系统win10,网络正常,执行命令“npm install -g @ohos/hpm-cli”,报错如下:
npm ERR! code ENOTFOUND npm ERR! errno ENOTFOUND npm ERR! network request to failed, reason: getaddrinfo ENOTFOUND proxyserver npm ERR! network This is a problem related to network connectivity. npm ERR! network In most cases you are behind a proxy or have bad network settings. npm ERR! network npm ERR! network If you are behind a proxy, please make sure that the npm ERR! network 'proxy' config is set properly. See: 'npm help config' npm ERR! A complete log of this run can be found in: npm ERR! D:nodenode_cache_logs2020-12-17T15_17_52_948Z-debug.log |
2个回答
npm ERR! code ENOTFOUND npm ERR! errno ENOTFOUND npm ERR! network request to failed, reason: getaddrinfo ENOTFOUND proxyserver npm ERR! network This is a problem related to network connectivity. npm ERR! network In most cases you are behind a proxy or have bad network settings. npm ERR! network npm ERR! network If you are behind a proxy, please make sure that the npm ERR! network 'proxy' config is set properly. See: 'npm help config' npm ERR! A complete log of this run can be found in: npm ERR! D: ode ode_cache_logs2020-12-17T15_17_52_948Z-debug.log |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
392 浏览 0 评论
4773 浏览 0 评论
32002 浏览 0 评论
【润开鸿HH-SCDAYU800A开发板试用体验】+系统编译
1126 浏览 0 评论
【汇思博SEEK100开发板试用体验】记录DevEco Studio 中遇到的问题
1521 浏览 0 评论
/9
GMT+8, 2025-12-12 04:11 , Processed in 0.785794 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1922
