RK3568 CPU默认最高频率为1992MHz,如果要修改为2016MHz,可以按如下修改。
注意这里只是显示2016MHz,实际还是跑1992MHz。 kernel的版本是develop-4.19 kernel下面的补丁: diff --git a/arch/arm64/boot/dts/rockchip/rk3568.dtsi b/arch/arm64/boot/dts/rockchip/rk3568.dtsi index 5b744b2b5755..97c88f587615 100644 --- a/arch/arm64/boot/dts/rockchip/rk3568.dtsi +++ b/arch/arm64/boot/dts/rockchip/rk3568.dtsi @@ -206,8 +206,8 @@ opp-microvolt-L2 = <1050000 1050000 1150000>; clock-latency-ns = <40000>; }; - opp-1992000000 { - opp-hz = /bits/ 64 <1992000000>; + opp-2016000000 { + opp-hz = /bits/ 64 <2016000000>; opp-microvolt = <1150000 1150000 1150000>; opp-microvolt-L0 = <1150000 1150000 1150000>; opp-microvolt-L1 = <1100000 1100000 1150000>; diff --git a/drivers/clk/clk-scmi.c b/drivers/clk/clk-scmi.c index 7da2c01c4444..a129cf95e4c1 100644 --- a/drivers/clk/clk-scmi.c +++ b/drivers/clk/clk-scmi.c @@ -69,6 +69,9 @@ static int scmi_clk_set_rate(struct clk_hw *hw, unsigned long rate, { struct scmi_clk *clk = to_scmi_clk(hw); + if ((clk->id == 0) && (rate == 2016000000)) + rate = 1992000000; + return clk->handle->clk_ops->rate_set(clk->handle, clk->id, rate); } @@ -129,6 +132,8 @@ static int scmi_clk_ops_init(struct device *dev, struct scmi_clk *sclk) min_rate = sclk->info->range.min_rate; max_rate = sclk->info->range.max_rate; } + if (sclk->id == 0) + max_rate = 2016000000; clk_hw_set_rate_range(&sclk->hw, min_rate, max_rate); return ret; -- 原作者:loitawu |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
RK3568平台,进入烧录模式,部分电脑提示无法识别,无法烧录
2575 浏览 1 评论
【RK3568 Android11.0】如何在设置-显示-HDMI-分辨率设置中添加3840*2160的选项?
5481 浏览 1 评论
瑞芯微第二代8nm高性能AIOT平台 RK3576 详细介绍
1395 浏览 0 评论
6344 浏览 1 评论
RK3399开发版正常刷机成功后 通电开机黑屏 HDMI无图像输出
4978 浏览 2 评论
GMT+8, 2024-4-19 21:58 , Processed in 0.404214 second(s), Total 37, Slave 30 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
