#/bin/bash
#Test for auto compile Android7.1.2 source code echo "==================================================================" echo "======================Android7.1.2 compile========================" echo "==================================================================" echo "Show current path:" pwd echo "======================UBunut16.04LTS 64bit OS=====================" echo "rn" echo "======================1.Install JDK===============================" sudo add-apt-repository ppa:openjdk-r/ppa sudo apt-get update sudo apt-get install openjdk-8-jdk echo "======================2.Config env variable=======================" export JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64 export JRE_HOME=$JAVA_HOME/jre export CLASSPATH=.:$JAVA_HOME/lib:$JRE_HOME/lib:$JAVA_HOME/lib/tools.jar export PATH=$PATH:$JAVA_HOME/bin:$JRE_HOME/bin source /etc/profile echo "======================3.Chech JDK install success or not==========" java -version java javac echo "======================4.Install NDK===============================" echo "NDK is not used, so do not install there..." echo "======================5.Install Cross compilation tools===========" sudo apt-get install gcc-arm-linux-gnueabihf sudo apt-get install lzop sudo apt-get install libncurses5-dev sudo apt-get install libssl1.0.0 sudo apt-get install libssl-dev sudo apt-get install libc6:i386 sudo apt-get install zip sudo apt-get install unzip sudo apt-get install git-core sudo apt-get install gnupg sudo apt-get install flex sudo apt-get install bison sudo apt-get install gperf sudo apt-get install build-essential sudo apt-get install curl sudo apt-get install zlib1g-dev sudo apt-get install gcc-multilib sudo apt-get install g++-multilib sudo apt-get install libc6-dev-i386 sudo apt-get install lib32ncurses5-dev sudo apt-get install x11proto-core-dev sudo apt-get install libx11-dev sudo apt-get install lib32z-dev sudo apt-get install ccache sudo apt-get install libgl1-mesa-dev sudo apt-get install libxml2-utils sudo apt-get install xsltproc echo "======================6.Update system==============================" sudo apt-get update echo "======================7.Compile u-boot=============================" echo "Please waiting ..." cd u-boot make rk3288_secure_defconfig make cd .. echo "======================8.Compile kernel=============================" echo "Please waiting..." cd kernel make ARCH=arm rockchip_defconfig make ARCH=arm rk3288-miniarm.img cd .. echo "======================9.Compile kernel=============================" source build/envsetup.sh lunch rk3288-userdebug make ./mkimage.sh echo "======================10.Collecting *.img & mkupdate================" echo "Generating update.img, user can use windows tools convert to SD image" cd RKTools/linux/Linux_Pack_Firmware/rockdev ./collectImages.sh && ./mkupdate.sh 欢迎大家批评指正。可以加QQ:727169295,一起交流学习~~~ 谢谢~~ |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 01:23 , Processed in 0.602166 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1343
