在系统开启并有日志打印的前提下,插入USB设备,就会打印USB设备和虚拟串口信息。
打印信息如下: 供应商ID(VID):idVendor=1234,产品ID(PID): idProduct=5678 Product、Manufacturer、SerialNumber,这三项暂时用不到。 ttyACM0:虚拟出来的串口,也有可能是ttySx、ttyGSx(x为0/1/2/3......) [ 99.373774] u*** 3-1.3: new full-speed USB device number 3 using u***20_host [ 99.473868] u*** 3-1.3: New USB device found, idVendor=1234, idProduct=5678 [ 99.473970] u*** 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 99.473997] u*** 3-1.3: Product: USBKey Module [ 99.474016] u*** 3-1.3: Manufacturer: USBKey Chip [ 99.474033] u*** 3-1.3: SerialNumber: 202730041341 [ 99.483763] cdc_acm 3-1.3:1.0: This device cannot do calls on its own. It is not a modem. [ 99.491455] cdc_acm 3-1.3:1.0: ttyACM0: USB ACM device 先手动测试此虚拟串口能否使用(以虚拟串口的扫描枪为例) $ adb shell // 查看虚拟的串口是否存在 root@xxx:/ # ls /dev/ttyACM0 ls /dev/ttyACM0 /dev/ttyACM0 // 如果不是 root 权限,此时使用 su 获取 root 权限 // 修改此虚拟串口为最高权限 root@xxx:/ # chmod 777 /dev/ttyACM0 chmod 777 /dev/ttyACM0 root@xxx:/ # cat dev/ttyACM0 cat dev/ttyACM0 // 开始扫码 DS610018C18021 DS610018C18021 确定虚拟串口可以使用,将设备添加到代码中。 同时添加了ttyACM0-3,为了防止插入多个设备而导致虚拟串口变动。 将VID和PID添加到数组 option_ids[] 中。USB_DEVICE(VID, PID) diff --git a/device/rockchip/common/ueventd.rockchip.rc b/device/rockchip/common/ueventd.rockchip.rc old mode 100644 new mode 100755 index 34f7ad1..d82fad3 --- a/device/rockchip/common/ueventd.rockchip.rc +++ b/device/rockchip/common/ueventd.rockchip.rc @@ -116,3 +116,8 @@ /dev/i2c-2 0660 system system /dev/i2c-3 0660 system system /dev/i2c-4 0660 system system + +/dev/ttyACM0 0666 system system +/dev/ttyACM1 0666 system system +/dev/ttyACM2 0666 system system +/dev/ttyACM3 0666 system system diff --git a/kernel/drivers/u***/serial/option.c b/kernel/drivers/u***/serial/option.c index e7ecdc3..9f1a6b6 100755 --- a/kernel/drivers/u***/serial/option.c +++ b/kernel/drivers/u***/serial/option.c @@ -1766,6 +1766,8 @@ static const struct u***_device_id option_ids[] = { {USB_DEVICE(0x0E8D,0x00A5)}, {USB_DEVICE(0x05C6,0x9025)}, + {USB_DEVICE(0x1234,0x5678)},//扫描枪 { } /* Terminating entry */ }; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1195 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
5973 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2012 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2559 浏览 0 评论
2555 浏览 0 评论
/9
GMT+8, 2025-12-9 06:52 , Processed in 0.550761 second(s), Total 43, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1446
