1. 主机开发环境
2. 安装aarch64-linux-gnu-g++交叉编译工具 安装交叉编译工具,我选择通过命令行安装,没有选择从官方地址下载。更新软件源和升级更新软件 sudo apt-get update sudo apt-get upgrade
$ sudo apt-cache search aarch64 binutils-aarch64-linux-gnu - GNU binary utilities, for aarch64-linux-gnu target binutils-aarch64-linux-gnu-dbg - GNU binary utilities, for aarch64-linux-gnu target (debug symbols) cpp-7-aarch64-linux-gnu - GNU C preprocessor cpp-aarch64-linux-gnu - GNU C preprocessor (cpp) for the arm64 architecture g++-aarch64-linux-gnu - GNU C++ compiler for the arm64 architecture gcc-7-aarch64-linux-gnu-base - GCC, the GNU Compiler Collection (base package) gcc-aarch64-linux-gnu - GNU C compiler for the arm64 architecture qemu-system-arm - QEMU full system emulation binaries (arm) cpp-5-aarch64-linux-gnu - GNU C preprocessor cpp-6-aarch64-linux-gnu - GNU C preprocessor cpp-8-aarch64-linux-gnu - GNU C preprocessor g++-5-aarch64-linux-gnu - GNU C++ compiler g++-6-aarch64-linux-gnu - GNU C++ compiler gcc-5-aarch64-linux-gnu - GNU C compiler gcc-5-aarch64-linux-gnu-base - GCC, the GNU Compiler Collection (base package) gcc-5-plugin-dev-aarch64-linux-gnu - Files for GNU GCC plugin development. gcc-6-aarch64-linux-gnu - GNU C compiler gcc-6-aarch64-linux-gnu-base - GCC, the GNU Compiler Collection (base package) gcc-6-plugin-dev-aarch64-linux-gnu - Files for GNU GCC plugin development. gcc-7-plugin-dev-aarch64-linux-gnu - Files for GNU GCC plugin development. gcc-8-aarch64-linux-gnu-base - GCC, the GNU Compiler Collection (base package) gcc-8-plugin-dev-aarch64-linux-gnu - Files for GNU GCC plugin development. gccgo-5-aarch64-linux-gnu - GNU Go compiler gccgo-6-aarch64-linux-gnu - GNU Go compiler gccgo-7-aarch64-linux-gnu - GNU Go compiler gccgo-8-aarch64-linux-gnu - GNU Go compiler gccgo-aarch64-linux-gnu - Go compiler (based on GCC) for the arm64 architecture gdc-5-aarch64-linux-gnu - GNU D compiler (version 2) gdc-6-aarch64-linux-gnu - GNU D compiler (version 2) gdc-aarch64-linux-gnu - GNU D compiler (based on GCC) for the arm64 architecture gfortran-5-aarch64-linux-gnu - GNU Fortran compiler gfortran-6-aarch64-linux-gnu - GNU Fortran compiler gfortran-7-aarch64-linux-gnu - GNU Fortran compiler gfortran-8-aarch64-linux-gnu - GNU Fortran compiler gfortran-aarch64-linux-gnu - GNU Fortran 95 compiler for the arm64 architecture gnat-5-aarch64-linux-gnu - GNU Ada compiler gnat-5-sjlj-aarch64-linux-gnu - GNU Ada compiler (setjump/longjump runtime library) gnat-6-aarch64-linux-gnu - GNU Ada compiler gnat-6-sjlj-aarch64-linux-gnu - GNU Ada compiler (setjump/longjump runtime library) gnat-7-aarch64-linux-gnu - GNU Ada compiler gnat-7-sjlj-aarch64-linux-gnu - GNU Ada compiler (setjump/longjump runtime library) gnat-8-aarch64-linux-gnu - GNU Ada compiler gnat-8-sjlj-aarch64-linux-gnu - GNU Ada compiler (setjump/longjump runtime library) gobjc++-5-aarch64-linux-gnu - GNU Objective-C++ compiler gobjc++-6-aarch64-linux-gnu - GNU Objective-C++ compiler gobjc++-7-aarch64-linux-gnu - GNU Objective-C++ compiler gobjc++-8-aarch64-linux-gnu - GNU Objective-C++ compiler gobjc++-aarch64-linux-gnu - GNU Objective-C++ compiler for the arm64 architecture gobjc-5-aarch64-linux-gnu - GNU Objective-C compiler gobjc-6-aarch64-linux-gnu - GNU Objective-C compiler gobjc-7-aarch64-linux-gnu - GNU Objective-C compiler gobjc-8-aarch64-linux-gnu - GNU Objective-C compiler gobjc-aarch64-linux-gnu - GNU Objective-C compiler for the arm64 architecture pkg-config-aarch64-linux-gnu - manage compile and link flags for libraries for arm64 architecture qemu-efi - transitional dummy package qemu-efi-aarch64 - UEFI firmware for 64-bit ARM virtual machines g++-7-aarch64-linux-gnu - GNU C++ compiler (cross compiler for arm64 architecture) gcc-7-aarch64-linux-gnu - GNU C compiler (cross compiler for arm64 architecture) g++-8-aarch64-linux-gnu - GNU C++ compiler (cross compiler for arm64 architecture) gcc-8-aarch64-linux-gnu - GNU C compiler (cross compiler for arm64 architecture) gdc-7-aarch64-linux-gnu - GNU D compiler (version 2) (cross compiler for arm64 architecture) gdc-8-aarch64-linux-gnu - GNU D compiler (version 2) (cross compiler for arm64 architecture)
sudo apt-get install g++-aarch64-linux-gnu
$ which aarch64-linux-gnu-g++ /usr/bin/aarch64-linux-gnu-g++
$ aarch64-linux-gnu-g++ -v Using built-in specs. COLLECT_GCC=aarch64-linux-gnu-g++ COLLECT_LTO_WRAPPER=/usr/lib/gcc-cross/aarch64-linux-gnu/7/lto-wrapper Target: aarch64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 7.5.0-3ubuntu1~18.04' --with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-7 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=aarch64-linux-gnu --program-prefix=aarch64-linux-gnu- --includedir=/usr/aarch64-linux-gnu/include Thread model: posix gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) 3. 移植Qt 3.1 修改Qt源码中的Makefile说明文档目录
$ cd Code/qtsourcecode/qt-everywhere-src-5.14.2/qtbase/mkspecs/
$ mkdir linux-arm-som-rk3399
$ cp linux-aarch64-gnu-g++/* linux-arm-som-rk3399/
qmake.conf文件的原始文件内容:# # qmake configuration for building with aarch64-linux-gnu-g++ # MAKEFILE_GENERATOR = UNIX CONFIG += incremental QMAKE_INCREMENTAL_STYLE = sublib include(../common/linux.conf) include(../common/gcc-base-unix.conf) include(../common/g++-unix.conf) # modifications to g++.conf QMAKE_CC = aarch64-linux-gnu-gcc QMAKE_CXX = aarch64-linux-gnu-g++ QMAKE_LINK = aarch64-linux-gnu-g++ QMAKE_LINK_SHLIB = aarch64-linux-gnu-g++ # modifications to linux.conf QMAKE_AR = aarch64-linux-gnu-ar cqs QMAKE_OBJCOPY = aarch64-linux-gnu-objcopy QMAKE_NM = aarch64-linux-gnu-nm -P QMAKE_STRIP = aarch64-linux-gnu-strip load(qt_config) qmake.conf修改后的文件内容:# # qmake configuration for building with aarch64-linux-gnu-g++ # MAKEFILE_GENERATOR = UNIX CONFIG += incremental QMAKE_INCREMENTAL_STYLE = sublib QT_QPA_DEFAULT_PLATFORM = linuxfb QMAKE_CFLAGS_RELEASE += -O2 -march=armv8-a -lts QMAKE_CXXFLAGS_RELEASE += -O2 -march=armv8-a -lts include(../common/linux.conf) include(../common/gcc-base-unix.conf) include(../common/g++-unix.conf) # modifications to g++.conf QMAKE_CC = aarch64-linux-gnu-gcc QMAKE_CXX = aarch64-linux-gnu-g++ QMAKE_LINK = aarch64-linux-gnu-g++ QMAKE_LINK_SHLIB = aarch64-linux-gnu-g++ # modifications to linux.conf QMAKE_AR = aarch64-linux-gnu-ar cqs QMAKE_OBJCOPY = aarch64-linux-gnu-objcopy QMAKE_NM = aarch64-linux-gnu-nm -P QMAKE_STRIP = aarch64-linux-gnu-strip load(qt_config) 4. 编译Qt5.14.2源码 4.1 创建编译Qt5.14.2源码的影子构建目录 创建影子构建目录的目的是:避免直接在Qt源码目录的根目录直接运行configure命令行工具污染源码
