1.芯片STM32F49BIT6 使用外部SDRAM,移植LTDC驱动RGB屏幕三色显示正常。
2.添加LVGL 8.2.0软件包,没有开启任何example和demo均不使能。 3.在applications中新建lvgl文件夹,利用软件包内的5个template移植lv_conf.h;lv_port_disp.h;lv_port_disp.c;lv_port_indev.h;lv_port_indev.c五个文件,在lv_port_disp.c中定义: #define MY_DISP_HOR_RES 800 #define MY_DISP_VER_RES 480 #define LV_VER_RES_MAX MY_DISP_HOR_RES 注释掉 // /* Example for 2) */ // static lv_disp_draw_buf_t draw_buf_dsc_2; // static lv_color_t buf_2_1[MY_DISP_HOR_RES * 10]; /*A buffer for 10 rows*/ // static lv_color_t buf_2_2[MY_DISP_HOR_RES * 10]; /*An other buffer for 10 rows*/ // lv_disp_draw_buf_init(&draw_buf_dsc_2, buf_2_1, buf_2_2, MY_DISP_HOR_RES * 10); /*Initialize the display buffer*/ // // /* Example for 3) also set disp_drv.full_refresh = 1 below*/ // static lv_disp_draw_buf_t draw_buf_dsc_3; // static lv_color_t buf_3_1[MY_DISP_HOR_RES * MY_DISP_VER_RES]; /*A screen sized buffer*/ // static lv_color_t buf_3_2[MY_DISP_HOR_RES * MY_DISP_VER_RES]; /*Another screen sized buffer*/ // lv_disp_draw_buf_init(&draw_buf_dsc_3, buf_3_1, buf_3_2, MY_DISP_VER_RES * LV_VER_RES_MAX); /*Initialize the display buffer*/ 编译后报如下错误 01:44:36 **** Incremental Build of configuration Debug for project FK-F429BIT6M2-LTDC-LVGL **** make -j8 all linking... ./packages/LVGL-v8.2.0/src/misc/lv_printf.o: In function `rt_snprintf': E:workspaceFK_F429M2FK-F429BIT6M2-LTDC-LVGLDebug/../packages/LVGL-v8.2.0/src/misc/lv_printf.c:866: multiple definition of `rt_snprintf' ./rt-thread/src/kservice.o:E:workspaceFK_F429M2FK-F429BIT6M2-LTDC-LVGLDebug/../rt-thread/src/kservice.c:1131: first defined here collect2.exe: error: ld returned 1 exit status make: *** [makefile:109: rtthread.elf] Error 1 "make -j8 all" terminated with exit code 2. Build might be incomplete. 01:44:39 Build Failed. 3 errors, 0 warnings. (took 2s.654ms) 错误定位一下两个函数之间存在重复定义: int lv_snprintf(char * buffer, size_t count, const char * format, ...) { va_list va; va_start(va, format); const int ret = _vsnprintf(_out_buffer, buffer, count, format, va); va_end(va); return ret; } int rt_snprintf(char *buf, rt_size_t size, const char *fmt, ...) { rt_int32_t n; va_list args; va_start(args, fmt); n = rt_vsnprintf(buf, size, fmt, args); va_end(args); return n; } 5.使用littlevGL2RTT软件包不存在这个问题,后在cubemx修改栈为0x1000问题也没有解决,重复新建工程多次也不行,应该怎么解决? |
1个回答
这个重复定义的错误应该来自 lv_conf.h 配置文件,里面把某个 lv 函数 define 成了 rt_snprintf
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
999 浏览 0 评论
2781 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9368 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2895 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2300 浏览 1 评论
/9
GMT+8, 2025-12-1 10:48 , Processed in 0.765860 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3225
