等,
msh >rtc_alarm_create 1 /* 创建闹钟:分钟为周期,也就是每分钟触发一次回调 */
msh >rtc_alarm_start 1 /* 使能闹钟:使能后闹钟才会触发 */
msh >list_alarm /* 查看闹钟列表,注意 M 代表类型【分钟】, en:1 代表使能 */
| hh:mm:ss | week | flag | en |
| 13:17:05 | 2 | M | 1 |
停止:如果需要手动停止,如果不需要
删删:主动删除,【内存】后可删删,禁止删除:msh >rtc_alarm_delete 1
小结
本篇基于STM32L4系列、STM32H5系列测试通过,但不代表其他平台会直接能测试
alarm与RTC的时间:没有UTC时间,也就是【时区】的,这个一定要注意
原作者:张世争