$ mkdir shadow_build_qt_5.14.2 4.2 创建并编辑自动配置脚本
$ cd shadow_build_qt_5.14.2 $ touch auto.sh
#!/bin/bash ../qt-everywhere-src-5.14.2/configure -xplatform linux-arm-som-rk3399 -prefix /home/bruce/Code/qtsourcecode/shadow_build_qt_5.14.2/sy***ase/qt5.14.2_install -release -opensource -confirm-license -make libs -pch -qt-libjpeg -qt-libpng -qt-zlib -no-opengl -no-sse2 -no-openssl -no-cups -no-glib -no-dbus -no-xcb -no-separate-debug-info -c++std c++17
$ sudo chmod a+x auto.sh
$ ./auto.sh 4.3 执行make编译qt源码 $ make -j4 4.3 执行make install安装qt 执行make install后安装到了shadow_build_qt_5.14.2/sy***ase/qt5.14.2_install目录$ cd ~/Code/qtsourcecode/shadow_build_qt_5.14.2/sy***ase/qt5.14.2_install $ ls bin doc include lib mkspecs plugins qml 5. 确保网络的连通 5.1 配置虚拟机网络配置 我使用笔记本开发的,在笔记本上使用VirtualBox虚拟了Ubuntu18.0.4系统,通过无限网路可以连接到因特网5.2 配置Ubuntu18.04的以太网口的IP 5.3 打开Windows系统网络连接配置以太网口的IP 将其配置为如下IP,保证和SOM-RK3399板子在同一网段 |
5.4 配置SOM-RK3399板子的IP
6.1 在UBuntu18.04上搭建NFS服务器 6.1.1 安装NFS Server sudo apt-get install nfs-kernel-server 6.1.2 配置NFS Server,它的配置文件是/etc/exports 创建NFS共享目录som_rk3399_nfs $ mkdir /home/bruce/Code/Projects/som_rk3399_nfs $ cd /home/bruce/Code/Projects 设置共享文件夹的权限$ sudo chmod -R 777 som_rk3399_nfs 设置共享文件夹的所有者sudo chown bruce:bruce som_rk3399_nfs/ -R 6.1.3 编辑/etc/exports文件 # /etc/exports: the access control list for filesystems which may be exported # to NFS clients. See exports(5). # # Example for NFSv2 and NFSv3: # /srv/homes hostname1(rw,sync,no_subtree_check) hostname2(ro,sync,no_subtree_check) # # Example for NFSv4: # /srv/nfs4 gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check) # /srv/nfs4/homes gss/krb5i(rw,sync,no_subtree_check) # /home/bruce/Code/Projects/som_rk3399_nfs *(rw,sync,no_root_squash)
6.1.4 重启NFS服务(每次修改/etc/exports文件后都需要重新启动 NFS 服务) sudo /etc/init.d/nfs-kernel-server restart 6.1.5 在UBuntu18.04本机上测试搭建的NFS服务器是否成功 将共享目录挂载到UBuntu18.04本机上的/mnt目录,随便在som_rk3399_nfs目录中或者/mnt中创建一个文件,看som_rk3399_nfs目录和/mnt中是否都存在.$ sudo mount -t nfs 192.168.1.100:~/Code/Projects/som_rk3399_nfs /mnt -o nolock #(注意:这种方式是不行的,必须使用绝对路径使用~挂载会失败,输出如下的内容:) mount.nfs: access denied by server while mounting localhost:~/Code/Projects/som_rk3399_nfs $ sudo mount -t nfs localhost:/home/bruce/Code/Projects/som_rk3399_nfs /mnt -o nolock 6.1.6 卸载挂载的共享目录 $ sudo umount /mnt 6.2 在SOM-RK3399开发板上挂载UBuntu18.04上的NFS服务器的共享目录 在SOM-RK3399开发板上,我烧写的是FriendlyELEC系统。6.2.1 在SOM-RK3399开发板的FriendlyELEC系统上安装NFS服务 $ sudo apt-get update $ sudo apt-get install nfs-kernel-server 6.2.2 重启NFS服务 pi@SOM-RK3399v2:~$ sudo /etc/init.d/nfs-kernel-server restart [ ok ] Restarting nfs-kernel-server (via systemctl): nfs-kernel-server.service. 6.2.3 测试和Ubuntu18.0.4的网络是否连通 Ubuntu18.0.4的主机的IP是192.168.1.100,SOM-RK3399板子的IP地址是192.168.1.10,它们之间是通过一根网线连接的。