Platform: ROCKCHIP
OS: Android 6.0 Kernel: 3.10.92 user版sd固件升級啟動之后開機出現如下error log: [ 3.036440] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3) [ 3.036451] ov5640_front_3(rk_cam_sensor:333): read reg(0x300a val:0x0) failed, try to read again! [ 3.036469] ov5640_front_3(rk_cam_sensor:697): read chip id failed [ 3.036560] ret: 0 [ 3.465624] binder: 161:161 transaction failed 29189, size 0-0 [ 4.449713] binder: 161:161 transaction failed 29189, size 0-0 [ 5.433801] binder: 161:161 transaction failed 29189, size 0-0 [ 6.417887] binder: 161:161 transaction failed 29189, size 0-0 [ 7.401973] binder: 161:161 transaction failed 29189, size 0-0 [ 8.386066] binder: 161:161 transaction failed 29189, size 0-0 [ 8.704273] [otg id chg] last id -1 current id 1 [ 8.704291] PortPower off [ 8.704298] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 8.803721] Using Buffer DMA mode [ 8.803733] Periodic Transfer Interrupt Enhancement - disabled [ 8.803739] Multiprocessor Interrupt Enhancement - disabled [ 8.803745] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 8.803752] ^^^^^^^^^^^^^^^^^Device Mode [ 9.294675] ***************vbus detect***************** [ 9.296859] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 9.370153] binder: 161:161 transaction failed 29189, size 0-0 [ 10.354240] binder: 161:161 transaction failed 29189, size 0-0 [ 11.338327] binder: 161:161 transaction failed 29189, size 0-0 [ 12.322412] binder: 161:161 transaction failed 29189, size 0-0 [ 13.306497] binder: 161:161 transaction failed 29189, size 0-0 [ 14.290582] binder: 161:161 transaction failed 29189, size 0-0 [ 15.274667] binder: 161:161 transaction failed 29189, size 0-0 [ 16.258752] binder: 161:161 transaction failed 29189, size 0-0 [ 17.242836] binder: 161:161 transaction failed 29189, size 0-0 原因: system分區默認是512M RKTools/linux/Linux_Pack_Firmware/rockdev/parameter: 0x00100000@0x00092000(system) 0x00100000,單位是512. 而user版本編譯出來的system分區大小超過了512M 解決方法: 擴大system分區. diff --git a/linux/Linux_Pack_Firmware/rockdev/parameter b/linux/Linux_Pack_Firmware/rockdev/parameter index 174241b..1048328 100644 --- a/linux/Linux_Pack_Firmware/rockdev/parameter +++ b/linux/Linux_Pack_Firmware/rockdev/parameter @@ -7,4 +7,4 @@ ATAG: 0x60000800 MACHINE: 3288 CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 -CMDLINE:console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00100000@0x00092000(system),0x00008000@0x00192000(metadata),0x00020000@0x0039A000(radical_update),-@0x003BA000(userdata) +CMDLINE:console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00200000@0x00092000(system),0x00008000@0x00292000(metadata),0x00020000@0x0049A000(radical_update),-@0x004BA000(userdata) |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 00:12 , Processed in 0.613692 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1372
