1个回答
RK3399 中的ffmpeg对于rkmpp硬件解码的转换
{ AVCodecContext *codecCtx; size_t unused; RKMPPDecodeContext *rk_context = codecCtx->priv_data; RKMPPDecoder *decoder = (RKMPPDecoder *) rk_context->decoder_ref->data; ret = mpp_buffer_group_limit_config(decoder->frame_group, 0, 30); //重新group为30长度 unused = mpp_buffer_group_unused(decoder->frame_group); //获取未使用个数 log("CH:%d, unused:%dn", mediaService->chNo, unused); } ... while(1) ..... 循环读取视频流并解码 //解码成AVFrame ret=avcodec_send_packet(codecCtx,pkt); if(ret!=0){ avcodec_flush_buffers(codecCtx); //刷新后可以重新解码 continue; } avcodec_receive_frame(codecCtx, avframe); { //移动avframe到其他第放使用 format 为 AV_PIX_FMT_DRM_PRIME,即rkmpp的DRM数据 AVFrame *dst_avframe = av_frame_alloc(); av_frame_move_ref(dst_avframe, avframe); av_frame_unref(avframe); //必须加 //将AVFrmae转换为rkmpp的数据格式 AVBufferRef* framecontextref = (AVBufferRef*) av_buffer_get_opaque( avframe->buf[0]); RKMPPFrameContext *framecontext = (RKMPPFrameContext *) framecontextref->data; MppFrame mppframe=framecontext->frame; MppBuffer mppbuffer = mpp_frame_get_buffer(mppframe); MppFrameFormat format = mpp_frame_get_fmt(mppframe); //应该为MPP_FMT_YUV420SP(NV12) int width = mpp_frame_get_width(mppframe); int height = mpp_frame_get_height(mppframe); int hor_stride = mpp_frame_get_hor_stride(mppframe); int ver_stride = mpp_frame_get_ver_stride(mppframe); uint8_t *yuvDataPtr=mpp_buffer_get_ptr(buffer); //YUV数据(NV12) //这样可以处理MPP的硬件数据,缩放,截图可以使用RGA } ... avcodec_flush_buffers(codecCtx); { RKMPPDecodeContext *rk_context = ffContext->pCodecCtx->priv_data; RKMPPDecoder *decoder = (RKMPPDecoder *) rk_context->decoder_ref->data; //等待未使用个数为原始的30个 while (30 != (unused = mpp_buffer_group_unused(decoder->frame_group))) { logInfo("Media", "CH:%d, mpp_buffer_group_unused:%dn", mediaService->chNo, unused); sleep(1); } } RK3399 rga转换 /格式转化 MppFrame srcframe = AVFrame2MppFrame(avframe); int hor_stride = mpp_frame_get_hor_stride(srcframe); int ver_stride = mpp_frame_get_ver_stride(srcframe); int src_width = mpp_frame_get_width(srcframe); int src_height = mpp_frame_get_height(srcframe); MppBuffer buffer = mpp_frame_get_buffer(srcframe); uint8_t *src_yuv_ptr = (uint8_t*) mpp_buffer_get_ptr(buffer); rga_info_t src_info; //原图像 memset(&src_info, 0, sizeof(rga_info_t)); src_info.fd = mpp_buffer_get_fd(buffer); src_info.mmuFlag = 1; rga_set_rect(&src_info.rect, 0, 0, src_width, src_height,hor_stride, ver_stride, RK_FORMAT_YCbCr_420_SP); //NV12 //目标图像存储空间分配 int dst_width = src_width; int dst_height = src_height; int dst_hor = MPP_ALIGN(dst_width, 1); //默认16字节对其,才能编码成JPG,这里使用1字节对齐 int dst_ver = MPP_ALIGN(dst_height, 1); //默认16字节对其 int framesize = dst_ver * dst_hor * 3 / 2; MppBuffer dst_buffer; mpp_buffer_get(NULL, &dst_buffer, framesize); //申请内存 rga_info_t dst_info; //目标图像 memset(&dst_info, 0, sizeof(rga_info_t)); dst_info.fd = mpp_buffer_get_fd(dst_buffer); dst_info.mmuFlag = 1; rga_set_rect(&dst_info.rect, 0, 0, dst_width, dst_height,dst_hor, dst_ver, RK_FORMAT_YCrCb_420_P); ret = c_RkRgaBlit(&src_info, &dst_info, NULL); void *yuv_ptr = mpp_buffer_get_ptr(dst_buffer); //对yuv_ptr做运算,人脸,车辆,车牌等 因为RK3399没有NPU,故而在CPU中处理GPU数据 mpp_buffer_put(dst_buffer); //释放内存 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2031 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
2571 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
5346 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
1336 浏览 0 评论
GMT+8, 2024-11-26 09:16 , Processed in 0.782566 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
