RK3288 适配LVDS屛 记录 :
在设备树增加LVDS相关节点: 源码/kernel/arch/arm/boot/das/rk3288.dts 1、添加背光节点 backlight: backlight { status = "okay"; compatible = "pwm-backlight"; brightness-levels = < 255 254 253 252 251 250 249 248 247 246 245 244 243 242 241 240 239 238 237 236 235 234 233 232 231 230 229 228 227 226 225 224 223 222 221 220 219 218 217 216 215 214 213 212 211 210 209 208 207 206 205 204 203 202 201 200 199 198 197 196 195 194 193 192 191 190 189 188 187 186 185 184 183 182 181 180 179 178 177 176 175 174 173 172 171 170 169 168 167 166 165 164 163 162 161 160 159 158 157 156 155 154 153 152 151 150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0>; default-brightness-level = <200>; pinctrl-names = "default"; pinctrl-0 = <&bl_en>; enable-gpios = <&gpio7 RK_PA2 GPIO_ACTIVE_HIGH>; pwms = <&pwm0 0 1000000 PWM_POLARITY_INVERTED>; }; &pwm0 { status = "okay"; }; 2、添加LVDS节点 RK3288 有2个视觉输出处理器 yopb vopl vopb 支持4K高清输出 vopl 支持2K视频输出 route { route_lvds: route-lvds { status = "okay"; // 使能LVDS logo,uboot = "logo.bmp"; // 显示启动LOGO logo,kernel = "logo_kernel.bmp"; // 显示内核LOGO logo,mode = "center"; // 居中显示 charge_logo,mode = "center"; // 居中显示 connect = <&vopl_out_lvds>; // 连接视频控制器vopl }; lvds_panel: lvds-panel { status = "okay"; ; pinctrl-0 = <&lcd_rst>; power-supply = <&vcc_lcd>; backlight = <&backlight>; enable-gpios = <&gpio7 RK_PA4 GPIO_ACTIVE_HIGH>; enable-delay-ms = <10>; bus-format = rockchip,data-mapping = "vesa"; // 数据格式 rockchip,data-width = <24>; // 颜色位数 rockchip,output = "lvds"; display-timings { native-mode = <&timing1>; // LVDS屛时序参数,参照具体数据手册 timing1: timing1 { clock-frequency = <60000000>; hactive = <800>; vactive = <1280>; hback-porch = <24>; hfront-porch = <72>; hsync-len = <24>; vback-porch = <10>; vfront-porch = <12>; vsync-len = <2>; pixelclk-active = <0>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; }; }; &lvds { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&lcdc_ctl>; ports { lvds_out: port@1 { reg = <1>; #address-cells = <1>; #size-cells = <0>; lvds_out_panel: endpoint@0 { reg = <0>; remote-endpoint = <&panel_in_lvds>; }; }; }; }; &lvds_in_vopb { status = "disabled"; // LVDS使用vopl, 关闭vopb }; 3、在 源码/device/rockchip/rk3288/device.mk 增加输出屏幕选项 #SCREEN DSI EDP HDMI-A LVDS PRODUCT_PROPERTY_OVERRIDES += sys.hwc.device.primary=LVDS // 主屏 sys.hwc.device.extend=HDMI-A // 副屛 ro.sys.rotation.sensor=false |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 20:24 , Processed in 0.727513 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1571
