开始下载程序:2021-12-15 10:05:08
D:softwareRT-ThreadStudio>"D:/software/RT-ThreadStudio//repo/Extract/Debugger_Support_Packages/SEGGER/J-Link/6.80d2/JLink.exe" -device STM32F767IG -ExitOnError -CommanderScript D:softwareRT-ThreadStudioworkspace/.metadata/Temp/rtthread_download_init.jlink SEGGER J-Link Commander V6.80d (Compiled Jun 26 2020 17:17:12) DLL version V6.80d, compiled Jun 26 2020 17:16:09 J-Link Commander will now exit on Error J-Link Command File read successfully. Processing script file... J-Link connection not established yet but required for command. Connecting to J-Link via USB...O.K. Firmware: J-Link V9 compiled May 7 2021 16:26:12 Hardware version: V9.60 S/N: 69660153 License(s): RDI, GDB, FlashDL, FlashBP, JFlash VTref=3.163V Selecting SWD as current target interface. Device "STM32F767IG" selected. Selecting auto as target interface speed Target connection not established yet but required for command. Device "STM32F767IG" selected. Connecting to target via SWD Found SW-DP with ID 0x5BA02477 Found SW-DP with ID 0x5BA02477 DPIDR: 0x5BA02477 Scanning AP map to find all available APs AP[1]: Stopped AP scan as end of AP map has been reached AP[0]: AHB-AP (IDR: 0x74770001) Iterating through AP map to find AHB-AP to use AP[0]: Core found AP[0]: AHB-AP ROM base: 0xE00FD000 CPUID register: 0x411FC270. Implementer code: 0x41 (ARM) Found Cortex-M7 r1p0, Little endian. FPUnit: 8 code (BP) slots and 0 literal slots CoreSight components: ROMTbl[0] @ E00FD000 ROMTbl[0][0]: E00FE000, CID: B105100D, PID: 000BB4C8 ROM Table ROMTbl[1] @ E00FE000 ROMTbl[1][0]: E00FF000, CID: B105100D, PID: 000BB4C7 ROM Table ROMTbl[2] @ E00FF000 ROMTbl[2][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7 ROMTbl[2][1]: E0001000, CID: B105E00D, PID: 000BB002 DWT ROMTbl[2][2]: E0002000, CID: B105E00D, PID: 000BB00E FPB-M7 ROMTbl[2][3]: E0000000, CID: B105E00D, PID: 000BB001 ITM ROMTbl[1][1]: E0041000, CID: B105900D, PID: 001BB975 ETM-M7 ROMTbl[0][1]: E0040000, CID: B105900D, PID: 000BB9A9 TPIU-M7 Cache: Separate I- and D-cache. I-Cache L1: 16 KB, 256 Sets, 32 Bytes/Line, 2-Way D-Cache L1: 16 KB, 128 Sets, 32 Bytes/Line, 4-Way Cortex-M7 identified. Reset delay: 0 ms Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit. Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ. PC = 1FF00210, CycleCnt = 00000000 R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000 R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000 R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000 R12= 00000000 SP(R13)= 20003420, MSP= 20003420, PSP= 00000000, R14(LR) = FFFFFFFF XPSR = 01000000: APSR = nzcvq, EPSR = 01000000, IPSR = 000 (NoException) CFBP = 00000000, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 00 FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000 FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000 FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000 FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= FFFFFFFF FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000 FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000 FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000 FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= FFFFFFFF FPSCR= 00000000 Downloading file [D:softwareRT-ThreadStudioworkspaceTESTDebugrtthread.bin]... J-Link: Flash download: Bank 0 @ 0x08000000: 1 range affected (32768 bytes) J-Link: Flash download: Total: 0.900s (Prepare: 0.135s, Compare: 0.097s, Erase: 0.335s, Program & Verify: 0.319s, Restore: 0.012s) J-Link: Flash download: Program & Verify speed: 100 KB/s O.K. Reset delay: 0 ms Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit. Reset: Halt core after reset via DEMCR.VC_CORERESET. Reset: Reset device via AIRCR.SYSRESETREQ. Script processing completed. 执行完毕, 耗时:4605ms. |
6个回答
程序有问题呗
都试过了还是不可以
试试 单独用 JFlash 下载程序看看
直接仿真一下,看程序停在哪里不行么
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1092 浏览 0 评论
3044 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9411 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2900 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2305 浏览 1 评论
/9
GMT+8, 2025-12-3 11:28 , Processed in 0.750534 second(s), Total 85, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2051
