本文档基于友善NanoPC-T4制作,主要是为了记录做Linux板级驱动全过程,以备忘。
创建soc目录 1、在drivers/soc建立自己的板目录,在这里我创建venkeeboard cd drivers/soc mkdir venkeeboard 2、在drivers/soc/venkeeboard目录建立自己的一个Kconfig文件 cd venkeeboard vi Kconfig 内容如下 # # Machine drivers # if ARCH_ROCKCHIP config MACH_VENKEEBOARD # 这个在编译dts时用到 bool "Venkee board Machine" default y endif 3、复制原厂的board.c文件到drivers/soc/venkeeboard目录 cp ../friendlyelec/board.c . vi board.c 修改代码片段 static const struct of_device_id board_sys_of_match[] = { { .compatible = "venkee,board" }, // 设置自己的compatible,跟一会修改的dts的compatible保持一致 {} }; MODULE_DEVICE_TABLE(of, board_sys_of_match); static struct platform_driver board_sys_driver = { .probe = board_sys_probe, .driver = { .name = "venkee-board", .of_match_table = board_sys_of_match, }, }; static int __init board_sys_init(void) { return platform_driver_register(&board_sys_driver); } device_initcall(board_sys_init); 4、复制原厂的Makefile文件到drivers/soc/venkeeboard目录 cp ../friendlyelec/Makefile . vi Makefile 内容修改为 obj-$(CONFIG_MACH_VENKEEBOARD) += board.o 5、修改drivers/soc目录下的Kconfig cd .. vi Kconfig 增加内容 source "drivers/soc/venkeeboard/Kconfig" # 使用自己建立的Kconfig 6、修改drivers/soc目录下的Makefile vi Makefile 增加内容 obj-$(CONFIG_MACH_VENKEEBOARD) += venkeeboard/ 创建dts文件 1、进入arch/arm64/boot/dts/rockchip目录,执行复制操作 cd ../../arch/arm64/boot/dts/rockchip/ cp rk3399-nanopi4-cifisp.dtsi rk3399-venkee-cifisp.dtsi cp rk3399-nanopi4-common.dtsi rk3399-venkee-common.dtsi cp rk3399-nanopi4-rev00.dts rk3399-venkee-rev00.dts 2、修改rk3399-venkee-common.dtsi文件 vi rk3399-venkee-common.dtsi 原来的内容: #define NANOPI4_RK_CIF_ISP10 #include "rk3399-nanopi4-cifisp.dtsi" / { model = "FriendlyElec boards based on Rockchip RK3399"; compatible = "friendlyelec,nanopi4", "rockchip,rk3399"; ...... mach: board { compatible = "friendlyelec,board"; machine = "NANOPI4"; hwrev = <255>; model = "NanoPi 4 Series"; }; ...... }; 修改后的内容: #define VENKEE_RK_CIF_ISP10 #include "rk3399-venkee-cifisp.dtsi" / { model = "Venkee pads based on Rockchip RK3399"; // model需要在rev00具体dts重新定义 compatible = "venkee,pads", "rockchip,rk3399"; // compatible需要在rev00具体dts重新定义 ...... mach: board { compatible = "venkee,pad"; // 这个需要跟board.c文件里面的compatible保持一致 machine = "Pad Machine"; // machine需要在rev00具体dts重新定义 hwrev = <255>; // hwrev需要在rev00具体dts重新定义 model = "Pad Model"; // model需要在rev00具体dts重新定义 }; ...... }; 3、修改rk3399-venkee-cifisp.dtsi文件 原来的内容: #if defined(NANOPI4_RK_CIF_ISP10) 修改后的内容 #if defined(VENKEE_RK_CIF_ISP10) 4、修改rk3399-venkee-rev00.dtsi文件 原来的内容 #include "rk3399-nanopi4-common.dtsi" / { model = "FriendlyElec NanoPC-T4"; compatible = "friendlyelec,nanopc-t4", "rockchip,rk3399"; }; &mach { hwrev = <0>; model = "NanoPC-T4"; }; 修改后的内容 #include "rk3399-venkee-common.dtsi" / { model = "Venkee Pad1S"; // 重新定义model compatible = "venkee,pad1s", "rockchip,rk3399"; // 重新定义compatible }; &mach { hwrev = <0>; // 重新定义hwrev machine = "Pad1S"; // 重新定义machine model = "Pad 1 Series"; // 重新定义model }; 5、修改Makefile vi Makefile 原来的内容 ifeq ($(CONFIG_MACH_NANOPI4),y) dtb-$(CONFIG_ARCH_ROCKCHIP) += rk3399-nanopi4-rev00.dtb rk3399-nanopi4-rev01.dtb rk3399-nanopi4-rev04.dtb rk3399-nanopi4-rev06.dtb else ...... endif always := $(dtb-y) subdir-y := $(dts-dirs) clean-files := *.dtb 修改后的内容 ifeq ($(CONFIG_MACH_VENKEEBOARD),y) // 这里使用了Kconfig配置的变量 dtb-$(CONFIG_ARCH_ROCKCHIP) += rk3399-venkee-rev00.dtb else ...... endif always := $(dtb-y) subdir-y := $(dts-dirs) clean-files := *.dtb 创建构建配置 1、进入arch/arm64/configs目录 cd ../../../configs/ 2、复制nanopi4_linux_defconfig文件为venkee_linux_defconfig cp nanopi4_linux_defconfig venkee_linux_defconfig 3、修改顶层架构Makefile cd ../ vi Makefile 增加生成image的目标(参照nanopi4) ifeq ($(CONFIG_MACH_VENKEEBOARD),y) DTBS := rockchip/rk3399-venkee-rev*.dtb PHONY += venkee-images venkee-bootimg venkee-images: dtbs kernel.img rklogo $(Q)scripts/resource_tool --dtbname $(objtree)/arch/arm64/boot/dts/$(DTBS) $(LOGO) $(LOGO_KERNEL) @echo ' Image: resource.img (with $(DTBS) $(LOGO) $(LOGO_KERNEL)) is ready' venkee-bootimg: venkee-images $(Q) if [ -x $(srctree)/scripts/mkbootimg ]; then $(srctree)/scripts/mkbootimg --kernel $(objtree)/arch/arm64/boot/Image --second resource.img -o boot.img && echo ' Image: boot.img (with Image resource.img) is ready'; $(srctree)/scripts/mkbootimg --kernel $(objtree)/arch/arm64/boot/Image.lz4 --second resource.img -o zboot.img && echo ' Image: zboot.img (with Image.lz4 resource.img) is ready'; fi endif 构建 1、进入源代码顶层目录并生成构建文件 cd ../../ make ARCH=arm64 venkee_linux_defconfig 2、执行构建 make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- -j6 venkee-bootimg 3、生成相应的image如图 修改u-boot环境变量硬编码 FriendlyElec做u-boot的时候,把dtb名称硬编码到了环境变量,如果不修改会导致启动不了,或者需要手动修改环境变量才能启动 1、进入uboot-rockchip/board/rockchip/rk33xx,修改rk33xx.c 原来的代码 static void set_dtb_name(void) { char info[64] = {0, }; snprintf(info, ARRAY_SIZE(info), "rk3399-nanopi4-rev%02x.dtb", get_board_rev()); setenv("dtb_name", info); } 修改后的代码 static void set_dtb_name(void) { char info[64] = {0, }; snprintf(info, ARRAY_SIZE(info), "rk3399-venkee-rev%02x.dtb", get_board_rev()); setenv("dtb_name", info); } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
1627 浏览 1 评论
2822 浏览 1 评论
3745 浏览 2 评论
RK3568平台,进入烧录模式,部分电脑提示无法识别,无法烧录
6634 浏览 1 评论
【RK3568 Android11.0】如何在设置-显示-HDMI-分辨率设置中添加3840*2160的选项?
9276 浏览 1 评论
GMT+8, 2024-6-30 18:44 , Processed in 0.620531 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
