RK3568kernelarcharm64bootdtsrockchiprk3568-evb1-ddr4-v10.dtsi //重点是复位RESET &gmac0 { phy-mode = "rgmii"; clock_in_out = "output"; snps,reset-gpio = <&gpio1 RK_PB0 GPIO_ACTIVE_LOW>; snps,reset-active-low; /* Reset time is 20ms, 100ms for rtl8211f */ snps,reset-delays-us = <0 20000 100000>; assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>; assigned-clock-rates = <0>, <125000000>; pinctrl-names = "default"; pinctrl-0 = <&gmac0_miim &gmac0_tx_bus2 &gmac0_rx_bus2 &gmac0_rgmii_clk &gmac0_rgmii_bus>; tx_delay = <0x3c>; rx_delay = <0x2f>; phy-handle = <&rgmii_phy0>; status = "okay"; }; &mdio0 { rgmii_phy0: phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x0>; }; }; &gmac1 { phy-mode = "rgmii"; clock_in_out = "output"; snps,reset-gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_LOW>; snps,reset-active-low; /* Reset time is 20ms, 100ms for rtl8211f */ snps,reset-delays-us = <0 20000 100000>; assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>; assigned-clock-rates = <0>, <125000000>; pinctrl-names = "default"; pinctrl-0 = <&gmac1m1_miim &gmac1m1_tx_bus2 &gmac1m1_rx_bus2 &gmac1m1_rgmii_clk &gmac1m1_rgmii_bus>; tx_delay = <0x4f>; rx_delay = <0x26>; phy-handle = <&rgmii_phy1>; status = "okay"; }; &mdio1 { rgmii_phy1: phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x0>; }; }; 详细参考:rk3568RKDocscommonGMAC Rockchip_Developer_Guide_Ethernet_CN.pdf Rockchip_Developer_Guide_Linux_GMAC_CN.pdf Rockchip_Developer_Guide_Linux_GMAC_Mode_Configuration_CN.pdf Rockchip_Developer_Guide_Linux_GMAC_RGMII_Delayline_CN.pdf Rockchip_Developer_Guide_Linux_GMAC_RGMII_Delayline_EN.pdf |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 03:57 , Processed in 1.316119 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4213
