[ 2.002835] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 2.002992] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 2.003029] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 2.003094] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 2.003164] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 2.003178] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 2.004431] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 2.004506] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 2.004526] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 2.004580] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 2.004704] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 2.005047] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 2.005203] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 2.017696] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.031967] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized [ 2.032446] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.034361] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ 2.034386] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ 2.062984] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 2.115687] mmc1: MAN_BKOPS_EN bit is not set [ 2.131736] mmc1: new HS400 MMC card at address 0001 [ 2.132971] mmcblk1: mmc1:0001 MCG8GC 58.2 GiB [ 2.133959] mmcblk1boot0: mmc1:0001 MCG8GC partition 1 4.00 MiB [ 2.134926] mmcblk1boot1: mmc1:0001 MCG8GC partition 2 4.00 MiB [ 2.135958] mmcblk1rpmb: mmc1:0001 MCG8GC partition 3 4.00 MiB [ 2.136600] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 2.136622] trust: 0x000800000 -- 0x000c00000 (4 MB) [ 2.136635] misc: 0x000c00000 -- 0x001000000 (4 MB) [ 2.136647] resource: 0x001000000 -- 0x002000000 (16 MB) [ 2.136659] kernel: 0x002000000 -- 0x003800000 (24 MB) [ 2.136671] boot: 0x003800000 -- 0x005800000 (32 MB) [ 2.136684] recovery: 0x005800000 -- 0x008800000 (48 MB) [ 2.136696] backup: 0x008800000 -- 0x00f800000 (112 MB) [ 2.136708] cache: 0x00f800000 -- 0x017800000 (128 MB) [ 2.136721] system: 0x017800000 -- 0x0d7800000 (3072 MB) [ 2.136735] metadata: 0x0d7800000 -- 0x0d8800000 (16 MB) [ 2.136748] baseparamer: 0x0d8800000 -- 0x0d8c00000 (4 MB) [ 2.136761] frp: 0x0d8c00000 -- 0x0d8c80000 (0 MB) [ 2.136773] userdata: 0x0d8c80000 -- 0xe8f400000 (56167 MB) [ 2.136816] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 [ 2.481883] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 2.482061] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 2.482113] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 2.482169] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 2.482287] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 2.482316] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 2.482769] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq [ 2.494688] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.507803] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized [ 2.556671] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ 2.559525] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 2.561212] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 2.565389] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ 2.623906] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0) [ 2.628545] init: OK,EMMC DRIVERS INIT OK [ 2.932402] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc [ 2.932568] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0 [ 2.933322] EXT4-fs (mmcblk1p9): Ignoring removed nomblk_io_submit option [ 2.937456] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro [ 2.937600] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=0: Success [ 2.956910] fs_mgr: check_fs(): unmount(/cache) succeeded [ 2.958200] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache [ 2.964050] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 2.966278] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 2.966313] mmcblk1: retrying because a re-tune was needed [ 2.988024] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 2.990140] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 2.990184] mmcblk1: error -84 transferring data, sector 973048, nr 256, cmd response 0x900, card status 0x0 [ 2.990260] mmcblk1: retrying using single block read [ 3.038680] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.040785] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 3.040818] mmcblk1: retrying because a re-tune was needed [ 3.059313] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.061430] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 3.061469] mmcblk1: error -84 transferring data, sector 972800, nr 224, cmd response 0x900, card status 0x0 [ 3.061536] mmcblk1: retrying using single block read [ 3.106220] mmcblk1: error -84 transferring data, sector 972989, nr 35, cmd response 0x900, card status 0x0 [ 3.106289] blk_update_request: I/O error, dev mmcblk1, sector 972989 [ 3.141668] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.143802] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 3.143850] mmcblk1: retrying because a re-tune was needed [ 3.162815] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.165056] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 3.165113] mmcblk1: error -84 transferring data, sector 972984, nr 8, cmd response 0x900, card status 0x0 [ 3.165155] mmcblk1: retrying using single block read [ 3.184661] mmcblk1: error -84 transferring data, sector 972989, nr 3, cmd response 0x900, card status 0x0 [ 3.184715] blk_update_request: I/O error, dev mmcblk1, sector 972989 [ 3.204352] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.206483] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 3.206525] mmcblk1: retrying because a re-tune was needed [ 3.225395] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.227528] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 3.227572] mmcblk1: error -84 transferring data, sector 972984, nr 8, cmd response 0x900, card status 0x0 [ 3.227603] mmcblk1: retrying using single block read [ 3.246588] mmcblk1: error -84 transferring data, sector 972989, nr 3, cmd response 0x900, card status 0x0 [ 3.246633] blk_update_request: I/O error, dev mmcblk1, sector 972989 [ 3.263636] e2fsck[225]: unhandled level 3 translation fault (7) at 0x7f9fc2d4a4, esr 0x82000007 [ 3.263682] pgd = ffffffc0e8e0c000 [ 3.263702] [7f9fc2d4a4] *pgd=00000000e8473003, *pud=00000000e8473003, *pmd=00000000e8479003, *pte=0000000000000000 [ 3.263758] [ 3.263783] CPU: 4 PID: 225 Comm: e2fsck Not tainted 4.4.36 #633 [ 3.263807] Hardware name: rockchip,rk3399-excavator-edp (DT) [ 3.263829] task: ffffffc0e8534980 ti: ffffffc0e858c000 task.ti: ffffffc0e858c000 [ 3.263854] PC is at 0x7f9fc2d4a4 [ 3.263871] LR is at 0x44 [ 3.263888] pc : [<0000007f9fc2d4a4>] lr : [<0000000000000044>] pstate: a0000000 [ 3.263908] sp : 0000007fd2ee0430 [ 3.263924] x29: 0000007fd2ee0430 x28: 0000007fd2ee0600 [ 3.263957] x27: 00000000ffffffd8 x26: 0000007fd2ee05d0 [ 3.263989] x25: 0000000000000000 x24: 0000007fd2ee0c58 [ 3.264020] x23: 00000000ffffffff x22: 0000007f9fc39170 [ 3.264050] x21: 0000007fd2ee05c0 x20: 0000007fd2ee06b8 [ 3.264080] x19: 0000007fd2ee05b4 x18: 0000000000000000 [ 3.264110] x17: 0000007fd2ee0da0 x16: 00000000ffffffe0 [ 3.264140] x15: 0000000000000000 x14: 0000000000000000 [ 3.264201] x13: 0000007fd2ee0630 x12: 0000007fd2ee05a7 [ 3.264232] x11: 0000007fd2ee05a8 x10: 0000007fd2ee0d78 [ 3.264263] x9 : 0000007f9fc56018 x8 : 0000000000000064 [ 3.264293] x7 : 0000007f9fc56098 x6 : 0000007fd2ee06c8 [ 3.264323] x5 : 0000007f9fc56c58 x4 : 0000007f9fc3bf70 [ 3.264353] x3 : 0000000000000002 x2 : 0000000000000030 [ 3.264383] x1 : 0000000000000003 x0 : 00000000ffffffd8 [ 3.264413] [ 3.264907] e2fsck: e2fsck terminated by signal 7 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1240 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
6253 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2055 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2599 浏览 0 评论
2596 浏览 0 评论
/9
GMT+8, 2025-12-11 08:24 , Processed in 1.042291 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1997
