思路:跟据显示器设置1080P60(目前显示到1080P60),如果显示信息最大的解决P08只进行大小,则按edididI2Cnct @nct-admin:/mnt/tsdc2/RK3399System/RK3399-JD4 -Android7.1/kernel/drivers$ git diff 。 diff --git a/RK3399-JD4-Android7.1/kernel/drivers/gpu/drm/bridge/dw-hdmi.cb/RK3399-JD4-Android7.1/kernel/drivers/gpu/drm/bridge/dw- hdmi.c 索引 835e78cca6..6f998cf7ea 100644 --- a/RK3399-JD4-Android7.1/kernel/drivers/gpu/drm/bridge/dw-hdmi.c +++ b/RK3399-JD4-Android7.1/ kernel/drivers/gpu/drm/bridge/dw-hdmi.c @@ -2442,21 +2442,46 @@ dw_hdmi_connector_detect(struct drm_connector *connector, bool force) static int dw_hdmi_connector_get_modes(struct drm_connector *connector) { + bool isVertical =假; + 整数最小值 = 0; + 整数最大值 = 0; 结构 dw_hdmi *hdmi = container_of(连接器,结构 dw_hdmi, 连接器); 结构 edid *edid; 结构 drm_display_mode *mode; - const u8 def_modes[6] = {4, 16, 31, 19, 17, 2}; + //const u8 def_modes[6] = {4, 16, 31, 19, 17, 2}; + 常量 u8 def_modes[6] = {16, 4, 31, 19, 17, 2}; 结构 hdr_static_metadata *metedata = &connector-》display_info.hdmi.hdr_panel_metadata; int i, ret = 0; 如果 (!hdmi-》ddc) 返回 0; - //@howard 20210604 - //edid = drm_get_edid(connector, hdmi-》ddc); - edid = NULL; - printk(“霍华德###hdmi, %sn”, __FUNCTION__); + + printk(“霍华德###hdmi, %s:n”, __FUNCTION__); + + edid = drm_get_edid(连接器,hdmi-》ddc); + + /** + * 由霍华德添加 + */ + if(edid) { + printk(“Howard###hdmi, %s: %dX%dn”, __FUNCTION__, edid-》width_cm, edid-》高度_厘米); + } + + if(edid-》width_cm 《 edid-》height_cm ){ + isVertical = true; + min = edid-》width_cm; + 最大 = edid-》height_cm; + }else{ + max = edid-》 + min = edid-》height_cm; + } + //48X27 + if(min 》 27 && max 》 48){ + edid = NULL; + } + if (edid) { dev_dbg(hdmi-》dev, “得到 edid: width[%d] x height[%d]n”, edid-》width_cm, edid-》height_cm); diff --git a/RK3399-JD4-Android7.1/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi.hb/RK3399-JD4-Android7.1/kernel/drivers/video/rockchip/hdmi/rockchip- hdmi.h index 08e1f9b47e..06f097f7a2 100644 --- a/RK3399-JD4-Android7.1/kernel/drivers/video/rockchip/hdmi/rockchip-hdmi.h +++ b/RK3399-JD4-Android7.1/内核/驱动程序/视频/rockchip/hdmi/rockchip-hdmi.h @@ -566,8 +566,9 @@结构HDMI { 的#define HDMI_AUTO_CONFIG假 / *默认HDMI参见模式* / - #定义HDMI_VIDEO_DEFAULT_MODE HDMI_1280X720P_60HZ - / * * HDMI_1920X1080P_60HZ / + //#限定HDMI_VIDEO_DEFAULT_MODE HDMI_1280X720P_60HZ +#限定HDMI_VIDEO_DEFAULT_MODE HDMI_1920X1080P_60HZ + #define HDMI_VIDEO_DEFAULT_COLORMODE HDMI_COLOR_AUTO #define HDMI_VIDEO_DEFAULT_COLORDEPTH 8 (END) diff --git a/RK3399-JD4-Android7.1/kernel/drivers/gpu/drm/rockchip/dw_hdmi-rockchip.cb/RK3399-JD4-Android7.1/内核/驱动程序/gpu/drm/rockchip/dw_hdmi-rockchip.c index e1f50de45c..7a3cb8fde5 100644 --- a/RK3399-JD4-Android7.1/kernel/drivers/gpu/drm/rockchip/dw_hdmi-rockchip.c +++ b/RK3399-JD4-Android7.1/kernel/drivers /gpu/drm/rockchip/dw_hdmi-rockchip.c @@ -484,11 +484,14 @@ dw_hdmi_rockchip_mode_valid(struct drm_connector *connector, * 如果 sink max TMDS clock 《 340MHz, 我们应该检查 mode pixel * clock 》 340MHz是否为 YCbCr420 */ +//@howard 20210604 disable + printk(“Howard###hdmi, %sn”, __FUNCTION__); +#if 0 if (mode-》clock 》 340000 && connector-》display_info .max_tmds_clock 《 340000 && !drm_mode_is_420(&connector-》display_info, mode)) 返回 MODE_BAD; - +#endif |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1133 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1367 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7082 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2170 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2715 浏览 0 评论
/9
GMT+8, 2025-12-14 20:40 , Processed in 0.502825 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3021