6.2.4 将Ubuntu18.0.4上的共享目录som_rk3399_nfs挂载到开发板上 $ mkdir /home/pi/mountHost $ sudo mount -t nfs 192.168.1.100:/home/bruce/Code/Projects/som_rk3399_nfs /home/pi/mountHost -o nolock 6.2.4 编辑SOM-RK3399的/etc/fstab文件,使开机自动挂载NFS服务器共享目录 pi@SOM-RK3399v2:~$ cat /etc/fstab 192.168.1.100:/home/bruce/Code/Projects/som_rk3399_nfs /home/pi/mountHost nfs defaults 0 0 pi@SOM-RK3399v2:~$ 7. 在SOM-RK3399开发板上安装sshd pi@SOM-RK3399v2:~$ sudo apt-get install ssh 7.1 重启sshd服务 pi@SOM-RK3399v2:~$ service sshd start 或 /etc/rc.d/init.d/sshd restart 7.2 打开MobaXterm连接开发板 8. 配置Ubuntu18.04上的Qt开发环境 打开Qt Creator选择Tools–>Options8.1 配置编译器
选择的是自己编译Qt源码安装目录下的qmake8.3 配置build套件 9. 配置SOM-RK3399板子上的开发环境 9.1 打包交叉编译的Qt5.14.2 bruce@bruce:~/Code/qtsourcecode/shadow_build_qt_5.14.2/sy***ase$ ls qt5.14.2_install bin doc include lib mkspecs plugins qml bruce@bruce:~/Code/qtsourcecode/shadow_build_qt_5.14.2/sy***ase$ tar -cvzf qt5.14.2_install.tar.gz qt5.14.2_install/ 9.2 将qt5.14.2_install.tar.gz 拷贝到共享目录 $ cp qt5.14.2_install.tar.gz ~/Code/Projects/som_rk3399_nfs/ 9.3 将qt5.14.2_install.tar.gz解压到SOM-RK339开发板上的/opt目录 pi@SOM-RK3399v2:~/mountHost$ sudo tar -xvf qt5.14.2_install.tar.gz -C /opt pi@SOM-RK3399v2:~/mountHost$ ls /opt/qt5.14.2_install/ bin doc include lib mkspecs plugins qml 9.4 编辑/etc/profile,配置QT环境变量 将原有内容注释掉,修改为如下内容# /etc/profile: system-wide .profile file for the Bourne shell (sh(1)) # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...). if [ "${PS1-}" ]; then if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then # The file bash.bashrc already sets the default PS1. # PS1='h:w$ ' if [ -f /etc/bash.bashrc ]; then . /etc/bash.bashrc fi else if [ "`id -u`" -eq 0 ]; then PS1='# ' else PS1='$ ' fi fi fi if [ -d /etc/profile.d ]; then for i in /etc/profile.d/*.sh; do if [ -r $i ]; then . $i fi done unset i fi #QTDIR=/usr/local/Trolltech/Qt-5.10.0-rk64one #QT_QPA_PLATFORM=xcb #QT_QPA_EGLFS_HIDECURSOR=0 #QTWEBENGINE_DISABLE_SANDBOX=1 #QT_QPA_FONTDIR=/usr/share/fonts/truetype/ubuntu-font-family #QT_QPA_PLATFORM_PLUGIN_PATH=/usr/local/Trolltech/Qt-5.10.0-rk64one/plugins/ export QTDIR=/opt/qt5.14.2_install export LD_LIBRARY_PATH=$QTDIR/lib:$LD_LIBRARY_PATH export QT_QPA_PLATFORM_PLUGIN_PATH=$QTDIR/plugins export QT_QPA_PLATFORM=linuxfb export QT_QPA_FONTDIR=/usr/share/fonts/truetype/ubuntu-font-family 10. 测试 10.1 在Ubuntu18.0.4打开QCreator创建一个测试工程 10.2 在主界面添加一个按钮并实现一个槽用来更改按钮的文本 按钮相应clicked()的槽void MainWindow::on_testButton_clicked() { auto curtext = this->ui->testButton->text(); if(curtext == tr("点击---")) this->ui->testButton->setText(tr("点击+++")); else this->ui->testButton->setText(tr("点击---")); } 10.3 在Ubuntu18.04上只编译Qt测试工程 执行qmake 10.4 将编译成功的可执行文件test_som_rk3399拷贝到共享目录 bruce@bruce:~/Code/Projects/som_rk3399_nfs$ ls test_som_rk3399 10.5 在SOM-RK3399开发板上执行./test_som_rk3399 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1906 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
2382 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
5175 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
1336 浏览 0 评论
GMT+8, 2024-11-22 06:05 , Processed in 0.618064 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
