注意了! - 开始了
一个新安装的编译器的编译,使用的是: Ubuntu14.04.2 LTS (GNU/Linux 3.16.0-30-generic x86_64) 构建会遇到一些小程序包的错误,如下。 Build Kernel: Error 1: build@build--machine:~/rk3288/kernel$ make rk3288-tb_8846.img 。..。.. LD vmlinux SORTEX vmlinux SYSMAP System.map OBJCOPY arch/arm/boot/Image Kernel: arch /arm/boot/Image 准备好 了 AS arch/arm/boot/compressed/head.o LZO arch/arm/boot/compressed/piggy.lzo /bin/sh: 1: lzop: not found CC arch/arm/boot/ compressed/misc.o make[2]: *** [arch/arm/boot/compressed/piggy.lzo] 错误 1 make[2]: *** Waiting for unfinished jobs.。.. make[2]: *** wait: 没有子进程。 停止。 make[1]: *** [arch/arm/boot/compressed/vmlinux] 错误 2 make: *** [zImage] 错误 2 解决办法: #sudo apt-get install lzop 错误 2: build@build--machine :~/rk3288/kernel$ make rk3288-tb_8846.img scripts/kconfig/conf --silentoldconfig Kconfig ^C build@build--machine:~/rk3288/kernel$ make rk3288-tb_8846.img CC scripts/mod/devicetable- offsets.s GEN scripts/mod/devicetable- offsets.h HOSTCC scripts/mod/file2alias.o HOSTLD scripts/mod/modpost CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h‘ 是最新的。 CALL scripts/checksyscalls.sh CHK include/generated/compile.h GEN drivers/video/rockchip/screen/lcd.h Kernel: arch/arm/boot/Image is ready LD arch/arm/boot/compressed/vmlinux OBJCOPY arch/ arm/boot/zImage Kernel: arch/arm/boot/zImage is ready make: *** [kernel.img] Error 127 #### make failed to build some targets (18 seconds) #### 解决办法: 安装64位机子对32位程序运行的支持。 #sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 另外,Android 5.1用的java环境是openjdk-7,否则报错。 解决办法: #sudo apt-get install openjdk-7-jdk # PATH=/usr/lib/jvm/java-7-openjdk-amd64/bin:$PATH Build Android: Error1: build@build--machine:~/rk3288/kernel$ make -j8 。..。.. 注意文件:external/jarjar/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src //framework/jarjar.jar.txt Yacc:aidl 《= frameworks/base/tools/aidl/aidl_language_y.y prebuilts/misc/linux-x86/bison/bison -d -o out/host/linux-x86/obj/ EXECUTABLES/aidl_intermediates/aidl_language_y.cpp frameworks/base/tools/aidl/aidl_language_y.y 通知文件:frameworks/base/tools/aidl/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/aidl .txt词法 :aidl 《= frameworks/base/tools/aidl/aidl_language_l.l 制作:*** [out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp] 管道损坏 :*** 正在等待未完成的作业。..。 flex-2.5.39:致命的内部错误,/usr/bin 的 exec /m4 failed frameworks/base/tools/aidl/aidl_language_l.l:55: 警告,规则 无法匹配 make: *** [out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp]管道 损坏 : *** 删除文件 `out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp’ 注意:一些输入文件使用未经检查或不安全的 操作。 注意:使用 -Xlint:unchecked 重新编译以获取详细信息。 注意:某些输入文件使用未经检查或不安全的 操作。 注意:使用 -Xlint:unchecked 重新编译以获取详细信息。 注意:某些输入文件使用或覆盖已弃用的 API。 注意:使用 -Xlint:deprecation 重新编译以获取详细信息。 注意:某些输入文件使用未经检查或不安全 的操作。 注意:使用 -Xlint 重新编译:unchecked for details. 解决办法: #sudo apt-get install bison Error2: build@build--machine:~/rk3288/kernel$ make -j8 Copy: out/target/product/rk3288/system /etc/.allBlock Copy: out/target/product/rk3288/system/etc/.videoBlock Copy xml: out/target/product/rk3288/system/etc/GS8604.xml /bin/bash: xmllint: command not found make : *** [out/target/product/rk3288/system/etc/GS8604.xml] 错误 127 make: *** Waiting for unfinished jobs.。.. 准备 StaticLib: libc_common [包括 out/target/product/rk3288/obj/STATIC_LIBRARIES/libc_thread_atexit_impl_intermediates/libc_thread_atexit_impl.a] 准备 StaticLib: libc_common [包括 out/target/product /rk3288/obj/STATIC_LIBRARIES/libc_tzcode_intermediates/libc_tzcode.a] target StaticLib: libc_common (out/target/product/rk3288/obj/STATIC_LIBRARIES/libc_common_intermediates/libc_common.a) #### make 无法构建一些目标 (12:49 (mm:ss)) #### 解决方法: #sudo apt-get install libxml2-utils |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 02:47 , Processed in 0.731771 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1921
